Zoyx Posted September 5, 2010 Share Posted September 5, 2010 I just fired up my CV for the first time in over a year, and it now has diagonal lines and snow. Any tips to fix this? I attached an Atari 7800 to the same TV, using the same video cable and RF adapter, and a much better picture. So the hookups don't seem to be the problem. Should I just go straight to an A/V mod? If so, which is best? Quote Link to comment Share on other sites More sharing options...
retroillucid Posted September 5, 2010 Share Posted September 5, 2010 (edited) You can contact 5-11under here, he sell A/V Mod kit There's also Yurkie who can provide refurbished system or refurbish your system,controllers He can A/V mod your system too BTW: The problem could be your Power Supply too Edited September 5, 2010 by retroillucid Quote Link to comment Share on other sites More sharing options...
Zoyx Posted September 5, 2010 Author Share Posted September 5, 2010 Power switch may be the problem. I now remember when I first got this system 3 years ago, games weren't running properly. I opened it up, and sprayed control/contact cleaner/lub into the on/off switch, and that fixed things enough so it was playable. I should probably do a more permanent fix this time around. Quote Link to comment Share on other sites More sharing options...
Zoyx Posted September 5, 2010 Author Share Posted September 5, 2010 Definitely a power issue. Sprayed the on/off switch like I did a few years back, and it is playable. Not ideal, but playable. Still should do the A/V mod and permanently fix the power issue. Quote Link to comment Share on other sites More sharing options...
+Yurkie Posted September 6, 2010 Share Posted September 6, 2010 Definitely a power issue. Sprayed the on/off switch like I did a few years back, and it is playable. Not ideal, but playable. Still should do the A/V mod and permanently fix the power issue. The power switch needs to be desoldered from the board, dissembled and cleaned. As tightly concealed as the contacts are, I find it amazing that any contact cleaner could get inside the switch. I offer repair and mods. Send me an IM if your interested. There is a link in my signature to my Youtube video showing my mods. Quote Link to comment Share on other sites More sharing options...
+5-11under Posted September 6, 2010 Share Posted September 6, 2010 If you want to tackle this yourself... http://www.atariage.com/forums/topic/163446-diy-modifications-for-colecovision/page__view__findpost__p__2019087 Quote Link to comment Share on other sites More sharing options...
Zoyx Posted September 7, 2010 Author Share Posted September 7, 2010 (edited) Thanks for the replies. My Colecovision is working quite well now, so I will be slow in making any decision. In the "I'm a retard" dept. ... part of the problem was that I had a PC close to the TV/monitor, which was causing some interference. Move the computer, PRESTO! ... I now have a nearly perfect picture. I believe blasting the power switch helped a bit as well. Edited September 7, 2010 by Zoyx Quote Link to comment Share on other sites More sharing options...
Charlie_ Posted September 10, 2010 Share Posted September 10, 2010 Definitely a power issue. Sprayed the on/off switch like I did a few years back, and it is playable. Not ideal, but playable. Still should do the A/V mod and permanently fix the power issue. The power switch needs to be desoldered from the board, dissembled and cleaned. As tightly concealed as the contacts are, I find it amazing that any contact cleaner could get inside the switch. I offer repair and mods. Send me an IM if your interested. There is a link in my signature to my Youtube video showing my mods. I believe what your saying 100%. If mine gives me trouble again I will take your advise and disassemble the switch. However a guy from work gave me a Colecovision he had in his attic for many years. The power switch didnt work so i took the system apart, removed the board and sprayed the hell out of the switch with Tuner cleaner from Radio Shack. Its been working well for a couple years now. Only thing I hate about that spray is that its so greasy. If you have any over-spray its hard to clean up. Quote Link to comment Share on other sites More sharing options...
