Can we change background color behind the score?
7 replies to this topic
#1 Random Terrain OFFLINE
Random Terrain
    Visual batari Basic User
  • 26,939 posts
  • Controlled Randomness
    Replay Value
    Nonlinear
Posted Sun Aug 29, 2010 8:35 AM
If we use pfcolors and background, we can change the background color strip behind the score, but that's not helpful if you want to use pfcolors to color rows of playfield pixels.
Is there any way to 'hack' bB so that only the strip where the score is can have a different background color from the rest of the screen and have it still be compatible with pfcolors?
Thanks.
Edited by Random Terrain, Wed Sep 8, 2010 2:03 AM.
#2 RevEng ONLINE
RevEng
  • 3,842 posts
  • Bitnik
Posted Sun Aug 29, 2010 11:06 AM
Try adding this to your last bank...
        asm
minikernel
        sta WSYNC
        lda scback
        sta COLUBK
        rts
end
Then in your bB code...
       rem to set a constant score background color do this...
       const scback=#$28
       rem to assign a variable to the score background color do this...
       dim scback=z
       scback=$28
The margin of color above the score is a bit larger than the margin below, due to the bB score setup, but I believe it's the best you can do without modifying the score assembly itself.
#3 Random Terrain OFFLINE
Random Terrain
  • 26,939 posts
    Replay Value
    Nonlinear
Posted Sun Aug 29, 2010 11:38 AM
        asm
minikernel
        sta WSYNC
        lda scback
        sta COLUBK
        rts
end
       const scback=$28
       dim scback=z
       scback=$28
It works great as long as I use COLUBK in the main loop to tell the program what color the rest of the background should be. The margin difference isn't a big deal. I'm just glad that I can have a different background color down there.
Thanks.
#4 RevEng ONLINE
RevEng
  • 3,842 posts
  • Bitnik
Posted Sun Aug 29, 2010 12:48 PM
...It works great as long as I use COLUBK in the main loop to tell the program what color the rest of the background should be...
Good point! I had that in my quick proof-of-concept, but I forgot to mention it in my post.
And you're welcome!
#5 atari2600land OFFLINE
atari2600land
    I should be a myrmecologist.
  • 9,473 posts
  • Shwam.
Posted Wed Oct 6, 2010 6:41 PM
I tried this and I got this as the result:
2600basic_variable_redefs.h (5): error: EQU: Value mismatch.
old value: $00f0 new value: $00cc
default.bas.asm (1228): error: Illegal Addressing mode 'sta #scback'.
bytes of ROM space left
2600basic_variable_redefs.h (3): error: EQU: Value mismatch.
old value: $00cc new value: $00f0
--> cycle74_HMCLR f07b
2600 Basic compilation Failed!
What the heck am I doing wrong here?
#6 Omegamatrix OFFLINE
Omegamatrix
  • 5,991 posts
Posted Wed Oct 6, 2010 6:50 PM
You're using scback as both a constant and a variable. Look at RT's post again. You're supposed to choose one or the other, but not both.
#7 atari2600land OFFLINE
atari2600land
  • 9,473 posts
  • Shwam.
Posted Wed Oct 6, 2010 6:53 PM
OK, that did it. Sorry. :dunce:
#8 Random Terrain OFFLINE
Random Terrain
  • 26,939 posts
    Replay Value
    Nonlinear
Posted Wed Oct 6, 2010 7:10 PM
This has been on the bB page for a while, but I just added a direct link to it:
http://www.randomter...nds.html#scback
