Chip8x - Chip8/superchip8 Emulator For Xbox V4
No replies to this topic
#1 Shannon OFFLINE
Shannon
    Born To Be Insane
  • 7,846 posts
  • Pac-man Fever
Posted Tue Apr 20, 2010 11:40 PM
Chip8X - CHIP8/SuperCHIP8 Emulator for XBox v4
http://xport.xbox-scene.com
goto http://www.ressurectionxtras.net/ for latest cheats, rumbles, synopsis and skin updates.
recent changes..
- New feature "Seconds before playing movie" determines how long the emu will wait before playing a movie. The default is half a second. This will help speed up rom browsing. Especially useful for people streaming stuff (like movies) across the network.
- If streaming movies from across the network and the user press on the dpad or a, b, x or y the emulator will abort the transfer. This should help speed up rom browsing and allow the user an "out" especially for the larger movies.
- Fixed an issue with the software filters displaying garbage.
- Activated the "Keep user Within ROM Directory Tree?" which I somehow missed.
- Fixed up the box/cart art position on a few skins.
- Fixed a problem where setting the box/cart orientation was screwed up.
- Fixed the bug that screwed up Gilou's skin to begin with (too weird to explain).
Chip8X - CHIP8/SuperCHIP8 Emulator for XBox v3
First off...
Special thanks....
X-port for porting a great collection of emu's over to the xbox, releasing the source code, and answering my stupid questions.
Atariage (Albert in particular) - For providing a place for me to ramble on. For encouragement in general.
RessurectionX for all that Xtra's stuff, synopsis, suggestions, etc.
Gilou9999 for a new PM3 skin, synopsis, suggestions, etc.
Comments of support from various interested parties.
If I missed anybody shoot me an email and I'll update this file.
*** Changes To Chipx Core ***
* Given the full "Madmab Edition" treatment.
* New dual-preview skin to support Ressurection Xtra's. Say thank you to Gilou9999 for the skin.
*** To Do For Chipx ***
* Eh?
*** Interface Related Changes ***
* Accurate Screen Pixel Ratio option added (see "http://fancyxbox.inf...1&secao=screen" for more into) per gilou9999's suggestion. Some numbers are still a WIP. Go into Game/Text Screen Size Position" and select "Set Game Screen to Accurate Screen Pixel Ratio". The emu will ask you if you wish to turn off software/hardware filters and flicker filter. This is recommended for the most accurate screen. You'll still have to manually adjust the image on the Y axis. We can't do everything for you, ya lazy bum!
* Added an option to display a "Static" video if no movie found. Can be set to yes or no. Static file must be named "Tv Static.xmv" and placed in the emu's "backgrounds" directory.
* Rewind is a bit of a memory hog. On some emu's at 720p it is barely useful. Some emu's can't even handle it. Here is what I did.
* Tweaked around with the rewind system fixed a couple potential xbox lockers.
* Modified the rewind system so if memory runs low it clears half the buffer, if that doesn't work it clears the entire buffer. What this means is that on memory intensive emu's you'll have a rewind system that mostly works. It's pretty much a "better than nothing" set-up.
* Modified the emu so that it allocates screen memory based on the software filters used. If you use no software filters you can save up to 4 times memory. 2 times on 2x filters.
- As a result if you change the filters from none to 2x or 4x. Or change it from 2x to 4x you will have to exit and reload the game for it to work. The emu will remind you of this. I figured this would make a good compromise for people who wanna eek out a little extra RAM.
* Known emu's to have rewind issues.
- NeoGenesis in CD or 32x mode cannot deal with it. Frameskip had to be activated for it to even work in Genesis mode.
- Snes9xBox works almost 100% in 480i/480p. At 720p I relied on two things clearing the buffer when it's full and saving memory when filters are not used (see avoe)
* Pressing Back while in the the controller settings menu will set the value to "None".
* Hopefully addressed weird issues with "Force Reload D:\\*.ini Settings".
* New option to "Keep user Within ROM Directory Tree". You can find it in "General Settings, Page Two". Useful for keeping n00bs from getting lost while selecting games.
* Hoperfully cleaned up all instances where the current "game select" directory would get trashed.
* Transparency control for keypad and keyboard should now function properly.
* Tightened up the Synopsis parsing code (sorry RessX )
* Fixed issue where cycling thru screenshots when non-available would create an infinite loop.
* Fixed two bugs that would cause the game select screen to slow down massively. One related to having Box/Cart art timer set to 0. The other related to the rather large size of the Xtra's. You dirty pirate you!
Fixes to the keyboard/keypad including. These affect emu's that use a keyboard/keypad (Winuaex, AdamX, Atarixlbox)
* Keyboard/keypad no longer corrupts portions of the screen when being moved.
* Keyboard/keypad can be moved diagonally in ALL directions now
* Keyboard/keypad transparency now works properly when "Pause game while using Keyboard/Pad" is set to ON.
* Fixed issue with screen blurring when Keyboard/keypad is activated. I'm surprised I did not notice this earlier.
* Created a new overlay system. The file "overlay.ini" contains configuration information for each overlay, including the color of the transparent button.
* Fixed issue with the "Music Control Menu" where the "Go to next/previous song" options were not working.
* Fixed issue where "View playlist" did not show the first two songs.
* Fixed issue where "pause" would still display even after changing songs while viewing the playlist in "clear screen" mode.
* Add song to playlist now functions correctly.
* Added a seperate "Volume Control Menu". It can be accessed by pressing "Y" in the "In Game Options" menu, or from the "Game Configuration" menu. It lets the user set the volume for in game sound, mp3_cdda, cdda, movie and mp3 music player from 0-100.
* Fixed issue where games that had more than 48 CRCs in the cheat code database would cause a crash when game is selected while searching for cheat codes.
* Rumble codes and cheat codes are now stored in seperate files. ( "rumblelist.inf" and "codelist.inf" respectively). To make it easier to search for "rumble codes" only. Note to cheat code makers: be sure to make your cheat codes and rumble codes seperately now. For those importing rumbles, the rumble does not have to be "activated" in order to work, it just works. Remove it from the list if you no longer wish to use it, or set it to "Rumble Enabled On - Nothing".
* Cheat code menus moved around. In-Game menu option "Cheat Codes" was moved into "Game Utilities" and replaced with "Cheat Code Database" to make it easier for the gamer to use codes in the database. Cheat code creators just need to go into "Game Utilities" to get to their stuff.
* Skin can now have a "Startup Movie" on loading menu. Please use with discretion (no long movies). User can press B to skip the movie.
* "Startup Movie" can be displayed full screen or in a window. If fullscreen is used the loading menu will not be displayed.
* Transparency for "Startup Movie" can be set as well.
* Moved the network initialization code to run before the loading menu. This moves the delay caused by network init to before the display of the loading menu, not after.
* Files when selecting within a zip are sorted.
* Added a seperate timer for alternating Box/Cart art.
* LThumb-Down - Go to next Box/Cart. LThumb-Up - Go to previous Box/Cart.
* Ability to view synopsis from within game. (press right analog stick down).
* Movies! The ability to display movie previews!
You can set the movie/previews directory in the "Change Default Directories" section.
The movie name has to be exactly the same as the ROM name. Only one movie per game.
* Display order can be set to. None, Screenshots Only, Movies Only, Screenshots 1st- Then Movies, Movies 1st- Then Screenshots.
* Sound for movies can be turned on/off
* Box/Cart art can be displayed in seperate window.
* Transparencies for Box/Cart art (and screenshots) is now supported Check out some of the 3d Box/Cart art floating around!
* Skin author can now designate two locations where Boxart or Cartart will display based on width vs height.
* Movies display over screenshots so if you want you can see screenshots when no movie exists.
* Can now stream videos and screenshots from Samba or Relax.
* Old Screenshots are now sorted and displayed in proper order.
* Old Screenshots can be named anything (as long as it has .png extension)
* In Game Options Screen can be sized and positioned now.
* New option to "Force Game Screen Size/Position". There are two configurable screensizes. (To deal with multi-core systems like MekaX and XboyAdvance). This will be useful when switching from HDTV to SDTV or vice versa. It will save the user the trouble of resizing the screens for something that is likely temporary.
* Numerous changes to menu system see above (current menu configuration layout)
* Skin Sprites can now be named for easier manipulation. Directory names must be of the format "0_spritename", "1_spritename", etc. Do not use underscores for the spritename. It is a delimiter.
* Added "Select Skin Configuration Used" and "Save Skin Configuration as" to the "Configure SKin" menu in place of the above moved options. This allows multiple skin configurations in one skin allowing the user more "pre-defined" options on how a skin looks. For example the placement of the games list and the preview screens. Gilou's Dynamic skins really take advantage of this, check 'em out!
* Sprites now display when sizing the preview screens.
* Changed "Seconds before auto-advancing Screenshot" to "Seconds Before Auto-Advancing Artwork".
* Changed "offset X" and "offset Y" to "Offset X (left/right)" and "Offset Y (up/down)" in the Sprite Settings menu.
* New Option to pause or not pause emulation when keyboard or keypad is up.
Finished the "Media browser"
* Be sure to use the RessurectionXtras for maximum enjoyment! "http://www.ressurectionxtras.net"
* Ability to display documentation (text or graphic) and commercials.
* Assigned buttons (white/black) to go to next/previous files when viewing documentation. See below graphic/text file viewer controls.
* Once the user opens a document - the emulator remember this document as long as the game session is running.
* View settings for each document viewed are now stored in a "bookmark" file so next time you view a file your settings are restored. Press Back to "reset" as if reading document for first time.
* "View Text File" changed to "Browse Manuals/Videos"
* Support added for different kinds of documentation in the media browser. Including "Manuals", "Game FAQs", "Game Maps", "Commercials", and "Other". The user can also specify where these directories are located. Defaults are "Manuals", "GameFAQs", "VGMAPS", "Commercials", and "Other". "Other" is in the media root directory (typically "x:\media\Other") for non emu specific stuff.
* User can specify whether manual is displayed "Full Size" or be "Sized to fit screen" when loaded. Keep in mind any saved bookmarks override this. Press Back to toggle between "Full Size" and "Size to fit screen".
* Commercials can be displayed either full screen, at the size of the video with black background, or same size of the video with synopsis background.
* NOTE: Some emulators are tight on memory (eg: NeoGenesis) and not all the Xtra's will load. If you have trouble with an image loading you might have to resize it.
* In screenshot viewer. If the image is smaller than your text file screensize settings it will work as follows.
a) If the image is taller than it is wide it will continue expanding the image ( based on aspect ratio) until the width fits within the width of your text file screensize width. (Most normal manuals)
If the image is wider than it is tall it will continue expanding the image ( based on aspect ratio) until the height fits within the height of your text file screensize height. (For example NES manuals).
This seems to effectively stretch the image in the best manner possible for scanned manual reading.
* Browsing manuals/videos should auto select any file matching your ROM name exactly. Select "View Media Directory" for manual browsing.
* Unmapped controls that allow you to move the screen around since word wrap should work correctly now.
* Change Fixed Width font controls are mapped to the right analog stick (left/right) like the help screen says it should be.
* Set font size keeps seperate settings for Fixed Width fonts and proportional fonts since they produce different results.
* Graphic documentation can now be stored in a ZIP file and still work with the media browser functions (next/previous and bookmarks).
* Music no longer starts playing after viewing text file in game.
* Number of lines displayed in the text file viewer now properly match user set text screen size.
* Number of lines displayed updates properly if user modifies text screen size within text file viewer
* Text file viewer functions turn off FixedWidth before displaying any menu.
* Added a fixed width font for the text file viewer. If you wanna use it you have to make sure that a file named (included in zip) "FixedFont.ttf" is located in the emulator directory. Press "Y" in the text file viewer to switch to the fixed font.
Controls for text browser
A -> Start Search
B -> Exit
X -> Continue Last Search
Y -> Simulate width font
White -> Previous file
Black -> Next file
Start -> Help screen
Back -> Reset view as if document was loaded for first time.
Dpad -> Up/down, Left-> Up Page, Right-> Down Page
Left Analog button -> Set font size
Left Analog Up -> Top of file
Left Analog Down -> End of file
Right Analog button -> Set text screen size
Right Analog left/right -> decrease/increase fixed-width font size
Left/Right triggers - Move up/down text file.
Controls for screenshot browser
A -> Lock/Unlock Aspect Ratio
B -> Exit
Y -> Delete file (Utilities-> browse screenshots only)
Black -> Next file
Back -> Toggle between "Full Size" and "Size to fit screen".
Dpad -> Up/Down/Left/Right -> Move image 1/4th the total size of the image.
Left Analog button -> Music Control Menu
Left Analog up/down -> Move screen up/down.
Right Analog left/right -> decrease/increase screen size. Size changes proportional to distance the stick is pressed.
**** Carryovers from Atarixlbox ****
* Ability to pick a file from within a zip file.
* Fixed a few interface "quirks" regarding playing game sounds while emu is paused.
* select save state screen tells you whether your "loading" or "saving", it also now displays whether a save file has a record session ( R ) associated with it.
* When a new save state is created it deletes any recordings. If you press the "back" button while in the save state select screen it will allow you to delete that save state (as well as it's recording).
* Utilities menu display modifed to state "stop or start recording/playback" depending on whether they are turned on or off. It also displays total minutes remaining or played so far.
* Record/Playback turn off when exiting a game. Boy that sure caused some confusion.
* Switched positioning control of sprites in the skin menu to the left analog stick, that way you don't have to worry about unintentionally lowering the volume.
* Savestate load screen is a little more informational when sent to it from the save/record option.
* When you save a picture it removes the screenshot save path making it easier to see long names.
* Changed order of some of the entries in the "Music Control Menu".
* Playlist repeat mode, and View Name setting is saved in INI file. Although song name only shows in the music control menu.
* (cheat codes)When "adding a code" from the "edit code" screen the current code is copied as a template.
* You can activate/deactivate a code from the "cheat code list" menu by pressing start.
* Deleting a cheat code now asks you if you are sure (I got tired of accidently deleting my codes ).
* Fixed up the problem created from using multiple files in a Zip file.
* Fixed problem when a filename inside a zip contains too many characters. While I was at it I fixed the space as the last character when trimming to 42 characters behavior. Zip files where the path was saved now unzip correctly.
* Rewind and Fastforward are de-activated during record/playback and netplay mode. It even tells you so when you try!!
* Modified YesNoMenu so it doesn't clear m_menuText.
* Added ability to add in cheat codes from a Gameshark compatible database (see description below). This includes the ability to export the cheat codes in a game to "share" with your friends. Cheat/rumble codes are included for most games. When "adding" codes from the gameshark DB it will move you to the entries with a matching CRC. If not you'll have to manually find the game.
*** "Auto Game Configurations (aka Configuration defaults) for select emulators ***
In the "General settings" menu there will be a new option.
"Automatically Use Default Game Configuration - Yes/No"
If the user sets it to "Yes" it will bring up the game configuration screen and let the user define the default (if no default.stg and default.key file exists).
In the "Configuration" menu there will be a new option... "Set default game configuration"
The user can go in anytime thru the "Configuration" menu to change these "defaults" to something else if they wish.
Once set to "Automatically use Default Game Configuration" the user will not see the game configuration screen again unless they... a) press X when selecting a game. Change "Use Default Game Configuration" back to "No".
Keep in mind when it is set to "Yes" the game will use your "Default game settings" and not the normal x-port behavior. If set to "No" the emulator will behave like it usually does. Each emu is typically different. But all, at the very least carry the controller settings over.
This feature will only be added to emulators in which it is feasible to use.
