thund3r Posted October 14, 2010 Share Posted October 14, 2010 (edited) Hi all, i reciently purchased a brand new memory track but when i put the cart in and start up the jag, the cd spins and i hear it load but all i get is a black screen. The cart slot on it works fine, and i even see the jaguar logo when it starts, but then it just hangs. Anyone know why this is? Edited October 14, 2010 by thund3r Quote Link to comment Share on other sites More sharing options...
The_Laird Posted October 14, 2010 Share Posted October 14, 2010 As far as I am aware the memory track dosn't do anything plugged in on its own, well mine dosn't anyway. Don't have any problems saving to it though and don't worry about running out of space as there isn't enough Jag CD games made to run out of space!!! Quote Link to comment Share on other sites More sharing options...
thund3r Posted October 14, 2010 Author Share Posted October 14, 2010 As far as I am aware the memory track dosn't do anything plugged in on its own, well mine dosn't anyway. Don't have any problems saving to it though and don't worry about running out of space as there isn't enough Jag CD games made to run out of space!!! Just yanked out the CD unit and put the cart in the jag and it works fine and shows a Blue Lightning save So the cart works fine, but i have no idea why it doesnt work in conjunction with a CD game... Quote Link to comment Share on other sites More sharing options...
The_Laird Posted October 14, 2010 Share Posted October 14, 2010 Probably just not reading its there, I have had that problem before Quote Link to comment Share on other sites More sharing options...
neo_rg Posted October 14, 2010 Share Posted October 14, 2010 try doing some of these.. self test might be one to try. MEMORY TRACK ------------ Memory Track Manager: Hold Option and turn on Jaguar. Commands: Delete File A/B/C Set Sort Type Option Set Sort & Save 1+Option/3+Option Edit Name/Size 7+9+Option Delete All Files *+#+Option Self Test *+0+#+Option Exit *+# Quote Link to comment Share on other sites More sharing options...
thund3r Posted October 14, 2010 Author Share Posted October 14, 2010 try doing some of these.. self test might be one to try. MEMORY TRACK ------------ Memory Track Manager: Hold Option and turn on Jaguar. Commands: Delete File A/B/C Set Sort Type Option Set Sort & Save 1+Option/3+Option Edit Name/Size 7+9+Option Delete All Files *+#+Option Self Test *+0+#+Option Exit *+# Done the self test and it said everything was ok, and i'm still getting a black screen with it plugged in Quote Link to comment Share on other sites More sharing options...
neo_rg Posted October 14, 2010 Share Posted October 14, 2010 Is the game save on the memory track for the game that won't load correctly. If so then the game save might be corrupt and it's stopping the game from loading, try another CD game and let us know what happens. Also try wiping all the saves from memory track. Quote Link to comment Share on other sites More sharing options...
ovalbugmann Posted October 15, 2010 Share Posted October 15, 2010 (edited) If you got a Blue Lightning save on there, then the BL disc & Memory Track had to work together to do that. Try doing what Neo_rg says - wipe all the data off it. Then power off the Jag. I would then check that the wipe went ok, by inserting the MT in either the base unit or CDunit, hold option, and power on -should be empty now. Power off the Jag. Then try running BL with the MT again. And try some other JagCD games(as was said directly above) that use the MT if you have 'em. Best of luck. Edited October 15, 2010 by ovalbugmann Quote Link to comment Share on other sites More sharing options...
thund3r Posted October 16, 2010 Author Share Posted October 16, 2010 (edited) If you got a Blue Lightning save on there, then the BL disc & Memory Track had to work together to do that. Try doing what Neo_rg says - wipe all the data off it. Then power off the Jag. I would then check that the wipe went ok, by inserting the MT in either the base unit or CDunit, hold option, and power on -should be empty now. Power off the Jag. Then try running BL with the MT again. And try some other JagCD games(as was said directly above) that use the MT if you have 'em. Best of luck. Ok i've given this ago, i've wiped the MT, put blue lightning in and it pops up very briefly stating "writing to memory track" (or something similar) and then a black screen. It does however write it to the MT but still decides to hang on a black screen. One interesting thing to note is that when i put in the Myst demo an error pops up on the screen stating that it cant read from the CD, once i take the MT out and play the demo on its own it loads perfectly. I have tried other games and its the same across all of them. I have no idea whats wrong with this thing, i'm guessing its dud in some way? *edit* Hmmm, well i've just put in Vid Grid and its making noises, which sound like its loading and they happen periodically so my guess is the CD is trying to load the same bit of data to start the game? Edited October 16, 2010 by thund3r Quote Link to comment Share on other sites More sharing options...
mr-atari Posted December 14, 2010 Share Posted December 14, 2010 (edited) Hmmm, I bought a MT (defective) and that has the same issue. Selftest: OK, but black screen on VidGrid. Most likely the memory-chip isn't soldered 100% to the PCB. (I had this problem years ago on a other MT). With a flashlight, you can shine under the chip to see if a pin is not soldered to the PCB. You need a small soldering tip (SMD....) and just press it on. I'll try mine this week and let you know if I can find the problem.... Edited December 14, 2010 by mr-atari Quote Link to comment Share on other sites More sharing options...
mr-atari Posted December 15, 2010 Share Posted December 15, 2010 Ok, here is my finding. Cartridge now works btw :-) The eeprom was correctly soldered to the PCB, so I examined the rest closely. Here I found a drop of solder stuck between to contacts that go into the cartridge-slot. After removing, vidgrid started , yeah! Saving and loading is OK now. Later, Sijmen. Quote Link to comment Share on other sites More sharing options...
Sporadic Posted June 18, 2015 Share Posted June 18, 2015 Hi, I know this post is old but I just had the exact problems talked about in this thread. Mine also had a weird random blob of solder on the contacts! Also, if using option to view the contents of the memory track, the saved names would show jumbled characters too. I thought it would be useful to post a photo of the rogue solder in case someone else has this issue. Perhaps it was a faulty batch? After just picking it off with my nail, the memory track works perfect. Didn't require heating with a soldering iron or anything. 1 Quote Link to comment Share on other sites More sharing options...
