System Changer
tz101
Does it only work with Intellivision II, but not with I or III?
Yes. The original Intellivision required a factory modification (to connect the external video input signal to one of the cartridge pins, as I recall). The modification has been documented by the Blue Sky Rangers, but the Intellivision II was designed with this input already connected, so the System Changer was compatible with it out of the box. The INTV System III went back to the original Intellivision design, so it also required the modification; I suppose that INTV wasn't planning on producing more System Changers, so they didn't see the need to support it.
