AtariGeezer Posted October 25, 2013 Share Posted October 25, 2013 (edited) This is the description of the Manufacturing Test Cartridge at Best Electronics Atari 810 Factory Manufacturing Test Cartridge. 810 / 1050 Disk Drive number test (for internal Atari disk drive number slide select switches), Alignment test (requires an Oscilloscope and 5 1/4 Alignment disk), Interchange Test Disk Manufacturing Test (no print out) and 810 Sideboard ROM level check. © That description is closer to the Field Exerciser Cartridge except that it doesn't format the floppy. It writes all sectors, reads all sectors, then repeats until stopped(it takes almost 8 minutes to complete a pass). The other test is an alignment test, which just reads track 16 continously until stopped. Actually it looks to be part of the "810 Disk Manufacturing Tests" Option #5 From my dump of this, it shows Version E00.13, so possibly an Engineering Test Prototype??? Edited October 25, 2013 by AtariGeezer Quote Link to comment Share on other sites More sharing options...
AtariGeezer Posted October 25, 2013 Share Posted October 25, 2013 Any dumps of this Atari 810 cartridge? That is what I am asking... Quote Link to comment Share on other sites More sharing options...
BillC Posted October 30, 2013 Share Posted October 30, 2013 Here's a few to play with. Couldn't get Magic Dump II to dump and run in Altirra. The two DOS ones are homemade carts I got in a lot long ago with homemade labels but I figured what the heck. Also have to dig up EasyScan and try to dump it. Not that it is usable without the fiberoptic cart. Al File contains: 400 Microprinter System 400/800 SALT Diagnostic cart 2.05 400/800/XL SuperSALT Diagnostic cart rev A 800 Microprinter System 810 Diagnostic cart DT80 ATR 800 Pronto: The Home Information System Super Zaxxon Topper The title 810 Diagnostic cart isn't very descriptive, Best Electronics sells 4 test/diagnostic cartidges for the 810. I looked in the binary using hexdump and this is the one Best describes as Atari 810 CPS Field Exerciser Diagnostic Cartridge. The reason for the title is probably that this is the only version that B&C/myatari.com sell, and is labeled 810 DIAGNOSTIC CARTRIDGE FD100006 Quote Link to comment Share on other sites More sharing options...
tep392 Posted October 30, 2013 Share Posted October 30, 2013 The diagnostic cart image I have will move the head to track 16 for an alignment check but according to the 810 field service manual, a master alignment diskette is required. I'm wondering if the master diskette has special data on that track or if any factory formated disk can be used, such as a dos master disk. Any thoughts? The alignment procedure also has steps to move the head to the first and last tracks, but I don't see how that can be done with the diagnostic cart. The manual refers to a "disk alignment cartridge or program". Anybody know what cartridge this is refering to? 810 Diagnostic Cartridge (1982).bin 4 Quote Link to comment Share on other sites More sharing options...
BillC Posted October 30, 2013 Share Posted October 30, 2013 The diagnostic cart image I have will move the head to track 16 for an alignment check but according to the 810 field service manual, a master alignment diskette is required. I'm wondering if the master diskette has special data on that track or if any factory formated disk can be used, such as a dos master disk. Any thoughts? The alignment procedure also has steps to move the head to the first and last tracks, but I don't see how that can be done with the diagnostic cart. The manual refers to a "disk alignment cartridge or program". Anybody know what cartridge this is refering to? Best Electronics sells 4 different test/diagnostic cartridges for 810 drives. Since the Field Exerciser Diagnostics can only check head alignment on track 16 it was probably meant for just doing a quick test, and if there were problems one of the others would be used to adjust alignment. All 4 cartridges with descriptions are on the following web page at Best, they also have a Dysan alignment disk on the page as well. http://www.best-electronics-ca.com/8-bit_.htm Quote Link to comment Share on other sites More sharing options...
+bob1200xl Posted October 31, 2013 Share Posted October 31, 2013 Head alignment requires a special disk with elliptical tracks. Basically, track 15 is written across track 16 as is track 17 written across track 16. When you scope the head output while reading track 16 continuously, you see the two tracks (15 and 17) in a particular cats-eye pattern. You adjust the alignment such that the two tracks are equal amplitude. That sets the head alignment. You can't use a normal disk. It only works on track 16. Bob 3 Quote Link to comment Share on other sites More sharing options...
tep392 Posted October 31, 2013 Share Posted October 31, 2013 Head alignment requires a special disk with elliptical tracks. Basically, track 15 is written across track 16 as is track 17 written across track 16. When you scope the head output while reading track 16 continuously, you see the two tracks (15 and 17) in a particular cats-eye pattern. You adjust the alignment such that the two tracks are equal amplitude. That sets the head alignment. You can't use a normal disk. It only works on track 16. Bob Great info. Guess I'll have to track down one of these disks. Quote Link to comment Share on other sites More sharing options...
AtariGeezer Posted April 21, 2014 Share Posted April 21, 2014 Adding AtariLab Temperature and Light ROMs AtariLab-Light.rom AtariLab-Temp.rom Tested on latest Altirra... 3 Quote Link to comment Share on other sites More sharing options...
AtariGeezer Posted May 15, 2014 Share Posted May 15, 2014 Here's the CitiBank Direct Access that I got. It has quite a few different bytes than the other one Chris posted. CitiBank_DirectAccess_400_122484.rom 4 Quote Link to comment Share on other sites More sharing options...
AtariGeezer Posted July 21, 2014 Share Posted July 21, 2014 (edited) Adding MAC/65 version 1.02 Mac65102.ROM CAR file -> Remove ".zip from filename" Mac65102.car.zip Edited July 21, 2014 by AtariGeezer 10 Quote Link to comment Share on other sites More sharing options...
Smokeless Joe Posted July 21, 2014 Share Posted July 21, 2014 Hooray! Thank you! Quote Link to comment Share on other sites More sharing options...
AtariGeezer Posted July 22, 2014 Share Posted July 22, 2014 Hooray! Thank you! Glad you [Cough][/Cough] "Liked" it Quote Link to comment Share on other sites More sharing options...
AtariGeezer Posted September 26, 2014 Share Posted September 26, 2014 Here's the Letter Perfect 80 Column ROM and disks that I bought on ebay a couple of months ago. Enjoy LetterPerfect80.rom LetterPerfectDisk01.ATR LetterPerfectDisk02.ATR LetterPerfectDisk03.ATR LetterPerfectDisk04.ATR LetterPerfectDisk04-2.ATR LetterPerfectDisk05.ATR LP-80-ROM-PrinterEditor.ATR LP-80-ROM-PrinterEditorBackup.ATR 5 Quote Link to comment Share on other sites More sharing options...
k1w1 Posted September 29, 2014 Share Posted September 29, 2014 Thanks Geezer. Does the ROM require some form of hardware to access the 80 columns. I have tried to run this with Altirra with no luck. k1w1 Quote Link to comment Share on other sites More sharing options...
AtariGeezer Posted September 29, 2014 Share Posted September 29, 2014 Thanks Geezer. Does the ROM require some form of hardware to access the 80 columns. I have tried to run this with Altirra with no luck. k1w1 It needs a Bit-3 80 Column Board or Austin-Franklin 80-Column Board to run... Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted October 28, 2014 Share Posted October 28, 2014 Why would anybody use there eproms and boards and make a Basic Cart? I must have over 10 Basic carts I need to get rid of one of these days. Because a 400 or 800 need basic on cartridge, it is not built in like on an XL/XE Quote Link to comment Share on other sites More sharing options...
AtariGeezer Posted October 28, 2014 Share Posted October 28, 2014 Because a 400 or 800 need basic on cartridge, it is not built in like on an XL/XE Geez, I've got 25 Basic Rev A's from all of the lots I bought. Maybe time to start selling some Let's see, ( 800's, (2) 400's and (5) 1200xl's, so I have 10 spare 2 Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted October 29, 2014 Share Posted October 29, 2014 (edited) first you rip the rev. a chip out the cartridge then you insert a rev. C chip or prom.... rev. A and B. are buggy bug bug infested! You could load basic off of disk as well.... not nearly as good as a cartridge or chip or prom inside the Atari itself though. So I guess we all need revision C cartridges for our 400, 800, and 1200XL. and if your XL/XE has rev A or Rev B... cut it out and replace it.... Revision C Eliminated memory leaks in Revision B installed in later 800XLs, 800XLF, XEGS and all XE computers. You can find out the version by examining the location in memory, simply Enter the command PRINT PEEK(43234) at the READY prompt in basic will give a result of 162 for Revision A, 96 for Revision B, and 234 for Revision C. Edited October 29, 2014 by _The Doctor__ Quote Link to comment Share on other sites More sharing options...
AtariGeezer Posted October 29, 2014 Share Posted October 29, 2014 Yep, in 1984 I pulled the Basic ROM out of a 600xl parts unit that I got from the Atari Service Center on Guam. It was the Rev 'B' which I thought was B)etter so I plopped that into my Basic Cartridge, I'll have to find that one and swap it out (again). I'm thinking about burning Phaeron's' ATBasic onto an eprom and see how that goes. I do use my Rev 'C' carts (only have 2 at the moment) on a Stock 800 and 1200XL... 1 Quote Link to comment Share on other sites More sharing options...
Kr0tki Posted November 29, 2014 Share Posted November 29, 2014 BUMP! Time for a new update of the ROM spreadsheet. Thanks to all who contributed ROM images. It needs a Bit-3 80 Column Board or Austin-Franklin 80-Column Board to run... AtariGeezer, do you have any instruction manual to this Letter Perfect version? I've tried to run this ROM in Atari800, which can emulate the Austin Franklin, but couldn't work it out. 1 Quote Link to comment Share on other sites More sharing options...
AtariGeezer Posted November 29, 2014 Share Posted November 29, 2014 AtariGeezer, do you have any instruction manual to this Letter Perfect version? I've tried to run this ROM in Atari800, which can emulate the Austin Franklin, but couldn't work it out. Nope, didn't receive any docs, just the cart and disks... The reference I found before on the Austin Franklin was here: http://www.cyberroach.com/analog/an22/new_letter_perfect.htm Quote Link to comment Share on other sites More sharing options...
peteym5 Posted December 12, 2014 Share Posted December 12, 2014 Speaking of carts. AtariSales is running a promotion until the end of the month. A few are a collectors item with a limited amount remaining. http://members.tcq.net/video61/holiday2014.html Quote Link to comment Share on other sites More sharing options...
ShosMeister Posted April 12, 2015 Share Posted April 12, 2015 Does anyone have instructions on using the WAM/Examiner? I have them and am trying to remember how to use them to copy my carts to move to my RetroPie but can't remember how it works. Obviously, plug Examiner in to joystick ports (1&2 or 3&4) but the disk doesn't boot. Guessing maybe binary load of Examiner? Then what? Will it make a .bin that I can copy off to the Pi? Quote Link to comment Share on other sites More sharing options...
Paul Westphal Posted April 12, 2015 Share Posted April 12, 2015 This reminds me - I have a Krazy Shoot Out that is labeled CBS but had the Kbyte title screen. I have only even seen one of these. Quote Link to comment Share on other sites More sharing options...
Atari8bitCarts Posted April 12, 2015 Share Posted April 12, 2015 This reminds me - I have a Krazy Shoot Out that is labeled CBS but had the Kbyte title screen. I have only even seen one of these. Does the cart housing look original (not tampered with, etc.). I remember that housing is the same one both versions, different colors? Unless it was being private labeled that would be strange I would think. Quote Link to comment Share on other sites More sharing options...
