I spent two evenings putting together a very minimal set of standard tools for accessing the cart. They will be included in the cc65 libraries soon.
The first one is
off_t lseek(int fd, off_t offset, int whence);
Of this I implemented only seek to a 32-bit offset. This code just sets the Lynx cart hardware to the right position so that the next read command can access the right bytes.
Example:
lseek(1, 0, SEEK_SET); // Seek to the 1st byte on the cart lseek(1, 1234, SEEK_SET); // Seek to the 1234:th byte on the cart
The lseek-command will ignore the fd-parameters and whence-parameter completely. This is because the Lynx only has one set of registers for accessing the cart. So you can not open two files at the same time anyway.
The second command to implement is
size_t read(int fd, void *buf, size_t count);
This will read "count" bytes into buf starting at the place where lseek or a previous read has left the hardware.
Example:
char buf[10]; lseek(1, 0, SEEK_SET); read(1, buf, 10); // Read first 10 bytes into buf read(1, buf, 10); // Read next 10 bytes into buf
The commands lseek and read will operate on the raw cart directly. They do not understand anything about files.
For files I plan to implement a command "open".
int open(const char *pathname, int flags, ...);
This command would understand filenames "0", "1", "2", ...
Internally this open-command would work like this:
int open(char name, int flags)
int fileno = atoi(name);
lseek(1, StartOfDirectory + fileno * 8, SEEK_SET); // Go to correct dir entry
read(1, FileEntry, 8); // Read entry into memory
block(FileStartBlock); // Set the Lynx address hardware to point to the content of this file
lynxskip(FileBlockOffset);
return 1;
So after running "open" you have the directory entry available in the FileEntry structure.
FileEntry: FileStartBlock: byte FileBlockOffset: int FileExecFlag: byte FileDestAddr: int FileFileLen: int
Example of how to load a segment into memory.
void load(char name) {
open(name, O_RDONLY);
read(1, FileDestAddr, FileFileLen);
load("123"); // Load file number 123 into RAM
Seasons Greetings,
Karri
