DIY modifications for ColecoVision
54 replies to this topic
#51 Yurkie OFFLINE
Yurkie
    Q*bert Champion
  • 4,073 posts
  • US Distributor for NESRGB and 2600RGB
Posted Wed Feb 19, 2014 11:47 AM
My DIY composite mod is $29 shipped in the USA and comes with cord. Info in my marketplace thread.
http://atariage.com/...-pause-mod-led/
You get the module and the cord. Solder 4 wires in place, drill one hole and trim a little metal on the shielding. PDF Instructions link in my Marketplace thread linked above.
#52 parkfun101 OFFLINE
parkfun101
    Chopper Commander
  • 243 posts
Posted Sun Apr 6, 2014 8:26 AM
Pause Mod: :)  The easiest way to view the image is click on it and then save the image to your desktop and then open it with a picture editor.  This site doesn't seem to let you display images at their full size.
http://atariage.com/...se-mod-example/
Also, note there is more than just 1 place you could solder the Audio Out line to in the link above.  This is just 1 way to do it.
This is for options of locations on the board for where you can do the line for the Pause "Wait" portion of the mod:
http://atariage.com/...cation-options/
If anyone has an easier way to do this, please post.
#53 jesusc OFFLINE
jesusc
    Dragonstomper
  • 648 posts
Posted Thu Aug 21, 2014 9:33 AM
I have 3 colecovisions which all have some sort of issue. I decided I'd sacrifice the worst looking one and try to do a composite AV mod (as well as power switch cleaning). I grabbed 5-11 under's instructions and went to Radio Shack.
Grabbed the potentiometer and transistor no problem, but didn't know which resistor to get. They come in various wattages and I didn't know which watt I should get.
Help?
#54 5-11under OFFLINE
5-11under
  • 3,396 posts
Posted Thu Aug 21, 2014 9:50 AM
Help?
1/4 Watt (or anything higher, such as 1/2 or 1 Watt, etc.) will be good.
Also, if you need to substitute parts, there's equations online for that (to double the resistance value, put two the same in series; to halve the resistance value, put two the same in parallel).
#55 jesusc OFFLINE
jesusc
    Dragonstomper
  • 648 posts
Posted Thu Aug 21, 2014 11:36 AM
thanks!
