XM Status Page...
1274 replies to this topic
#876 Wntermute OFFLINE
Wntermute
    Moonsweeper
  • 471 posts
Posted Wed Nov 9, 2011 12:39 PM
So we are seeing a HUGE launch line-up of XM enhanced games that will all be working for the release of the XM, so those who've been wondering "if" any XM games would be available, there is going to be a very large launch line up!
Sounds like there'll be more XM enhanced/required games at launch than the 3DS had 3DS games. lol :D
#877 Propane13 OFFLINE
Propane13
  • 1,642 posts
Posted Wed Nov 9, 2011 12:42 PM
2 questions--
1) is the HSC at a different software address compared with the old HSC I already have?
2) Same question, but about POKEY software address for "special hardware" carts vs. XM.
-John
#878 GroovyBee OFFLINE
GroovyBee
    Games Developer
  • 9,636 posts
  • Busy bee!
Posted Wed Nov 9, 2011 1:10 PM
They are at the same address. If the XM BIOS detects a HSC pass through cart plugged into the top slot it displays an error message. If it detects a multi-cart it disables its own built in HSC because it doesn't know what you'll choose to play. If you are mad enough to plug an XM into an XM it detects that too.
XM POKEY does not conflict with CC2, Ballblazer or Commando POKEY addresses. It is compatible with the XBOARD games BeefDrop and Froggie.
#879 psquare75 OFFLINE
psquare75
    Dragonstomper
  • 704 posts
Posted Wed Nov 9, 2011 2:00 PM
In my personal dreamworld, an XM plugged into an XM results in a countdown to destruction on the screen, a la Star Trek III.
#880 Propane13 OFFLINE
Propane13
  • 1,642 posts
Posted Wed Nov 9, 2011 2:06 PM
Ok, this is good to hear.
So, in theory, there is no software change needed for say, newly-written software to be "XM compatible" with respect to the POKEY and the HSC, right?
In short, I'm trying to confirm that developers only need to make the software "one way".
So, if I wrote a game that used HSC, I'd have the option to use my old HSC, or to use the XM without code changes.
And, if I had a game that used POKEY, I wouldn't have to compile 2 different versions, one for XM, and one for "hardware that supported POKEY", correct?
That was something rattling around in my brain today; thought I'd ask the experts. :)
-John
#881 GroovyBee OFFLINE
GroovyBee
    Games Developer
  • 9,636 posts
  • Busy bee!
Posted Wed Nov 9, 2011 2:18 PM
Not quite. POKEY and HSC are enabled and disabled from the main control register in the XM. The HSC will be enabled by default when a 7800 game is detected and started in NTSC mode (unless its a known multi-cart). For PAL operation, HSC is always disabled unless you override it manually. The reason HSC is disabled in PAL is because the legacy PAL games (that support HSC in NTSC format) crashed when a HSC was detected in the system from the tests I did a while ago. I may get around to making a PAL HSC BIOS and retesting them (it all depends on time). I'd rather the legacy PAL games didn't crash when plugged into the XM.
I'm gathering the materials for the XM technical guide so that'll be available shortly after the XM ships.
#882 Curt Vendel OFFLINE
Curt Vendel
  • 4,481 posts
Posted Wed Nov 9, 2011 9:13 PM
Bob's Pac 320 and Ms Pac 320 are both working perfect with the XM for Pokey/HSC....
Still having problems with Perry's Pokey Kong, trying to figure out why its not working with the XM, his Pokey Pacman is working fine and Pokey Kong works fine with the XM, but then what's the point - No Pokey.
Curt
#883 Curt Vendel OFFLINE
Curt Vendel
  • 4,481 posts
Posted Wed Nov 9, 2011 9:18 PM
"Awaiting final code for 1 Minute Countdown"
"Code 7 8 0 Destruct 0"
Then the power pak overheats and blows out ;-)
#884 Metal Ghost OFFLINE
Metal Ghost
  • 1,434 posts
Posted Thu Nov 10, 2011 7:53 AM
I haven't seen that movie in quite some time....I REALLY hope that quote gets into the current book I'm reading, 'Ready Player One'. It would completely fit in context.
Sorry, off topic I know, but when we all need some TV-free time from playing XM next month (you know, that 30 minutes or so out of the day :) ) I highly recommend this book. I haven't finished it yet, but it is definitely a read that I think any AtariAger would enjoy immensely.
#885 Nuclear Pacman OFFLINE
Nuclear Pacman
  • 2,487 posts
Posted Sat Nov 12, 2011 1:00 PM
Things are looking good for me. My plan is to pre-order this thing by next weekend as long as nothing major pops up like vehicle issues. Just wanted to make sure that the following website is the proper place to order? http://www.legacyeng...bt6fctcgmkusv93
Also, is this unit going to run off the power of the 7800, or is it going to require it's own psu? Just wondering, it has no effect on my purchasing decision, although if it runs off the existing 7800 power, should we be concerned with our psu's being overworked and maybe going bad?
#886 mimo OFFLINE
mimo
    Preppie!
  • 6,797 posts
  • It's easy living in a bubble
Posted Sat Nov 12, 2011 4:01 PM
Yes that is the correct site to order from.
It uses the 7800 psu, well, it takes its power from the 7800 cart port.
7800 psu should be more than sufficient, modern electronics are very efficient, I bet there is hardly any extra load
#887 Curt Vendel OFFLINE
Curt Vendel
  • 4,481 posts
Posted Mon Nov 14, 2011 10:40 AM
Will be posting up some more demo and compatibility test videos this week, will be holding off on the super-secret demo till Mark get to the ejagfest and sets up, then we can show you something REALLY cool that should put a lot of smiles on people's faces for sure....
#888 Darrin9999 OFFLINE
Darrin9999
  • 2,791 posts
Posted Sat Nov 19, 2011 9:52 AM
Just ordered one! Can not wait to play some new games.... Thanks Curt!
#889 Nuclear Pacman OFFLINE
Nuclear Pacman
  • 2,487 posts
Posted Sat Nov 19, 2011 10:50 AM
Same here, ordered mine yesterday!
#890 Lendorien OFFLINE
Lendorien
  • 1,247 posts
Posted Sat Nov 19, 2011 11:39 AM
Waiting eagerly for that update. Probably a pipe dream to hope for it to be here before Christmas at this point, but it's great to see things moving at a good speed.
Edited by Lendorien, Sat Nov 19, 2011 11:41 AM.
#891 Curt Vendel OFFLINE
Curt Vendel
  • 4,481 posts
Posted Sat Nov 19, 2011 6:44 PM
We are going to make it, shaking out some final issues, all of the major ones are behind us, just need to make some changes to the audio circuit for the summation of the pokey and yamaha in the console and dealing with carts that have onboard pokey, seems our summation circuit is over powering ballblazer and other pokey carts and I'd be concerned it may interfere with xboards as well.
We have a few stubborn carts - mean 18, motopsycho and impossible mission that aren't playing well with xm at all.
All 2600/7800 homebrews all play well with the xm
The 7800 homebrewers have made adjustments to make sure their new games can use pokey and we are making sure they are all working well.
Cuttlecart 2 and croc carts are working great now, haven't tested harmony and I will make sure Btari gets an xm so he can test to make sure his H2 and XM work well together.
Just waiting for word back from Mark to see if he's publicly demo'd the super secret adding test yet so I can post the video
Curt
Edited by Curt Vendel, Sat Nov 19, 2011 6:55 PM.
#892 philipj OFFLINE
philipj
    Moonsweeper
  • 363 posts
Posted Sat Nov 19, 2011 11:40 PM
Sounds great... Can't wait... :D :thumbsup:
#893 swlovinist OFFLINE
swlovinist
  • 1,859 posts
  • I heart videogames!
Posted Sun Nov 20, 2011 9:45 AM
Thanks for the updates. I cant wait till the project is done. There has been so much hard work done on this. I appreciate the details shared of how challenging a project of this magnitude is, and look forward to supporting all homebrew software when released.
#894 mimo OFFLINE
mimo
    Preppie!
  • 6,797 posts
Posted Sun Nov 20, 2011 4:45 PM
Curt
aaaah, spill the beans, the show is finished and the weekend of suspense is killing me
#895 Curt Vendel OFFLINE
Curt Vendel
  • 4,481 posts
Posted Mon Nov 21, 2011 8:05 AM
All right... Mark is back and a lot of people got to see the demo at ejagfest...
There is a test built into the latest bios that tests an xegs keyboard plugged into the xm.
Also, while just a thought, Mark is considering allowing players to enter your high score initials into a game via xegs keyboard
Basically, the keyboard is going to totally open up the doors to a whole new breed of games on the 7800 that will allow for even more imagination from coders and more fun for players.
Perhaps it's time for a Star Raiders type game on the 7800 to turn shields, com
#896 DracIsBack OFFLINE
DracIsBack
  • 5,190 posts
Posted Mon Nov 21, 2011 8:47 AM
Which was ... ????? :-D
#897 Standard User OFFLINE
Standard User
    Dragonstomper
  • 827 posts
  • Redundant
Posted Mon Nov 21, 2011 9:04 AM
So, it has some rudimentary keyboard support, already...cool. Didn't think that would come until later. It does take a lot of the sting out of devising control schemes...pure awesomesauce. :)
#898 Gaztee OFFLINE
Gaztee
  • 1,523 posts
Posted Mon Nov 21, 2011 5:49 PM
Fricking excellent! Really makes me wish I hadn't sold mine a while back! I might have to scout about on eBay again! We did come up with a nickname for it, but I am under pain of death to keep it under wraps until its released!! :grin:
#899 Zonie OFFLINE
Zonie
  • 1,343 posts
Posted Mon Nov 21, 2011 6:50 PM
Well there goes the price of XEGS consoles... :lol:
Edited by Zonie, Mon Nov 21, 2011 6:50 PM.
#900 Curt Vendel OFFLINE
Curt Vendel
  • 4,481 posts
Posted Tue Nov 22, 2011 12:25 AM
I know I promised demo's sorry... big project here at the house this week, so time has been tight, I will post up something shortly, I know everyone wants to see the latest news, so I will get something done Friday while I'm having my 10th helping of turkey ;-)
