split charset in rasters
10 replies to this topic
#1 tebe OFFLINE
tebe
    Dragonstomper
  • 545 posts
Posted Sun Apr 11, 2010 11:00 AM
color yellow = charset #0
color blue = charset #1
http://atariarea.kra...=108675#p108675
Atari800Win show screen OK, but Altirra no
Edited by tebe, Sun Apr 11, 2010 11:38 AM.
#2 Tezz ONLINE
Tezz
  • 2,246 posts
Posted Sun Apr 11, 2010 12:01 PM
Whilst working on MM with the cycle counting for mid scanline changes, I've noticed a slight difference in the amount of acceptable cycles between Awin+ and Alterra. I was planning to do some tests between them and the real hardware.
#3 phaeron OFFLINE
phaeron
  • 1,841 posts
Posted Sun Apr 11, 2010 2:26 PM
Yes, it looks like you've found an emulation bug -- ANTIC needs to respond one cycle later to the CHBASE change.
In general, timing accuracy in Altirra is a bit better for GTIA than it is for ANTIC or POKEY. I've fixed some of the issues in 1.5, but haven't done a full release yet, so the DMACTL and STIMER fixes are only in 1.6 test releases:
http://www.virtualdu...-1.6-test15.zip
#4 Heaven/TQA OFFLINE
Heaven/TQA
  • 9,781 posts
Posted Sun Apr 11, 2010 2:30 PM
can someone post a screenshot how the demo should look like?
#5 phaeron OFFLINE
phaeron
  • 1,841 posts
Posted Sun Apr 11, 2010 5:50 PM
Here's a picture from my NTSC 800XL. YCMV (your colors may vary).
Adding a one-cycle delay to CHBASE seems to fix the problem:
http://www.virtualdu...-1.6-test17.zip
#6 tebe OFFLINE
tebe
    Dragonstomper
  • 545 posts
Posted Sun Apr 18, 2010 12:33 PM
disabled "badlines" (GED+ mode without badlines)
new g2f feature, but 5-th color missed and 8 first and 4 last lines from screen
#7 Tezz ONLINE
Tezz
  • 2,246 posts
Posted Sun Apr 18, 2010 2:33 PM
interesting, so it's a software char mode via mode E? I'll go take a look at this now.
Edited by Tezz, Sun Apr 18, 2010 2:34 PM.
#8 Rybags OFFLINE
Rybags
  • 14,200 posts
Posted Sun Apr 18, 2010 4:28 PM
So this uses some sort of VScrol trick?
But, what's the use of disabling badlines? That should mean you get stuck with the same 40 characters and would need to change character set every 8 lines.
#9 tebe OFFLINE
tebe
    Dragonstomper
  • 545 posts
Posted Mon Apr 19, 2010 12:45 AM
yes
#10 Rybags OFFLINE
Rybags
  • 14,200 posts
Posted Mon Apr 19, 2010 1:12 AM
But, what advantage does it offer over traditional G2F techniques, or Mode E?
I can visualise a situation where you might have 3 splits so you can use characters 0-119 of 8 character sets over 24 lines, but it isn't going to give any memory savings, plus you'd be stuck with whatever attributes the initial character has (bit 7).
#11 tebe OFFLINE
tebe
    Dragonstomper
  • 545 posts
Posted Mon Apr 19, 2010 3:12 PM
nothing special, only "we can do it" :)
