my atari 8bit online channel
48 replies to this topic
#26 ProWizard ONLINE
ProWizard
  • 4,017 posts
  • Into Stampede
Posted Mon Aug 30, 2010 1:29 PM
I have had this problem once... with building a sio2ide...
Now I remember.
After getting to the point I was pulling my hair out, I found out the Firmware file I was using was broke.
After getting a fresh firmware, everything worked fine...
#27 flashjazzcat ONLINE
flashjazzcat
  • 10,686 posts
Posted Mon Aug 30, 2010 1:35 PM
Now I remember.
I sent him two. Surely they're not both stuffed.
#28 flashjazzcat ONLINE
flashjazzcat
  • 10,686 posts
Posted Mon Aug 30, 2010 2:08 PM
Right - it's working. :)
That's me done for the night...
#29 w1k ONLINE
w1k
  • 1,521 posts
Posted Mon Aug 30, 2010 2:14 PM
You watched the live programming sio2sd chip. the longer punished it finally succeeded thanks to flashjazzcat. i will be continuited with live broadcast, thank you for watching and support, good night :)
and pepax - dont joking, thats was serious problem man
#30 pepax OFFLINE
pepax
    Moonsweeper
  • 305 posts
Posted Mon Aug 30, 2010 10:35 PM
Of course it was.
#31 ProWizard ONLINE
ProWizard
  • 4,017 posts
  • Into Stampede
Posted Tue Aug 31, 2010 1:29 AM
So please tell us what the problem was! Fuse settings?
And a bit offtopic:
Your 800xe looks pretty cool with that sio2sd build-in. But... I have to say: it would not be my choice. I want peripherals being as mobile as possible, AND I don't want to change the looks of my Atari computers. Switches at the backside: ok... but that's it.
But I admire your nice work. It looked very impressive!
Greetz
Marius
#32 flashjazzcat ONLINE
flashjazzcat
  • 10,686 posts
Posted Tue Aug 31, 2010 3:30 AM
If I may jump in: I obtained yet a third BIN file and set up my own AVR programmer and flashed an SIO2SD. I then sent this known 100% guaranteed to work BIN file to w1k. I'm unsure whether he used it or not, but I think he was also trying to load BIN files as HEX files and messing around unnecessarily in the lower (EEPROM) buffer window. Once these misunderstandings were resolved, the process worked.
#33 ProWizard ONLINE
ProWizard
  • 4,017 posts
  • Into Stampede
Posted Tue Aug 31, 2010 4:30 AM
Cool that it worked out. So there was indeed a certain similarity with my problem with Sio2IDE. It is very frustrating when it happens. I hope w1k wrote down the right steps in case he need to do it again.
So please back to my earlier question (I did not understand the answer). Is this a problem which happens a lot with sio2sd? Or with every interface with an Atmel?
I don't have these troubles with my Sio2IDE or Sio2USB, so I was wondering: why is this happening with sio2sd, or is it just this one w1k has?
Thanks
Marius
#34 flashjazzcat ONLINE
flashjazzcat
  • 10,686 posts
Posted Tue Aug 31, 2010 6:10 AM
The correct steps which I follow are:
  • Connect interface cable, power on Atari
  • Run AVRprgWin as Admin
  • Calibrate cable (power off Atari, then power up again)
  • Load BIN file into flash (top) buffer and write to chip
  • Set fuse bits (L=FF, H=D1)
That's it. Release and disconnect the cable and all should be well. You get the occasional write error but it should be OK after a couple of goes. I've never had any reason to touch the EEPROM (lower) window.
I don't know if the Atmel problem is common to all devices which use this chip. I very much suppose it depends on the design of the circuit. 99 per cent of the time, a dead chip is discovered immediately after hotplugging the device with the Atari switched on. As I understand it, the problem is caused by +5 travelling through the circuit before the ground pin is connected. The fuse bits are supposed to combat this problem but I haven't found the situation to be entirely preventable. I made an attempt to safeguard against ungrounded power ups by modifying the female molex connector on the last batch of devices, bending the +5v spring metal conact back by 2mm or so. The idea is that it will always be the last contact to make a connection.
Edited by flashjazzcat, Tue Aug 31, 2010 6:10 AM.
#35 w1k ONLINE
w1k
  • 1,521 posts
Posted Tue Aug 31, 2010 6:24 AM
I was having problems, after i use firmware 2.5 and tool SYSINFO
tonight, i will be again online - i want more learn dli, pmg, etc
#36 sloopy OFFLINE
sloopy
  • 2,401 posts
  • lookin for bits, i like bits...
Posted Tue Aug 31, 2010 6:38 AM
damn i missed it, wish i could have seen it live...
sloopy.
#37 w1k ONLINE
w1k
  • 1,521 posts
Posted Tue Aug 31, 2010 9:39 AM
online live stream now
#38 w1k ONLINE
w1k
  • 1,521 posts
Posted Wed Sep 1, 2010 8:45 AM
atomic bomberman live :)
17:19 - off
Edited by w1k, Wed Sep 1, 2010 9:19 AM.
#39 w1k ONLINE
w1k
  • 1,521 posts
Posted Sat Mar 19, 2011 10:04 AM
back online
http://www.ustream.t...nnel/atari800xe
#40 Blues76 OFFLINE
Blues76
    Moonsweeper
  • 260 posts
Posted Sat Mar 19, 2011 11:49 AM
I'm sorry, but the broadcast will be moved to tomorrow :(
still watching :)
what a mess!!!!
#41 w1k ONLINE
w1k
  • 1,521 posts
Posted Fri Apr 8, 2011 11:30 AM
im online, because we have warning about big wind (20-40m/s)
Posted Image
#42 w1k ONLINE
w1k
  • 1,521 posts
Posted Thu Jan 19, 2012 1:01 PM
tommorow i again start online stream, 9:00am central europe time
program: one guy give me cassettes with interesting software, so i want save it to PC (600baud/t2000 to .xex)
Edited by w1k, Thu Jan 19, 2012 1:08 PM.
#43 w1k ONLINE
w1k
  • 1,521 posts
Posted Fri Jan 20, 2012 2:05 AM
no stream today.. my PC is death
#44 w1k ONLINE
w1k
  • 1,521 posts
Posted Mon Feb 20, 2012 3:22 AM
live: unpacking new box - i dont know what is it :)
-----offline now:
video from live broad:
http://www.ustream.t...corded/20577942
next: soon - saving atari soft from tape to sio2sd
Edited by w1k, Mon Feb 20, 2012 3:44 AM.
#45 w1k ONLINE
w1k
  • 1,521 posts
Posted Fri Feb 24, 2012 4:33 AM
today 13:00 central EU time LIVE
copying soft from tapes via sio2sd to PC
#46 Rybags ONLINE
Rybags
  • 13,912 posts
Posted Fri Feb 24, 2012 4:51 AM
PMSL. That'd be as much fun as watching paint dry.
#47 w1k ONLINE
w1k
  • 1,521 posts
Posted Sun Jun 3, 2012 12:43 AM
again online
#48 sloopy OFFLINE
sloopy
  • 2,401 posts
Posted Sun Jun 3, 2012 1:04 AM
and because i watched your stream, I doubled your viewership... you had 1 (me), plus the two watching me...
congrats!
sloopy.
#49 w1k ONLINE
w1k
  • 1,521 posts
Posted Mon Mar 25, 2013 8:43 AM
back online :)
http://www.webcam.podstromami.com/
refresh - 5s
www.webcam.podstromami.com/image.jpg
