Magellan
540 replies to this topic
#351 artrag OFFLINE
artrag
  • 1,262 posts
Posted Wed Jan 15, 2014 1:48 AM
A quick question how can I select a tile from the map in order to edit it?
#352 sometimes99er OFFLINE
sometimes99er
  • 4,225 posts
Posted Wed Jan 15, 2014 3:30 AM
Useless answer completely eradicated. :|
Edited by sometimes99er, Wed Jan 15, 2014 8:26 AM.
#353 artrag OFFLINE
artrag
  • 1,262 posts
Posted Wed Jan 15, 2014 4:36 AM
IMHO it is an essential feature to quickly locate into the current tileset a detail of the map, expecially when you import a PNG image and the tileset is computed automatically.
I would "select" it in the tileset by clicking with the right button of the mouse, this would allow an easy copy & past and fast editing.
Actually, but it is a matter of personal tases, I would also allow a copy & past of squared areas by holding the right button while selecting a square of tiles to be copied, but there is already a tool for this.
Edited by artrag, Wed Jan 15, 2014 4:38 AM.
#354 sometimes99er OFFLINE
sometimes99er
  • 4,225 posts
Posted Wed Jan 15, 2014 5:11 AM
Edited by sometimes99er, Mon Jan 20, 2014 2:54 AM.
#355 Asmusr OFFLINE
Asmusr
  • 3,116 posts
Posted Wed Jan 15, 2014 7:40 AM
There is a 'Look At' function. It's in the character editor toolbar rather than in the map editor toolbar where it really belongs.
#356 artrag OFFLINE
artrag
  • 1,262 posts
Posted Wed Jan 15, 2014 2:17 PM
Found! Thanks.
It is not as practical as the right button of the mouse but it does what it is for.
#357 artrag OFFLINE
artrag
  • 1,262 posts
Posted Sat May 3, 2014 2:06 AM
I have found some bugs in magellan v2.1
the import function is very buggy:
If I try to import a VRAM dump as binary file I get imported only the first 256 character despite of the fact it is a full bitmap image of 768 tiles
I selected USE HEXADECIMAL  and BITMAP MODE and i set the correct addresses in the BIN file and I get only 256 tiles
I tried in OPTIONS to set the BITMAP COLOR MODE and all the other modes and to select "EXPANDED CHARACTERS" but the import always works only on 256 tiles!
Try to import OPENING_.BIN and you will see what i mean
shapes are at 0000 hex
map is at 1800 hex
colors are at 2000 hex
If I try to import a PNG image or a GIF Image using IMPORT -> MAP IMAGE I get only 256 tiles as well, with some specific image formats (I think it is connected to 16 color PNG and 256 color gif, but I'm not sure).
Try to import OPENING_SCREEN.PNG and you will see the problem
Edited by artrag, Sat May 3, 2014 2:07 AM.
#358 Asmusr OFFLINE
Asmusr
  • 3,116 posts
Posted Sat May 3, 2014 3:49 AM
Well, yes - it only works with up to 256 tiles. It would not be that difficult to add support for more tiles, but it's not on my todo list right now.
#359 Asmusr OFFLINE
Asmusr
  • 3,116 posts
Posted Sat May 3, 2014 5:03 AM
I shouldn't hold on to the source code if anyone else wants to improve it further. So here is the latest version with a few small changes and bug fixes (but still only 256 tiles).
#360 OLD CS1 OFFLINE
OLD CS1
    >OLD CS1█
  • 6,111 posts
  • Technology Samurai
Posted Sun Sep 14, 2014 9:52 PM
Is it possible to put the VDP into bitmap mode in Extended BASIC?  I ask here because I would like to export some test screens to XB.  When I tried I got a blank screen during the program run.
#361 senior_falcon OFFLINE
senior_falcon
  • 1,498 posts
Posted Sun Sep 14, 2014 10:47 PM
There is more to it than just setting the registers to the bitmap values.  You can use "The Missing Link" which can be found in the development resources.  This can run XB programs while in bitmapped mode. Also plotting, text in various sizes, etc.  You can import pictures in TI Artist format.    I think there is another similar package from Germany, but don't know what it is called.  I tried one called "Draw and Plot" which was not very good.
#362 Ksarul OFFLINE
Ksarul
  • 5,279 posts
Posted Sun Sep 14, 2014 11:04 PM
You may be looking for the APESoft routines, as they add a lot of graphics manipulation to Extended BASIC. They are also available in the Mechatronics Extended BASIC II module.
#363 OLD CS1 OFFLINE
OLD CS1
    >OLD CS1█
  • 6,111 posts
Posted Mon Sep 15, 2014 7:04 AM
I will have a quick look, thanks.  I had hoped the XB environment would easily support bitmap mode as I just want a quick look-see at how a screen will look on the real iron.  I will probably get more mileage out of exporting to assembly and compiling (assembling) it as it will be the same environment I work in, ultimately.
Edited by OLD CS1, Mon Sep 15, 2014 7:09 AM.
#364 Lee Stewart OFFLINE
Lee Stewart
  • 3,972 posts
Posted Mon Sep 15, 2014 11:00 AM
You might try fbForth 2.0 (still in beta 10).  If you use split or split2 modes, you can manipulate the bitmap part of the screen manually from the text part (8 text lines in split mode and 4 in split2 mode).  You can use the full width of the screen in both modes (dot-columns 0 – 215).  You are limited to dot-rows 0 – 127 in split mode  and dot-rows 32 – 191 in split2 mode.  You can actually do it in full bitmap mode (graphics2) as well—you just can't see what you are typing.
...lee
#365 OLD CS1 OFFLINE
OLD CS1
    >OLD CS1█
  • 6,111 posts
Posted Wed Sep 17, 2014 2:13 PM
The only thing I would find useful right now is the ability to print a map directly from within the program.  I get that starts getting too platform specific, though.  I can for now just export to a graphic image and then print that image from my favorite program.
#366 OLD CS1 OFFLINE
OLD CS1
    >OLD CS1█
  • 6,111 posts
Posted Wed Sep 17, 2014 10:10 PM
I want to make sure I understand bitmap mode so I appreciate any corrections or elaborations.
In bitmap mode, there are 768 screen positions (screen image table.)  Each image table position contains a value (name) which references one of 256 patterns in the pattern description table and an associated entry in the color table, the latter referenced from one of three tables dependent upon which third of the image table is calling the name.
Thus, using mixed conventions so bear with me:
tile=SIT(p)
    =PDT(INT(p/256),p MOD 256) & CT(INT(p/256), p  MOD 256)
[note how PDT( x ,y) is intrinsically linked to CT(x,y)]
As a result:
1) Patterns which exist in one third of the image table must be repeated if they are to be used in more than one one-third part of the image table.
To wit: For pattern 240 in pattern table section 0 to be used in image table positions 110 and 320, pattern 240 from section 0 must be repeated somewhere in section 1, not necessarily as pattern 240.
2) Patterns which wish to be reused but with a different color set, irrespective of which third of the image table calls them, must be repeated somewhere in the pattern generator table with associated entry in the color table of the desired colors.
To wit: For pattern 240 above to be used in image table positions 24 and 48 but with different color settings, pattern 240 must be repeated as another pattern in the same table section but with a differing associated entry in the color table.
Given a correct assessment, the question is begged: why do I only have 256 tiles available in Magellan if bitmap mode is defined as three groups of 256 patterns?
Edited by OLD CS1, Wed Sep 17, 2014 10:36 PM.
#367 Asmusr OFFLINE
Asmusr
  • 3,116 posts
Posted Wed Sep 17, 2014 11:01 PM
I only have time for a short answer. Magellan supports bitmap mode colors but only one set of 256 patterns. I have used it for editing graphics for 'half-bitmap' mode where the same patterns are used all over the screen. Magellan is not a screen editor but a map editor. Even if it supported 3 different pattern sets it could not make assumptions about which part of the map uses which pattern set. Perhaps you're really looking for a screen based bitmap mode editor?
Edit: If you can settle for 256 patterns but want to use full bitmap mode on the TI, all you have to do is to copy the patterns and colors 3 times to each VDP RAM table, but this is a waste of VDP RAM. The half bitmap mode where the same patterns/colors are used all over the screen does not allow you to use more than 8 sprites, so the best mode for working with 256 patterns and bitmap mode colors is what I call 2/3 bitmap mode where you have 3 pattern tables and 1 color table. The does not have any sprite issues and uses only 2/3 of the RAM (8K) compared to full bitmap mode (12K). In an assembly game you can easily find a need for the extra RAM - in particular if you want to use F18A multicolor sprites.
#368 sometimes99er OFFLINE
sometimes99er
  • 4,225 posts
Posted Wed Sep 17, 2014 11:49 PM
Edited by sometimes99er, Thu Sep 18, 2014 3:55 AM.
#369 Asmusr OFFLINE
Asmusr
  • 3,116 posts
Posted Thu Sep 18, 2014 12:33 AM
... but colors can't be copied ...
Actually bitmap mode colors can be copied in the latest version.
#370 sometimes99er OFFLINE
sometimes99er
  • 4,225 posts
Posted Thu Sep 18, 2014 1:55 AM
#371 OLD CS1 OFFLINE
OLD CS1
    >OLD CS1█
  • 6,111 posts
Posted Thu Sep 18, 2014 9:37 AM
Okay, so there are more modes for me to understand.  For what I am doing right now I think 256 patterns and colors should be sufficient.  Future projects may be more ambitious.
#372 artrag OFFLINE
artrag
  • 1,262 posts
Posted Thu Sep 18, 2014 12:16 PM
Never the less, supporting 768 tiles could be very handy, maybe only when the map is 24 tiles tall...
Anyway, I've also another request: usually one have to make multiple maps sharing the same tile set.
A nice feature could be that when you import a png and you have already a tileset defined you can "lock" the tiles already defined and just add the new tiles in the free positions eventually reusing the tiles that match with those already defined.
In this way you can import pictures and merge the tilesets that give those pictures.
Edited by artrag, Thu Sep 18, 2014 2:29 PM.
#373 Asmusr OFFLINE
Asmusr
  • 3,116 posts
Posted Thu Sep 18, 2014 2:56 PM
A very reasonable request. I have also needed that.
#374 OLD CS1 OFFLINE
OLD CS1
    >OLD CS1█
  • 6,111 posts
Posted Thu Sep 18, 2014 6:15 PM
I second this.  To work with multiple images I have to set up a different map project for each one.
#375 OLD CS1 OFFLINE
OLD CS1
    >OLD CS1█
  • 6,111 posts
Posted Thu Sep 18, 2014 6:18 PM
Double-posted.
Edited by OLD CS1, Thu Sep 18, 2014 6:19 PM.
