Mednafenx-pce - Pce/tg16 Emulator For Xbox V5
3 replies to this topic
#1 Shannon OFFLINE
Shannon
    Born To Be Insane
  • 7,846 posts
  • Pac-man Fever
Posted Tue Apr 27, 2010 3:59 AM
MednafenX-PCE - PCE/TG16 Emulator for XBox v5
http://xport.xbox-scene.com
goto http://www.ressurectionxtras.net/ for latest cheats, rumbles, synopsis and skin updates.
*** Changes To MednafenX_PCE Core ***
* Given the full "Madmab Edition" treatment.
* New dual-preview skin to support Ressurection Xtra's. Say thank you to Gilou9999 for the skin.
* "Auto Game Configurations (aka Configuration defaults)" added (see below description).
* Fixed an issue where the screen was not displaying correctly in Mednafen_PCE when in debug mode.
* Apparently mp3CDDA and CDDA volume were sharing the volume variable for Mp3music. Created seperate volume variables for each. Mp3CDDA and CDDA volume are saved with each game so you can customize this for CD games.
* CD music volume is now saved with each game. That way the user can better balance the sound in games that use CD audio/music.
* New feature "Seconds before playing movie" determines how long the emu will wait before playing a movie. The default is half a second. This will help speed up rom browsing. Especially useful for people streaming stuff (like movies) across the network.
* If streaming movies from across the network and the user press on the dpad or a, b, x or y the emulator will abort the transfer. This should help speed up rom browsing and allow the user an "out" especially for the larger movies.
* Fixed an issue with the software filters displaying garbage.
* Activated the "Keep user Within ROM Directory Tree?" which I somehow missed.
* Fixed up the box/cart art position on a few skins.
* Fixed a problem where setting the box/cart orientation was screwed up.
* Fixed the bug that screwed up Gilou's skin to begin with (too weird to explain).
*** To Do For MednafenX_PCE ***
- Eh?
*** Interface Related Changes ***
A gazillion changes, read the Latest-Snes9x.txt file.
**** Carryovers from Atarixlbox ****
A gazillion changes carried over from Atarixlbox. Read the Latest-Snes9x.txt file.
*** "Auto Game Configurations (aka Configuration defaults) for select emulators ***
In the "General settings" menu there will be a new option.
"Automatically Use Default Game Configuration - Yes/No"
If the user sets it to "Yes" it will bring up the game configuration screen and let the user define the default (if no default.stg and default.key file exists).
In the "Configuration" menu there will be a new option... "Set default game configuration"
The user can go in anytime thru the "Configuration" menu to change these "defaults" to something else if they wish.
Once set to "Automatically use Default Game Configuration" the user will not see the game configuration screen again unless they... a) press X when selecting a game. Change "Use Default Game Configuration" back to "No".
Keep in mind when it is set to "Yes" the game will use your "Default game settings" and not the normal x-port behavior. If set to "No" the emulator will behave like it usually does. Each emu is typically different. But all, at the very least carry the controller settings over.
This feature will only be added to emulators in which it is feasible to use.
#2 108 Stars OFFLINE
108 Stars
  • 2,277 posts
Posted Wed Nov 3, 2010 3:39 AM
Not sure if this is the right place to post, but I have no idea where else to post about emulator troubles. So since the threads are not locked IŽll just post in the threads for each emulator. :)
Mednafenx-pce is great, but it failed to load one game for me: Might and Magic III, the US-version. I tried the US and japanese cue-sheet, but it wonŽt load.
#3 Shannon OFFLINE
Shannon
    Born To Be Insane
  • 7,846 posts
  • Pac-man Fever
Posted Thu Nov 4, 2010 2:40 AM
Hmm... I'm not sure what to say.. RessX has it listed as working on the compabitility sheet. But I don't see any comments regarding special settings or anything. I didn't get much chance either to play around with the CD based games.
#4 108 Stars OFFLINE
108 Stars
  • 2,277 posts
Posted Thu Nov 4, 2010 4:37 AM
I will check the files again, this time on PC. Maybe they are just bad. Or maybe I did something wrong when I renamed them so I could FTP them over to the Xbox. Is it just the displayed filenames of .cue and .bin that have to match or do I need to edit something else?
I was looking at this specific version of the game because the SNES version is censored and cut, while the Mega Drive version is uncensored and complete, but has a terrible problem recognizing button presses.
