0
minimum amount of assembly to init suzy and display full screen sprite
2 replies to this topic
#1 Wookie OFFLINE
Wookie
    Chopper Commander
  • 191 posts
Posted Mon Jan 17, 2011 3:13 PM
Assuming the the only initialization of the Lynx is as follows:
	// 1. force Mikey to be in memory
	lda #0
	sta MIKEY_MEMORY_MAP_CONTROL
	// 2. set IODIR the way Mikey ROM does, also force AUDIN to output
	lda #010011
	sta MIKEY_IO_DIRECTION
	// 3. set ComLynx to open collector
	lda #000100
	sta MIKEY_SERIAL_CONTROL
	// 4. make sure the ROM is powered on
	lda #001000
	sta MIKEY_IO_DATA
What would be the minimum amount of assembly to init suzy and display, full screen, a sprite located at 0x0500?  I'm trying to add a simple splash screen to my secondary loader so that something gets on the screen ASAP.  I thought I'd ask you guys since you're all pretty good at this stuff.
(BTW, I could figure this out for myself, but I wanted to see if anybody had a clever way to do this in a minimal amount of code.)
--Wookie
Edited by Wookie, Mon Jan 17, 2011 3:14 PM.
#2 sage OFFLINE
sage
    Dragonstomper
  • 518 posts
Posted Mon Jan 17, 2011 3:46 PM
	lda #0
	lda #010011
	lda #000100
	lda #001000
	sta MIKEY_IO_DATA
--Wookie
-> maybe check the EPYX loader code?
Then you are sure it is working
#3 LX.NET OFFLINE
LX.NET
    Chopper Commander
  • 229 posts
Posted Wed Mar 16, 2011 1:48 PM
	lda #0
	lda #010011
	lda #000100
	lda #001000
	sta MIKEY_IO_DATA
--Wookie
Although I have no actual Lynx programming experience I do know that the Epyx Handy documentation has a set of required steps you need to follow to ensure correct initialization for drawing sprites:
Sprite Initialization
