F18A
878 replies to this topic
#851 broettger OFFLINE
broettger
    Star Raider
  • 54 posts
Posted Thu Mar 22, 2018 10:27 PM
Does anyone know if he is still making the F18A? I went to his website and it hasn't even had a blog post in a long time.
#852 Lee Stewart ONLINE
Lee Stewart
  • 3,991 posts
Posted Fri Mar 23, 2018 9:13 AM
“He” (matthew180) is regularly on this forum.  If you go to his store (top, left menu) on his website and select the F18A, you will see where you can be added to the pre-order list.  When he gets enough pre-orders, he will make a run of F18As.  As of last October, he was 70 % there.
...lee
#853 broettger OFFLINE
broettger
    Star Raider
  • 54 posts
Posted Fri Mar 23, 2018 9:20 AM
Thanks. I added my name to the list.
#854 matthew180 OFFLINE
matthew180
  • 2,632 posts
Posted Fri Mar 23, 2018 11:54 AM
Yes, I'm still working on getting more made.  Sorry for the delay.  Life, work, etc. blah blah blah, (insert normal excuses here).    Anyone on the contact list will get an email when the next batch is available.
Edited by matthew180, Fri Mar 23, 2018 11:55 AM.
#855 digress ONLINE
digress
  • 1,149 posts
Posted Wed Apr 25, 2018 2:35 PM
Yes and to help promote more I might attempt to make commando using f18a for the colecovision. I think it's possible.
You gave me a bit of machine code to scroll the tiles left and right after the the register scroll reaches 7 and resets. Could we expand this to do up & down as well?
were having a discussion on whether this is possible here:
http://atariage.com/...ovision-debate/
Edited by digress, Wed Apr 25, 2018 2:36 PM.
#856 Asmusr OFFLINE
Asmusr
  • 3,149 posts
Posted Wed Apr 25, 2018 2:58 PM
It should be possible to make a great version of Commando using the F18A.
Set the least significant bit of VR29, that will give you two vertical pages to scroll through. Then set the scrolll offset in VR28.
For creating the bridge it is possible to set some tiles to take priority over sprites, to allow the player to move under to bridge. That could also be used for moving behind boulders etc.
Edited by Asmusr, Wed Apr 25, 2018 3:24 PM.
#857 OLD CS1 OFFLINE
OLD CS1
    >OLD CS1█
  • 6,176 posts
  • Technology Samurai
Posted Wed Apr 25, 2018 3:06 PM
Are we talking Commando for the ColecoVision or the TI?  I am definitely down for the latter.
#858 Asmusr OFFLINE
Asmusr
  • 3,149 posts
Posted Wed Apr 25, 2018 3:28 PM
Did you see this? A great version of the music for our PSG.
http://atariage.com/...n/#entry3996953
I might try to get the music to play on the TI.
#859 OLD CS1 OFFLINE
OLD CS1
    >OLD CS1█
  • 6,176 posts
Posted Wed Apr 25, 2018 3:56 PM
Holy cow, WTF!  Should be easy enough to capture into a VGM.  Reminds me I have not been to VGMRips in a while.
#860 matthew180 OFFLINE
matthew180
  • 2,632 posts
Posted Wed Apr 25, 2018 10:38 PM
Sure, vertical scrolling can be done a few ways.  Rasmus<<1 already pointed out one way, i.e. you can use two name tables and enable using two vertical pages for scrolling.  The second name table provides the data that is scrolled "in".  If you don't use the second name table, then you need to mask the bottom row and update a new row of data every 8 pixels (similar to what is going on with the horizontal scrolling).
Once you have more details about how you want to set up the screen and doing the scrolling, I would be happy to provide you some GPU routines to help with managing the VRAM data for the scrolling.
#861 Davidb OFFLINE
Davidb
    Space Invader
  • 10 posts
Posted Sun May 13, 2018 4:15 AM
The F18A is a very impressive project. I'm glad it's had interest across several systems.
I was wondering, is it possible to achieve a 16 colour mode in any form at all?
Edited by Davidb, Sun May 13, 2018 6:04 AM.
#862 Asmusr OFFLINE
Asmusr
  • 3,149 posts
Posted Sun May 13, 2018 6:00 AM
The F18A is a very impressive project. I'm glad it's had interest across several systems?
There are many ways to get 16 colors and more on the screen. If you need to color each pixel independently then you can use a fat pixel bitmap of 128x192 pixels to cover the whole screen.
#863 Davidb OFFLINE
Davidb
    Space Invader
  • 10 posts
Posted Sun May 13, 2018 6:03 AM
Thank youThat's good to know. Would 256x192 be possible at all?
#864 Asmusr OFFLINE
Asmusr
  • 3,149 posts
Posted Sun May 13, 2018 7:22 AM
A bitmap of 256x192 in 16 colors would require 24K and the F18A only has 18K. You can have 256x192 in 4 colors, or you can use tiles/characters where each of the 256 8x8 tiles can have up to 8 colors from one of 8 palettes. You can also change the palette for each scanline while the screen is drawn. In combination with the old (9918A) bitmap mode this can give some amazing results with far more than 16 colors. Sprites can also be used to add more color.
#865 matthew180 OFFLINE
matthew180
  • 2,632 posts
Posted Sun May 13, 2018 4:04 PM
Unfortunately a true 256x192 pixel-addressable display with 16-colors per pixel requires more VRAM (24K) than is available (16K), as Asmusr mentioned.
To elaborate a little, the F18A provides a feature called the "bitmap layer" (or BML for short) that allows you to define a pixel-addressable rectangular area that supports 4-colors per pixel.  This way you can have a 256x192 4-color display.
The BML also has a setting called the "fat-pixel" feature, which doubles the size of the pixels in the X-direction, but also gives you 16-colors per pixel.  So using this feature you could have a 128x192 16-color display.
Also, the BML is in addition to the normal tiles and sprites (you could think of the BML as a big configurable sprite).  Both the 256x192 4-color and 128x192 16-color BML would take up 12K of VRAM.
The BML can be any size you want, from 1x1 pixel to the full screen.  You can also set the BML location anywhere you want on the screen.
Edit: corrected BML fat-pixel size information.
Edited by matthew180, Mon May 14, 2018 1:06 AM.
#866 Davidb OFFLINE
Davidb
    Space Invader
  • 10 posts
Posted Sun May 13, 2018 4:18 PM
Thank you - that does make sense. It certainly makes very good use of the available memory however.
It's a shame that it's not possible to run two in conjuction :)
#867 Asmusr OFFLINE
Asmusr
  • 3,149 posts
Posted Sun May 13, 2018 11:32 PM
So using this feature you could have a 128x96 16-color display.
Only the pixel width is doubled, so it's 128x192, right?
#868 matthew180 OFFLINE
matthew180
  • 2,632 posts
Posted Mon May 14, 2018 1:07 AM
You are correct, it only changes the X-size.  I have corrected my previous post.  Thanks for catching that.
#869 ppj34 OFFLINE
ppj34
    Combat Commando
  • 2 posts
Posted Tue Nov 6, 2018 2:16 AM
Hello,
I have a tomy tutor and I read that your video card is compatible with this machine. The video rendering would be much better (than composite video output on the tomy).
Can I order a card if it's still available?
If so, I live in France and I would have to pay extra shipping costs.
Thanks
#870 arcadeshopper OFFLINE
arcadeshopper
  • 4,411 posts
Posted Tue Nov 6, 2018 3:32 PM
Hello,
Thanks
They are not currently available. If you read this thread.. you will see what the status is.
#871 matthew180 OFFLINE
matthew180
  • 2,632 posts
Posted Tue Nov 6, 2018 10:24 PM
Sadly I do not have any F18As right now, and the MK2 is held up due to a video output dilemma.  I'm working on getting something worked out as quickly as I can.
#872 ppj34 OFFLINE
ppj34
    Combat Commando
  • 2 posts
Posted Wed Nov 7, 2018 1:02 AM
Ok. Thanks.
Notify me if you find a solution. I am always interested (and not in a hurry either) :-)
Edited by ppj34, Wed Nov 7, 2018 1:02 AM.
#873 Schmitzi OFFLINE
Schmitzi
  • 4,538 posts
  • ToXiC
Posted Wed Dec 19, 2018 10:18 AM
Hi,
I have mounted 3 x F18A´s now (into EU/PAL-Consoles), but I cannot use the systems anymore,
or just in a very restricted way, as there is no sound on the Samsung 19" monitor.
I already had this problem at the last meeting in Germany.
Is anybody out there who can assemble & ship me 3 of this cables DIN/PAL-to-SCA-Cinch/Sound ?
Of course, I would pay for everything
(I am NOT able to solder, as all past tries destroyed any candidates/hardwares that I touched)
thanks
xXx
#874 globeron OFFLINE
globeron
    Dragonstomper
  • 850 posts
Posted Mon Dec 31, 2018 3:02 AM
Hi,
thanks
xXx
I use a standard DIN 5-pin cable (USA), see pictures, but I remember having a DIN-6 pin (EU) as well with 4x cinch connectors and used that for sound. And use the converters to the smaller 3.5mm plug for Speakers or into a monitor. No soldering required.9f2d73c15407bf16c8230439725727a5.jpg6e217c06b86844d707f9f1582b1a3902.jpg8066911b46722d97ce9ce669a381b8c0.jpg
Sent from my VIE-L29 using Tapatalk
#875 globeron OFFLINE
globeron
    Dragonstomper
  • 850 posts
Posted Mon Dec 31, 2018 3:12 AM
Hi,
thanks
xXx
Maybe it is your monitor/TV, have you tried other speakers? You only need 1 wire into Audio (Pin 5 for EU or Pin 3 for US) and 1 wire into GND/Common (middle for EU, or pin 2 for US).
The only thing you need to be aware is how do you look to the Pins on the plug (inside out or outside in, otherwise they are "mirrored")25ad762626563f2acc293683cdd2397b.jpg1ee0c9650f35440184e90f508b61aece.jpgcf743839344bd3c9fe15cc77c6b36fe7.jpg14581882f8b6ed8db1588a5d53001b17.jpg4ff3c5cd7db04d5333cb241e98624e4e.jpg
