Cartrdge Disassembly
3 replies to this topic
#1 bombidragon OFFLINE
    Chopper Commander
  • 132 posts
Posted Sun Oct 31, 2010 11:26 AM
Does anyone know how to disassemble the intv carts that don't have screws???
#2 IntellivisionDude OFFLINE
  • 3,625 posts
  • INTV Brotherhood Member
Posted Sun Oct 31, 2010 12:11 PM
I just read a post here recently where someone said you have to use a small screwdriver (carefully) and the small cover will pop off, but you will have to glue it back on.
#3 jaybird3rd OFFLINE
  • 8,605 posts
  • "Excuse me, sir? I have a question ..."
Posted Sun Oct 31, 2010 3:17 PM
There is also a solid cartridge shell without a "back door," into which the board was inserted through the card edge opening. For those shells, the boards are held in place by a small plastic clip inside the shell, just above the fingers, and you can sometimes pinch the plastic snaps that hold it in place with a small screwdriver just enough to slide the board out. Just be careful that you don't actually break the snaps, and that you bend them back into place before you try to re-insert the board. I've got a broken Buzz Bombers cartridge like that (it came that way out of the box, actually): if you pull it out of the console, the shell slides right off and board stays in the slot!
#4 edintv OFFLINE
  • 745 posts
Posted Sun Oct 31, 2010 6:21 PM
for the version of the cart with 2 pieces and no screws, the cover is glued, so with a little pressure and care, you can remover that cover without any damage. fix your cart (I Recommend to use an Ink eraser to clean the contacts) and then apply a glue. I didnt use a strong one in case i need to reopen again.
The topic of cleaning carts has risen very often lately, I have as a proyect to do some videos of my techniques, but my crappy camera doesn´t record audio.
