Moj Mikro magazine listings: Super fast circle routine
2 replies to this topic
#1 Gury OFFLINE
Gury
  • 1,315 posts
Posted Wed Apr 7, 2010 11:47 PM
I present you super fast routine for drawing circles in graphics mode 8 and 8 + 16.
Moj Mikro magazine article listings are available as zipped file in download section. It contains ATR disk image file with Atari DOS system for using with disk based, real Atari machine or any Atari 8-bit emulator. To load Atari BASIC programs properly, Atari must be powered with Atari BASIC enabled, or you can try them with any compatible BASIC.
Posted Image
You can try, use and modify the programs and routines for whatever purpose you want.
Super Fast Circle Routine
Magazine: Moj Mikro, 1989/3
Author : Zlatko Bleha
Page : 27 - 31
Article link
Atari BASIC listing on disk (tokenized): M8903284.BAS
Atari BASIC listing (listed): M8903284.LST
Assembly language listing: CIRCLE.LST
This routine uses very fast algorithm for drawing circles. It works in graphics mode 8. To see it in action, try the following demonstration program, which includes circle routine in DATA tables for using it from Atari BASIC. Also included is assembly language source code for anybody to examine inner workings of the algorithm. It is written in ATMAS 2.
Posted Image Posted Image Posted Image Posted Image Posted Image
Description
Algorithm is based on one from Croatian computer magazine Racunari (number 31). There is a little faster way of doing this, but data must be provided in tables for sine and cosine. But this alternative takes more RAM.
The routine consists of two parts: main program for calculating X and Y coordinates and second part with PLOT routine for drawing (or erasing) pixels on X and Y coordinates. Calculation of coordinates is done for one eighth of the circle. Other seven parts are simply mirrored from original mentioned pattern. We take advantage of this fact, because circle is simetricly shaped. The routine uses Page Zero locations for variables for even faster execution. There are 17 of them.
Usage of the routine
A=USR(30000,POK,X,Y,R)
30000 - Starting address of the calling routine
POK - 1 (draw the circle), 0 (erase the circle)
X - X coordinate of the circle
Y - Y coordinate of the circle
R - Radius of the circle
The routine is not relocatable. If you want to relocate it anyway, use assembler of your choice and assemble it to another location or amend the DATA tables in Atari BASIC program demonstration.
Maximum value for radius is 127, which is more than enough, because the circle with such radius will not be seen on the screen in whole anyway. If you choose wrong parameter values and consequently break the borders of the screen, don't worry, circle will be drawn anyway, but with its parts in different places. Experiment with the values for best results and your own fun.
The included assembly language listing shows what is necessary for implementing circle algorithm, calculating coordinates and drawing pixels and circles on the screen.
Fast circle drawing in pure Atari BASIC
Page : 27 - 31
Atari BASIC listing on disk (tokenized): M8903282.BAS
Atari BASIC listing (listed): M8903282.LST
Next example is demonstration of implementing mentioned circle algorithm in pure Atari BASIC. This program shows how much faster it is compared to classic program using sine and cosine functions from Atari BASIC (shown in last example).
Use some valid values for coordinates and radius, for example:
X=40, Y=40, R=30
X=130, Y=90, R=60
Slow circle drawing in Atari BASIC
Page : 27 - 31
Atari BASIC listing on disk (tokenized): M8903281.BAS
Atari BASIC listing (listed): M8903281.LST
This is classic example for drawing circles from Atari BASIC using sine and cosine functions. Unfortunatelly, this is very slow way of doing it and not recommended. Just use routine shown above and everybody will be happy :)
Posted Image
Conclusion
Returning back to first program with the fastest way of drawing circles... There is one more thing to note. In case you want to use PLOT subroutine, which is part of the main circle routine, then read following explanation.
PLOT routine is written so it can be used easily from Atari BASIC program independently from main circle routine, by using like this:
A=USR(30179,POK,X,Y)
POK - 1 (drawing a pixel), 0 (erasing a pixel)
X - X coordinate of the pixel
Y - Y coordinate of the pixel
The routine alone is not any faster than normal PLOT command from Atari BASIC, because USR command takes approximatelly 75% of whole execution. But, used as part of the main circle routine it does not matter anymore, because it is integrated in one larger entity. There the execution is very fast, with no overhead. PLOT routine is here for you to examine anyway. You never know if you will maybe need it in the future.
Greetings,
Gury
Edited by Gury, Wed Apr 7, 2010 11:50 PM.
#2 cas OFFLINE
cas
    Dragonstomper
  • 524 posts
Posted Thu Apr 8, 2010 12:10 AM
Greetings,
Gury
Hello Gury,
thanks for posting this, this is very useful stuff!
-- Carsten
#3 Gury OFFLINE
Gury
  • 1,315 posts
Posted Thu Apr 8, 2010 1:20 AM
You are welcome, Cas, and thank you. I hope people will make good use of the routine and have some fun.
I mistakely uploaded listed files as binary files. I will fix the problem when I come home. Anyway, here are the listings for you to look at.
M8903284.LST
1 REM *******************************
2 REM PROGRAM : SUPER FAST CIRCLE ROUTINE
3 REM AUTHOR : ZLATKO BLEHA
4 REM PUBLISHER: MOJ MIKRO MAGAZINE
5 REM ISSUE NO.: 1989, NO.3, PAGE 28
6 REM *******************************
7 REM
10 FOR A=30000 TO 30288
20 READ B:C=C+B:POKE A,B
30 NEXT A
40 IF C<>28218 THEN ? "*** DATA ERROR ***":END
50 DATA 120,104,104,104,133,58,104,133,51,133
60 DATA 60,104,133,50,133,59,104,104,168,133
70 DATA 54,104,104,208,5,152,88,76,242,117
80 DATA 133,56,56,233,1,133,55,160,0,132
90 DATA 57,165,59,24,101,57,133,50,152,101
100 DATA 60,133,51,165,54,101,56,133,61,32
110 DATA 242,117,165,54,56,229,56,133,62,32
120 DATA 242,117,165,59,56,229,57,133,50,165
130 DATA 60,233,0,133,51,165,62,32,242,117
140 DATA 165,61,32,242,117,165,59,24,101,56
150 DATA 133,50,152,101,60,133,51,165,54,101
160 DATA 57,133,63,32,242,117,165,54,56,229
170 DATA 57,133,64,32,242,117,165,59,56,229
180 DATA 56,133,50,165,60,233,0,133,51,165
190 DATA 64,32,242,117,165,63,32,242,117,230
200 DATA 57,165,55,56,229,57,229,57,16,7
210 DATA 198,56,24,101,56,101,56,133,55,165
220 DATA 56,197,57,48,3,76,89,117,96,104
230 DATA 104,104,133,58,104,133,51,104,133,50
240 DATA 104,104,160,0,132,49,133,48,10,38
250 DATA 49,10,38,49,24,101,48,170,152,101
260 DATA 49,133,49,138,10,38,49,10,38,49
270 DATA 10,38,49,24,101,88,133,48,165,49
280 DATA 101,89,133,49,166,51,134,53,165,50
290 DATA 170,70,53,106,70,53,106,70,53,106
300 DATA 24,101,48,133,48,165,53,101,49,133
310 DATA 49,138,41,7,170,152,56,106,202,16
320 DATA 252,166,58,240,6,17,48,145,48,88
330 DATA 96,73,255,49,48,145,48,88,96
500 REM ***************************
501 REM * DEMONSTRATION PROGRAM *
502 REM ***************************
503 REM
510 GRAPHICS 8:SETCOLOR 2,0,0:COLOR 3
520 FOR A=2 TO 90
530 Q=USR(30000,1,A,A,A)
540 Q=USR(30000,1,319-A,A,A)
550 NEXT A
560 ? "PRESS ANY KEY TO CONTINUE"
570 IF PEEK(555)=0 THEN 570
580 ? <img src='http://www.atariage.com/forums/public/style_emoticons/<#EMO_DIR#>/icon_confused.gif' class='bbc_emoticon' alt=':?' /> <img src='http://www.atariage.com/forums/public/style_emoticons/<#EMO_DIR#>/icon_confused.gif' class='bbc_emoticon' alt=':?' /> :FOR A=2 TO 90
590 Q=USR(30000,1,319-A,159-A,A)
600 Q=USR(30000,1,A,159-A,A)
610 NEXT A
620 ? "PRESS ANY KEY TO CONTINUE"
630 IF PEEK(555)=0 THEN 630
640 GRAPHICS 8:SETCOLOR 2,0,0:COLOR 3
650 FOR A=2 TO 79 STEP 4
660 Q=USR(30000,1,100,A,A)
670 NEXT A
680 FOR A=82 TO 2 STEP -4
690 Q=USR(30000,1,A+100,A,A)
700 NEXT A
710 ? "PRESS ANY KEY TO START AGAIN"
720 IF PEEK(555)=0 THEN 720
730 GOTO 510
M8903282.LST
2 REM PROGRAM : FAST CIRCLE DRAWING
5 REM ISSUE NO.: 1989, NO.3, PAGE 29
7 REM
20 ? "ENTER X, Y AND R"
30 INPUT X,Y,R
40 IF R=0 THEN PLOT X,Y:END
50 B=R:C=0:A=R-1
60 PLOT X+C,Y+B
70 PLOT X+C,Y-B
80 PLOT X-C,Y-B
90 PLOT X-C,Y+B
100 PLOT X+B,Y+C
110 PLOT X+B,Y-C
120 PLOT X-B,Y-C
130 PLOT X-B,Y+C
140 C=C+1
150 A=A+1-C-C
160 IF A>=0 THEN 190
170 B=B-1
180 A=A+B+B
190 IF B>=C THEN 60
M8903281.LST
2 REM PROGRAM : SLOW CIRCLE DRAWING
7 REM
20 FOR A=0 TO 6.28 STEP 0.02
30 X=SIN(A)*50+150
40 Y=COS(A)*50+80
50 PLOT X,Y
60 NEXT A
CIRCLE.LST
* FAST CIRCLE DRAWING ROUTINE
* Author : Zlatko Bleha
* Publisher: Moj Mikro magazine
* Issue No.: 1989, No.3, Page 27
* System variables on Page Zero
LO	EQU $30
HI	EQU $31
XLO EQU $32
XHI EQU $33
XLOH EQU $34
XHIH EQU $35
Y 	EQU $36
A 	EQU $37
B 	EQU $38
C 	EQU $39
POK EQU $3A
X1	EQU $3B
X2	EQU $3C
YVIB EQU $3D
YMAB EQU $3E
YVIC EQU $3F
YMAC EQU $40
* Taking circle parameters from stack
 	ORG $7530
 	SEI
 	PLA
 	PLA
 	PLA
 	STA POK
 	PLA
 	STA XHI
 	STA X2
 	PLA
 	STA XLO
 	STA X1
 	PLA
 	PLA
 	TAY
 	STA Y
 	PLA
 	PLA
 	BNE NEXT
 	TYA
 	CLI
 	JMP PLOT
NEXT STA B
 	SEC
 	SBC #$1
 	STA A
 	LDY #$0
 	STY C
* PLOT X+C,Y+B
LOOP LDA X1
 	CLC
 	ADC C
 	STA XLO
 	TYA
 	ADC X2
 	STA XHI
 	LDA Y
 	ADC B
 	STA YVIB
 	JSR PLOT
* PLOT X+C,Y-B
 	LDA Y
 	SEC
 	SBC B
 	STA YMAB
 	JSR PLOT
* PLOT X-C,Y-B
 	LDA X1
 	SEC
 	SBC C
 	STA XLO
 	LDA X2
 	SBC #$0
 	STA XHI
 	LDA YMAB
 	JSR PLOT
* PLOT X-C,Y+B
 	LDA YVIB
 	JSR PLOT
* PLOT X+B,Y+C
 	LDA X1
 	CLC
 	ADC B
 	STA XLO
 	TYA
 	ADC X2
 	STA XHI
 	LDA Y
 	ADC C
 	STA YVIC
 	JSR PLOT
* PLOT X+B,Y-C
 	LDA Y
 	SEC
 	SBC C
 	STA YMAC
 	JSR PLOT
* PLOT X-B,Y-C
 	LDA X1
 	SEC
 	SBC B
 	STA XLO
 	LDA X2
 	SBC #$0
 	STA XHI
 	LDA YMAC
 	JSR PLOT
* PLOT X-B,Y+C
 	LDA YVIC
 	JSR PLOT
 	INC C
 	LDA A
 	SEC
 	SBC C
 	SBC C
 	BPL JUMP
 	DEC B
 	CLC
 	ADC B
 	ADC B
JUMP STA A
 	LDA B
 	CMP C
 	BMI END
 	JMP LOOP
END RTS
* PLOT routine
* Taking parameters from stack in case
* PLOT routine is called directly from
* BASIC
 	PLA
 	PLA
 	PLA
 	STA POK
 	PLA
 	STA XHI
 	PLA
 	STA XLO
 	PLA
 	PLA
 	LDY #$0
* Beginning of the PLOT routine
* Calculating A*40
PLOT STY HI
 	STA LO
 	ASL
 	ROL HI
 	ASL
 	ROL HI
 	CLC
 	ADC LO
 	TAX
 	TYA
 	ADC HI
 	STA HI
 	TXA
 	ASL
 	ROL HI
 	ASL
 	ROL HI
 	ASL
 	ROL HI
* A*40+VIDEO
 	CLC
 	ADC $58
 	STA LO
 	LDA HI
 	ADC $59
 	STA HI
* X/8
 	LDX XHI
 	STX XHIH
 	LDA XLO
 	TAX
 	LSR XHIH
 	ROR
 	LSR XHIH
 	ROR
 	LSR XHIH
 	ROR
* A*40+VIDEO+X/8
 	CLC
 	ADC LO
 	STA LO
 	LDA XHIH
 	ADC HI
 	STA HI
* Calculating a location of
* destination bit
 	TXA
 	AND #$7
 	TAX
 	TYA
 	SEC
ROT ROR
 	DEX
 	BPL ROT
* PLOT or UNPLOT?
 	LDX POK
 	BEQ UNPLOT
* PLOT
 	ORA (LO),Y
 	STA (LO),Y
 	CLI
 	RTS
* UNPLOT
UNPLOT EOR #$FF
 	AND (LO),Y
 	STA (LO),Y
 	CLI
 	RTS
