Kjmann Posted January 19, 2011 Author Share Posted January 19, 2011 Here are Final Versions of The Stereo and Mono Unreal Superhero III Songs. Instrument Volume has been Improved and Phase Canceling Problems in the Mono Version has been Fixed. Enjoy. =) Quote Link to comment Share on other sites More sharing options...
analmux Posted January 19, 2011 Share Posted January 19, 2011 Yes, sounds not bad at all. (OK, I personally hate the gen C/E basses, but that's a matter of taste). Instrument volume settings sound good. But, the pulsewidth modulation can surely be improved still. By the way, what about a 16bit bass channel (instead of an 8bit gen C/E bass) for the stereo version? I'd really like to hear a 16bit pure square bass instead though, but it's a pity RMT doesn't really support it. Maybe another reason to do a 6th patch of RMT Quote Link to comment Share on other sites More sharing options...
+Stephen Posted January 20, 2011 Share Posted January 20, 2011 Here are Final Versions of The Stereo and Mono Unreal Superhero III Songs. Instrument Volume has been Improved and Phase Canceling Problems in the Mono Version has been Fixed. Enjoy. =) Both sound really nice! The stereo version is great. P.S. Stereo PoKey emulation seems terribly broken in Altirra 1.8. The 2nd PoKey is horribly out of tune - maybe it is not allowing for filters or polycounter resets? Atari800Win+ is pretty close to the real hardware. Quote Link to comment Share on other sites More sharing options...
Rybags Posted January 20, 2011 Share Posted January 20, 2011 Something is "amiss". If you load the mono one with Stereo enabled, then later set back to mono, the audio all but drops out. Quote Link to comment Share on other sites More sharing options...
Kjmann Posted January 20, 2011 Author Share Posted January 20, 2011 This Seems to be a problem with altirra. Not Sure what the Problem is though. When Switching between Mono and stereo you must restart altirra or you will have problems. Quote Link to comment Share on other sites More sharing options...
Kjmann Posted January 20, 2011 Author Share Posted January 20, 2011 Yes, sounds not bad at all. (OK, I personally hate the gen C/E basses, but that's a matter of taste). Instrument volume settings sound good. But, the pulsewidth modulation can surely be improved still. By the way, what about a 16bit bass channel (instead of an 8bit gen C/E bass) for the stereo version? I'd really like to hear a 16bit pure square bass instead though, but it's a pity RMT doesn't really support it. Maybe another reason to do a 6th patch of RMT The Stereo Version is Using a 16bit (Gen 6) Bass. =) Quote Link to comment Share on other sites More sharing options...
Alphasys Posted January 20, 2011 Share Posted January 20, 2011 I'm impressed. Smooth. Love it. Quote Link to comment Share on other sites More sharing options...
Creature XL Posted January 20, 2011 Share Posted January 20, 2011 Real hard to see how it could be much better Let's wait for Emkay Quote Link to comment Share on other sites More sharing options...
R4ngerM4n Posted January 20, 2011 Share Posted January 20, 2011 Let's wait for Emkay He (?) posted something in another thread. Quote Link to comment Share on other sites More sharing options...
Mclaneinc Posted January 20, 2011 Share Posted January 20, 2011 Both play fine in Altirra here, yes swapping to stereo really should have a reset, don't think it needs a full power down tho. Quote Link to comment Share on other sites More sharing options...
Kjmann Posted April 26, 2011 Author Share Posted April 26, 2011 Using Some Ideas I got From a Discussion with Analmux, I Made Some Changes to this song and Cleaned it up a bit. So I figured Why not Upload it. =) I worked Specifically on the Main Synth Melody Line. I think it's sounds a bit smoother now. Thanks Analmux for the Help. =) 3 Quote Link to comment Share on other sites More sharing options...
atx4us Posted April 29, 2011 Share Posted April 29, 2011 Using Some Ideas I got From a Discussion with Analmux, I Made Some Changes to this song and Cleaned it up a bit. So I figured Why not Upload it. =) I worked Specifically on the Main Synth Melody Line. I think it's sounds a bit smoother now. Thanks Analmux for the Help. =) Awesome! Your musical talent is quite evident here. Thanks for sharing this with us. Since I know little about this type of music generation on the Atari, can you please tell me how did you create this song? (i.e. on a MIDI keyboard) Hayden Quote Link to comment Share on other sites More sharing options...
Kjmann Posted April 30, 2011 Author Share Posted April 30, 2011 Using Some Ideas I got From a Discussion with Analmux, I Made Some Changes to this song and Cleaned it up a bit. So I figured Why not Upload it. =) I worked Specifically on the Main Synth Melody Line. I think it's sounds a bit smoother now. Thanks Analmux for the Help. =) Awesome! Your musical talent is quite evident here. Thanks for sharing this with us. Since I know little about this type of music generation on the Atari, can you please tell me how did you create this song? (i.e. on a MIDI keyboard) Hayden Well, I didn't write it. I used Raster Music Tracker With My Midi Keyboard and Played in the notes. =) Quote Link to comment Share on other sites More sharing options...
Rybags Posted April 30, 2011 Share Posted April 30, 2011 Altirra has a slight bug in that if you swap between mono/stereo on the fly, it puts both Pokeys into the INIT state. You can "fix" it by entering "E D20F 03" in the console window (D21F for the second Pokey) after doing the change. Playback routines that bother to check if you have Stereo would only tend to do it once, and most would only set SKCTL once as well, unless using the 2-tone feature. Quote Link to comment Share on other sites More sharing options...
+Stephen Posted April 30, 2011 Share Posted April 30, 2011 Using Some Ideas I got From a Discussion with Analmux, I Made Some Changes to this song and Cleaned it up a bit. So I figured Why not Upload it. =) I worked Specifically on the Main Synth Melody Line. I think it's sounds a bit smoother now. Thanks Analmux for the Help. =) Sounds great - I really have to get a stereo pokey in my NTSC machine, especially since RMT now plays back at the proper speed. Quote Link to comment Share on other sites More sharing options...
kool kitty89 Posted April 30, 2011 Share Posted April 30, 2011 (edited) Have any of the other versions been uploaded to youtube, or just the first? (it would be nice for comparison) Oh, there it is (well, one video at least) http://www.youtube.com/watch?v=KOE-kAYXvOY Nice It seems the early stereo version was taken down too. Edited April 30, 2011 by kool kitty89 Quote Link to comment Share on other sites More sharing options...
