mvdsteenoven Posted December 13, 2013 Share Posted December 13, 2013 What's the best Aquarius assembler workflow workaround on 64 bit windows 7? I have faced the same issue and switched over to tniASM - Macro AssemberDo not know if this is the the best, but the freeware version seems to do the job well.There are some minor differences, like setting the start address: In TASM: .ORG $E000 tniASM: ORG $E000 Note the dot?Most tniASM commands do not use a .dot like TASM but is all in the tniasm.txt manual. RegsMartin Quote Link to comment Share on other sites More sharing options...
Pset Posted December 14, 2013 Share Posted December 14, 2013 You have working examples please? This is always such a struggle to get one thing working. Meanwhile, What do you think we could do with this Lua Z80 emulator with assembler /dissasembler? https://github.com/robzed/LuaZ80 What could we put together for that? Quote Link to comment Share on other sites More sharing options...
Pset Posted December 14, 2013 Share Posted December 14, 2013 Trying to get that Aquarius man adventure assembled, at least virtual aquarius could see the file this time. But it was no load. Maybe you can see something glaringly wrong with the code ; File: PANSCRN.ASM ; Purpose: Panning screen from array-area ; By: Martin v.d. Steenoven ; http://www.vdSteenoven.com/aquarius ; ; Use tniasm (supplied with VirtualAquarius) to compile: ; tniasm panscrn.asm ; CPU Z80 ; switch to Z80 mode ORG 31000 ; Start address of machinecode ; Aquarius with 16K additional memory required ; ; Definitions to make code more readable ; and to make it easier if I want to use a different size background screen ; COLS: EQU 40 ; Maximum number of columns per screen ROWS: EQU 22 ; Maximum number of rows per screen MAXCOL: EQU 167 ; Last column ( 4+ screens ) SETSIZE: EQU MAXCOL * ROWS ; total number of characters (or colors) ; 22 * 167 equals 3674 ; used to calculate the beginning of the ; color-table ( offset plus SETSIZE ) LASTLEFTCOL: EQU MAXCOL - COLS ; There is a total of 167 colums in the background screen, ; we can only draw 40 columns per screen, thus the last ; column beginning a new screen is 167 - 40 = 127 Initialize: ; Clear the screen and color it black ld b,$20 ; ASCII code for <space> ld hl,$3000 ; start of screen character ram location call $1e59 ; fill screen character ram with spaces. ld b,$70 ; Green on Black color attrib call $1e59 ; set colour attribs. ; Keyboard instructions ld hl, leftstr ; pointer to text "c - left" ld de, 13253 ; on screen, 22nd row, 5th col ld bc, 8 ; 8 characters ldir ld hl, rightstr ; pointer to text "b - right" ld de, 13274 ; on screen, 22nd row, 26th col ld bc, 9 ; 8 characters ldir ; Calculate the start address of the array ; where the background screen is located. ld hl, (14552) ; ARRTAB ld de, 7 ; add hl, de ; ARRTAB plus 7 is where the screen dump is located ld (offset), HL ; Save the start address at offset mainloop: call do_pan ; show screen call AquariusMan ; show man figure call keyboard ; check and wait for key jr mainloop keyboard: ld bc,$2F60 ; Pause for $2f60 loops (Approx 1.5 second) call $1d4b ; SLEEPBC - sleep for BC loops. ld bc, $efff ; Scan column 4 in a,(c) ; READ KEYBOARD bit 4,a jr nz, nextkey ; 'c' is not pressed ; 'c' is pressed, moving to the left ld a, $FF ; Moving right (-1) call prep_move ; Prepare the move cp $FF ; minus one (-1) jr nz, end_of_key ; Within limits, we can move left ; Could jump back to keyboard, but ; let's check the 'b' while we are here nextkey: ld bc, $f7ff ; Scan column 3 in a,(c) ; READ KEYBOARD bit 5,a jr nz, keyboard ; 'b' is not pressed ; 'b' is pressed, moving to the right ld a, $01 ; Moving right (+1) call prep_move ; Prepare the move cp LASTLEFTCOL + 1 ; upper left last screen jr z, keyboard ; Over the limit, do not move to the right end_of_key: ret prep_move: ld hl, move ; Load the address where the movement is stored into HL ld (hl), a ; Next movement stored in A (+1 or -1) cp 1 ; >+ Are we moving right? ld hl, man ; | ld a, (hl) ; | A now contains the AquariusMan status jr z, moving_right ; <+ Now jump if we were moving right moving_left: bit 7, a ; Is AquariusMan also facing left? jr nz, move_ok ; ld a, $00 ; AquariusMan is temporarily idle, will be set to left #1 jr move_ok moving_right: bit 7, a ; is AquariusMan also facing right? jr z, move_ok ld a, $00 ; AquariusMan is temporarily idle, will be set to right #1 move_ok: ld hl, move ; Location of the AquariusMan status add a, (hl) ; AquariusMan has 2 states for moving left or right cp 3 ; did we got over the 2nd state for moving right? jr nz, prep2 ld a, 1 prep2: cp -3 ; did we got over the 2nd state for moving left? jr nz, prep3 ld a, -1 prep3: ld hl, man ld (hl), a ; Aquarius man facing right or left (+2, +1 or -1, -2) ld hl, move ld a, (xpos) ; read current first column upperleft corner add a, (hl) ; increase or decrease register A depending on the movement ret do_pan: ld (xpos), A ; store new first column upperleft corner call FirstCol ; Calculate first column in HL ex de, hl ; DE points at start address characters ld hl, 12328 call scrn ; Write chars to screen call FirstCol ; Calculate first column in HL ld de, SETSIZE ; DATA contains 4+ screens add hl, de ; HL points at start address colors ex de, hl ; Now DE points at start address colors ld hl, 13352 Call scrn ; Write colors to screen ret ;Draw a man on the screen, just for fun AquariusMan: ld a, (man) ; What is the men's current state? cp -2 jr z, man_left2 cp -1 jr z, man_left1 cp 0 jr z, man_idle cp 1 jr z, man_right1 man_right2: ld a, 21 ; Man's head facing right #2 call ShowMan ret man_right1: ld a, 23 ; Man's head facing right #1 call ShowMan ret man_idle: ld a, 19 call ShowMan ret man_left1: ld a, 130 ; Man's head facing left #1 call ShowMan ret man_left2: ld a, 140 ; Man's head facing left #2 call ShowMan ret ShowMan: ld (13108),a ; 12328+20+19*40 push af ; >+ store AF register ld a, (14132) ; | the current color at location and 15 ; | make the foreground black, keep background ld (14132), a ; | store the new color combination pop af ; <+ restore AF register inc a ; Man's legs ld (13148),a ; 12328+20+20*40 ld a, (14172) ; the current color at location and 15 ; make the foreground black, keep background ld (14172), a ; store the new color combination ret scrn: ld c, ROWS ; 22 rows defined in macro loop1: ld b, COLS ; 40 columns defined in macro loop2: ld a, (de) ld (hl), a inc hl inc de djnz loop2 ; B=B-1, jump while not zero ; End of columns, goto next row dec c push hl ; >+- temporarily store HL ld hl, MAXCOL - COLS ; | Skip the difference to the start of next row add hl, de ; | ex de, hl ; | pop hl ; <+- restore HL jr nz, loop1 ret FirstCol: ld hl, (offset) ; offset address characters ld a, (xpos) ; xpos = first column upperleft corner ld d, $00 ld e, a add hl, de ; ret leftstr: dw "c - Left" rightstr: dw "right - b" xpos: db $00 ; first column upperleft corner move: db $FF ; -1 = left, 1 = right man: db $00 ; -2 = left #2, -1 = left #1, 0 = idle, 1 = right #1, 2 = right #2 offset: dw $0000 ; start address screendumps Quote Link to comment Share on other sites More sharing options...
mvdsteenoven Posted December 14, 2013 Share Posted December 14, 2013 You have working examples please? This is always such a struggle to get one thing working. Meanwhile, What do you think we could do with this Lua Z80 emulator with assembler /dissasembler? https://github.com/robzed/LuaZ80 What could we put together for that? The bootloader has been compiled with tniAsm, maybe that helps? There are many Z80 emulators available in C, Java. You can execute the Aquarius ROM within such emulator. The tricky part is the I/O like sound, keyboard and screen while keeping the Z80 performance. Regs, Martin Quote Link to comment Share on other sites More sharing options...
mvdsteenoven Posted December 14, 2013 Share Posted December 14, 2013 Trying to get that Aquarius man adventure assembled, at least virtual aquarius could see the file this time. But it was no load. Maybe you can see something glaringly wrong with the code I only had a quick look, but I am missing the rom recognization at E000The Aquarius will not accept the cartridge without a valid ROM recognization Regs, Martin Quote Link to comment Share on other sites More sharing options...
Pset Posted December 16, 2013 Share Posted December 16, 2013 Going in circles with this assembler and went looking for other z-80 emulation options, maybe with scripting. Found Oshonsoft Z-80 Simulator IDE with built in assembler, dissassembler, and BASIC compiler. 30 day trial, and the "Getting Started" six lessons took me about an hour an a half, some instructions don't match theinterface, but everything eventually did what the tutorial expected it to do, filling memory, testing printer ports, getting keyboard input. compiling a basic program to assembler and assembling it and loading it into the virtual Aquarius and getting it to scream bloody ?SN ERROR! It's Alive! I had some fun with this thing, but I better stay on the path of productivity. So have a go at it and give it a review. You think we could set up an Aquarius simulation and adapt that BASIC compiler? That would make my holiday. It would probably mean dropping the default Aquarius BASIC, that was the goal in 1984. Anyway, have a look at this software and maybe you'll see some benefit for future Aquarius development. 1 Quote Link to comment Share on other sites More sharing options...
Aquaman Posted December 16, 2013 Share Posted December 16, 2013 (edited) You think we could set up an Aquarius simulation and adapt that BASIC compiler? That would make my holiday. It would probably mean dropping the default Aquarius BASIC, that was the goal in 1984. As for an attempt on a Basic compiler, Nitrofurano made had a go at it: http://atariage.com/forums/topic/213965-aquarius-stuff-from-boriels-zx-basic-compiler-first-attempt/ Edited December 16, 2013 by Aquaman Quote Link to comment Share on other sites More sharing options...
+Gemintronic Posted December 16, 2013 Share Posted December 16, 2013 ZX Basic for the Aquarius might be a project Nitrofurano alone can't complete (though I admire this intentions). ZX Basic for the Sega Master System also seems indefinitely stalled. I'm pretty sure the source for both projects is around. Maybe a second pair of eyes would get ZX Basic for the Aquarius farther. I mention the SMS version as the Z80 is a common point. 2 Quote Link to comment Share on other sites More sharing options...
Pset Posted December 17, 2013 Share Posted December 17, 2013 (edited) I take the latest files from Nitrofurano, and point zbx to it, get a bin file that's 6K smaller than his example ROM, load it into the Virtual Aquarius, reboot. Nothing. Now what? If I run it with the -d debugger I get 1536 lines of machine code for a 75 line BASIC program. Maybe there's one of two dozen essential files not included? Or I'm not using the right command line option? Or its the compiler is broken on 64 bit windows? You guys get a working binary from running zxb.exe example01.bas on the commandline? Am I doing that wrong? Loved his working example01.rom and hoping to get some working machine code to build so I can try making a 3x3 sprite editor that will run sprite graphics spritely. I don't expect to pick up and use assembler over night, but I do. Oh BTW, Rob Probin of ZedCone LuaZ80 project got back to my inquiry: LuaZ80 is still a work in progress, had to take a break in order to do some stuff on gulpman (http://gulpman.net) ... just been adding a Lua interpreter to it ... (Hey REXpaint guy, you listening?) Anyway, if you are interested in using LuaZ80, in a bigger project - say emulate the Mattel Aquarius, then I'll help by completing/bug fixing the Z80 emulator. Whether I can commit to more than that is another matter: I already have a zillion projects running :-) What did you have in mind for graphics display? Would it be possible to add the z80 to LOVE or something for that? Yeah, I've used Love2D and SDL (1 and 2) ... so those would probably be possible. Love2D uses Lua5.1, so that might actually cause some problems. Specifically LuaZ80 use gotos, if I remember correctly.It might be possible to switch Love2D to use LuaJIT which has goto support. LOVE 0.90 released today, LuaJIT by default instead of LUA 5.1 Cool! So if I'm to understand it at this point in the project your Z80 would basically just return some console data for you to know its working?Yes. There is a debugger in the LuaZ80 project you can step Z80 with, and an unused op-code will print to stdout. I have some test code I've been using to test op-codes.The aquarius graphics screen is only 40x25 characters, console output shouldn't be a problem faking graphics for a while.Sure. The debugger uses VT100/ANSI control codes to highlight interesting stuff. Doing that for a while wouldn't be too bad. Also you could add extra unused op-codes or even patch a screen decode. You still need to basically model that fake Spectrum in Lua? or you'll load some of the standard non-standard ROM image files?The plan was standard image files. We have write-protect, so that overcomes the ROM writes to ROM. As for hardware emulation, I'd not got that far yet. The two options were either Lua code or patch a version of a current emulator to use LuaZ80 as it's CPU emulator (I've used and looked at zxsp a lot). Zxsp looks like unix/mac only? What are our options on that front? Edited December 17, 2013 by Pset 1 Quote Link to comment Share on other sites More sharing options...
Aquaman Posted August 20, 2014 Share Posted August 20, 2014 Hi, Thank's for your comments, I should receive the cassettes from my mother in a few day's so hopefully it is there. I will check out the Aquarius user site and will have to find an Aquarius again. Hi Clemeilio, it's been a while since you visited this Forum. Any news on the Aquarius side of things? Quote Link to comment Share on other sites More sharing options...
g0blinish Posted May 3, 2015 Share Posted May 3, 2015 how to redefine character set? cannot find memory address. Quote Link to comment Share on other sites More sharing options...
jaybird3rd Posted May 3, 2015 Author Share Posted May 3, 2015 how to redefine character set? cannot find memory address. There is no way to redefine the character set in a stock Aquarius. The character data is stored in a 2K ROM that is not mapped into the Aquarius address space, so there is no memory address to change. I'm in the process of designing an upgrade for the Aquarius which will allow user-defined character graphics. Watch the Intellivision forum for an update; I hope to have something to share within the next two weeks. 1 Quote Link to comment Share on other sites More sharing options...
g0blinish Posted May 3, 2015 Share Posted May 3, 2015 interesting.. Compute-032-01-1983 said The Aquarius can display 256 characters. This includes a 128-character ASCII set with upper- and lowercase, and 128 user-programmable char acters, similar to the redefinable character sets on the Atari, Commodore 64, VIC-20, and TI-99/4A computers. Quote Link to comment Share on other sites More sharing options...
jaybird3rd Posted May 3, 2015 Author Share Posted May 3, 2015 I'm afraid they were mistaken. If you study the Aquarius motherboard, you'll see that all of the Aquarius character data comes from the character generator ROM. Even if its contents were directly accessible to the programmer, it could not be changed, since ROM is (as its name indicates) Read Only Memory. Making even half of the character set user-programmable would have required a much different memory design, and it also would have eaten up a whopping 1K out of the ~1.7K of free RAM that an unexpanded Aquarius has. My upgrade will include dedicated character memory, as well as a larger ROM with a variety of built-in character sets. 1 Quote Link to comment Share on other sites More sharing options...
g0blinish Posted May 3, 2015 Share Posted May 3, 2015 I'm afraid they were mistaken. If you study the Aquarius motherboard, you'll see that all of the Aquarius character data comes from the character generator ROM. Even if its contents were directly accessible to the programmer, it could not be changed, since ROM is (as its name indicates) Read Only Memory. Making even half of the character set user-programmable would have required a much different memory design, and it also would have eaten up a whopping 1K out of the ~1.7K of free RAM that an unexpanded Aquarius has. My upgrade will include dedicated character memory, as well as a larger ROM with a variety of built-in character sets. Ok, where is exactly adress of character set? Quote Link to comment Share on other sites More sharing options...
jaybird3rd Posted May 3, 2015 Author Share Posted May 3, 2015 Ok, where is exactly adress of character set? The character set does not have an address. The memory locations within the character matrix (from $3000-$33FF) select the characters which appear on the screen; each location corresponds to one on-screen character. However, the corresponding bitmap data from the character generator ROM is only available to the Aquarius's video controller. This ROM is not assigned an address (and in fact does not even appear on the same bus as the other memory), so its contents are "invisible" to the programmer. 1 Quote Link to comment Share on other sites More sharing options...
g0blinish Posted May 25, 2015 Share Posted May 25, 2015 how works Virtual Aquarius option: Util/Load Binary -- This is useful for assembly language program development. ? typed source and assembled with sjAsm: device zxspectrum128 ORG #6000 begin ld hl,$3400 lp: ld (hl),l:inc l:jr nz,lp ret;jr $ end display /d,end-begin savebin "test.bin",begin,end-begin no effect:( Quote Link to comment Share on other sites More sharing options...
Bruce Abbott Posted May 27, 2015 Share Posted May 27, 2015 how works Virtual Aquarius option: Util/Load Binary -- This is useful for assembly language program development. ? typed source and assembled with sjAsm: device zxspectrum128 ORG #6000 begin ld hl,$3400 lp: ld (hl),l:inc l:jr nz,lp ret;jr $ end display /d,end-begin savebin "test.bin",begin,end-begin no effect:( RAM above $3FFF is on the expansion bus, so it goes through the code scrambler (which XORs the data bus against the value stored in I/O port $FF). Normally this isn't a problem because data written to RAM also goes through the scrambler, so it is scrambled when written but unscrambled again when read out. However the Virtual Aquarius 'Load Binary' function loads the data directly into RAM, so it will be scrambled when read out. For your code to read correctly the scramble code must be set to 0. One way to do this is POKE 14345 with 0, do a soft reset, hit ctrl-c, then load your code into the now unscrambled RAM. Quote Link to comment Share on other sites More sharing options...
g0blinish Posted May 28, 2015 Share Posted May 28, 2015 no, code works If i load binary without USR. Next Step is copy/paste: 45 n=14790 50 POKE 14341,INT(N/256):POKE 14340,N-256*PEEK(14341) 55 x=usr(0) Quote Link to comment Share on other sites More sharing options...
g0blinish Posted August 31, 2015 Share Posted August 31, 2015 here is my attempt: http://www.pouet.net/prod.php?which=66288 3 Quote Link to comment Share on other sites More sharing options...
Aquaman Posted August 31, 2015 Share Posted August 31, 2015 (edited) here is my attempt: http://www.pouet.net/prod.php?which=66288 Not a bad attempt I must say! Did you compose the music yourself? Edited August 31, 2015 by Aquaman Quote Link to comment Share on other sites More sharing options...
g0blinish Posted September 1, 2015 Share Posted September 1, 2015 No, tune is simple cover for Hollywood Video Poker Quote Link to comment Share on other sites More sharing options...
GroovyBee Posted September 1, 2015 Share Posted September 1, 2015 here is my attempt: http://www.pouet.net/prod.php?which=66288 Found the video on youtube :- 1 Quote Link to comment Share on other sites More sharing options...
Aquaman Posted September 1, 2015 Share Posted September 1, 2015 No, tune is simple cover for Hollywood Video Poker Did you rip it somehow, and if yes could you please explain how you did this? Quote Link to comment Share on other sites More sharing options...
g0blinish Posted September 2, 2015 Share Posted September 2, 2015 Did you rip it somehow, and if yes could you please explain how you did this? ZX Tune has ripper from Sound Tracker. I have decompiled ST player's source. some modifications in code and you have music. Quote Link to comment Share on other sites More sharing options...
