RAM 320XL
619 replies to this topic
Poll: RAM 320XL (174 member(s) have cast votes)
I'm interested in:
  1. RAM 320XL naked version (24 votes [9.96%])
    Percentage of vote: 9.96%
  2. RAM 320XL full version (111 votes [46.06%])
    Percentage of vote: 46.06%
  3. RAM 320XE (54 votes [22.41%])
    Percentage of vote: 22.41%
  4. RAM 576+ (52 votes [21.58%])
    Percentage of vote: 21.58%
Vote Guests cannot vote
#601 BuzzBrain OFFLINE
BuzzBrain
    Combat Commando
  • 3 posts
Posted Thu Dec 17, 2015 6:19 AM
Hmm I voted for full 320XL full version as I have a 800XL I want to upgrade.
But when I think about it. I would love to have a internal ram upgrade. So any just a internal one.Then I can have the cart port free :)
Some soldering is okey for me.
#602 David_P OFFLINE
David_P
    Dragonstomper
  • 935 posts
Posted Thu Dec 17, 2015 1:20 PM
The 320xl connects to the PBI port, not the cart port.
#603 BuzzBrain OFFLINE
BuzzBrain
    Combat Commando
  • 3 posts
Posted Thu Dec 17, 2015 7:35 PM
Ah. Thanks for the information. I´m noob on Atari. But learning every day :) But still. I think I want a internal  ram solution.
#604 Ripdubski OFFLINE
Ripdubski
  • 1,307 posts
Posted Thu Mar 24, 2016 5:20 PM
Any updates?  When can we get a batch of 320XL's?
#605 brenski OFFLINE
brenski
  • 1,841 posts
  • How should we f**k off, oh Lord ?
Posted Tue Mar 29, 2016 8:34 AM
it's almost ready - from what i hear,
glad i got in early with this one, as it could have a lot of demand   :)
#606 xrbrevin OFFLINE
xrbrevin
    Moonsweeper
  • 366 posts
  • Mr Ziggy loves to extend the 1050 heatsink!
Posted Thu Apr 14, 2016 5:40 AM
I am interested in a 320xl full version :)
#607 tep392 OFFLINE
tep392
  • 3,111 posts
Posted Thu Apr 14, 2016 10:29 AM
I would like a full 320XL if it's not too late.
#608 Dmitry OFFLINE
Dmitry
    Chopper Commander
  • 240 posts
Posted Thu Apr 14, 2016 11:20 AM
If this is an interest thread, please put me down for 1 as well.
#609 plyr0 OFFLINE
plyr0
    Combat Commando
  • 5 posts
Posted Thu Apr 14, 2016 1:27 PM
I had voted for full 320XL, if I could have one.
#610 Marius OFFLINE
Marius
  • 4,830 posts
Posted Fri Apr 15, 2016 2:25 AM
You also could go for the new remake of the Turbo Freezer (see other thread). This one gives you also XE compatible memory expansion, and it is battery back upped, and a lot more features which are excellent.
My main Atari is a stock 800XL (well ok I did a small mod to add +5v to the pbi, but that is needed with other expansions too) and the Turbo Freezer. I can run anything on this.
#611 rockdoc2010 OFFLINE
rockdoc2010
    Chopper Commander
  • 176 posts
  • working swings,
Posted Tue Apr 19, 2016 5:07 PM
RAM 320XL is a external plug and play 320kB memory expansion card for 600XL and 800XL machines.
Additionally there is a possibility to disable internal memory and remap it onto card (switchable via jumper), thus one can "fix" many failing XLs without even looking inside.
Also, an unexpanded 16kB 600XLs can be upgraded to 320XL without any additional work.
RAM 320XL uses banking via bits 2,3,5,6 and 4 of PORTB. As you can see this is compatible with "Atari magazine" expansion rather than a most common RAMBO or Compy shop setup, however I have to say the comaptibility with both old and new software is excellent. There can be only problem with some programs, which does use the separate Antic/CPU banking. If you want to test any particular program, let me know.
Installation is easy. 600XL users will just plug it into PBI port. For 800XL is a bit more complicated, because Atari decided to remove 5V power from the PBI connector from it. Thus 800XL users will have either to use additional power cable which will fit into joystick port or solder one wire inside atari to make the PBI port powered like on 600XL.
The estimated price is between 20-30€ + postage. There will be probably two versions. A cheaper "naked" one and the more expensive with enclosure and power cable.
The availability is unknown, but I believe I can prepare a first batch in a month or so.
The future:
RAM 320XE - external plug and play 320kB RAM upgrade for all XE machines with EXP port. The basic parametres will be the same as the RAM 320XL plus possibility to switch into 100% compatible 130XE mode with separate ANTIC/CPU banks.
RAM 576+ - Internal RAM 576kB and beyond which will require very little and simple soldering. Universal PCB for XL/XE/XEGS. Compatible with 130XE/RAMBO/COMPY/Atari magazine modes (switchable).
Gallery:
Development:
First prototype:
Here you can see one of the protopytes in 600XL on the krupkaj's pages:
RAM 320XL in 600XL 1
RAM 320XL in 600XL 2
 thats an 800XL?!?
#612 iesposta OFFLINE
iesposta
  • 3,903 posts
  • Retro-gaming w/my VCS
Posted Tue Apr 19, 2016 6:12 PM
 thats an 800XL?!?
Picture 1 & 2, everything without wires below the cartridge port, is an 800XL.
Just a 2 year older updated Atari 2600 with a full 6502 not the "half of a 6502 - the 6507", actual ram chips, a video chip, and a proper sound chip (not just a noise oscillator).
Nice late 1970's design.
#613 jum OFFLINE
jum
    Chopper Commander
  • 126 posts
Posted Wed Jul 13, 2016 7:23 AM
Hi. Voted for 320XL full version. Would love one for my 600XL.
#614 Larry OFFLINE
Larry
  • 4,099 posts
Posted Wed Jul 13, 2016 7:36 AM
We have not had any updates on the new version in awhile.  The older version was sold out a long time ago.  I think that you are likely to be waiting for a long, long while! (Unless you find a used one to purchase.)
You might instead want to consider an Antonia 4 MB upgrade.  It is a better upgrade (IMO), and has flashable OS and Basic slots.  It does require that you open your Atari up, but virtually all 600XL's are socketed, so there are no troublesome issues installing one.  Depending on what you plan to use for a display, you might consider an Ultimate Atari Video (UAV).  Also quite easy to install and gives superb video. Do those two upgrades, and you will have a SOTA ;) retro Atari.
Capetown S.A.?  I've never seen anyone here from S.A.  Welcome!
-Larry
#615 ctirad OFFLINE
ctirad
    Moonsweeper
  • 306 posts
Posted Wed Jul 13, 2016 7:44 AM
The RAM 576XL is finished, but unfortunately I have no time to start a mass production :(
#616 Philsan OFFLINE
Philsan
  • 3,854 posts
  • New Orleans Saints Super Bowl XLIV Champions
Posted Wed Jul 13, 2016 1:07 PM
:_(  :_(  :_(
I hope you'll soon have plenty of time!
Meanwhile, could you please describe RAM 576XL features?
#617 kogden OFFLINE
kogden
    Dragonstomper
  • 636 posts
Posted Wed Jul 13, 2016 11:45 PM
I have a cased RAM320XL from the older run that I'm not using since I have some actual PBI devices now.  Shipping charges would be brutal outside of the US though.
If the new version has PBI pass-through that would be pretty sweet.
#618 ctirad OFFLINE
ctirad
    Moonsweeper
  • 306 posts
Posted Thu Jul 28, 2016 10:39 AM
Just a basic 576kB or 320KB with remapped base RAM (useful mainly for 16kB 600XL machines).
Due to fact, the PBI port lacks /HALT signal needed for separate CPU/ANTIC makes, there was no reason to bother with a true 130XE and COMPY modes.
#619 Molloch OFFLINE
Molloch
    Combat Commando
  • 3 posts
Posted Fri Aug 5, 2016 10:13 AM
Hello, voted for 320XL, but willing to purchase 320XL or 576XL.  I know that this is in high demand, so I also posted over in marketplace in case anyone is willing to part with one.  These are amazing devices, kudos to your talent :).
#620 @ircular logic OFFLINE
@ircular logic
    Combat Commando
  • 9 posts
Posted Thu Nov 9, 2017 1:27 PM
We're all still interested!
