Topic for newbies
newbies
286 replies to this topic
#226 Calibus OFFLINE
Calibus
    Space Invader
  • 43 posts
Posted Wed Apr 5, 2017 4:29 AM
Hi,
I have an Atari 800XL and I am looking for a flash cart that can handle both cartridge games and floppy based ones.
I found the Side2 here: http://www.lotharek....duct.php?pid=68
But it seems kinda small flash size - 256K?  especially compared to the Ultimate SD Cart - which seems to only support cartridge images.
As someone completely new to the Atari scene - which is more prevalent - cartridge or disk based software?
#227 Philsan OFFLINE
Philsan
  • 3,714 posts
  • New Orleans Saints Super Bowl XLIV Champions
Posted Wed Apr 5, 2017 4:44 AM
If you haven't already done it, please read first post.
Side2 is a Compact flash card based cartridge, so it has no storage limits.
Together with U1MB internal memory expansion, Side2 loads all existing software; unfortunately that solution needs some soldering inside the machine.
Other solutions have pro and cons.
For example, SIO2SD is a good solution, but you cannot load games with more than 64KB unless you have a memory expansion.
#228 Totimato OFFLINE
Totimato
    Combat Commando
  • 5 posts
Posted Thu Oct 12, 2017 2:01 AM
Then use my basic instructions: http://www.santelloc...2sd.htm#english
Hi!
This link is dead.
#229 Philsan OFFLINE
Philsan
  • 3,714 posts
Posted Thu Oct 12, 2017 4:27 AM
#230 ChoccyHobNob OFFLINE
ChoccyHobNob
    Space Invader
  • 33 posts
  • AtariArtist
Posted Fri Oct 27, 2017 6:20 AM
I thought Side2 couldn't load car/rom/cas files, just xex/atr?
#231 Philsan OFFLINE
Philsan
  • 3,714 posts
Posted Fri Oct 27, 2017 9:43 AM
Exactly.
Perhaps Side3 (not yet released) will load them.
#232 ChoccyHobNob OFFLINE
ChoccyHobNob
    Space Invader
  • 33 posts
  • AtariArtist
Posted Fri Oct 27, 2017 9:48 AM
Lotharek's site says atr/xex/rom, so just no cas files, I can live without cas files.
Side3 is the reason I didn't buy a side2 for my 800xl when I got it recently.
#233 Zap! ONLINE
Zap!
  • 1,735 posts
Posted Mon Nov 6, 2017 10:17 PM
OK, I've got a newbie question. I know there are various projects for the A8 where you can put programs from on either an SD or flash (downloaded on your modern computer), and then hook it up to your Atari to run them. These projects are Ultimate Cart, Side 2, SIO, SIO2SD, etc. Some run some program files, some run the other ones. None run all, but Side 3 might (maybe, we don't know yet).
Now, with that being said, does anything allow you to read the 1050 and it's floppies? I want to transfer the content of my floppies onto that devise (Side 2, Sio, etc)? I have so many old programs that aren't even on Atari Mania for download, and would love to preserve them.
#234 Zap! ONLINE
Zap!
  • 1,735 posts
Posted Tue Nov 7, 2017 9:46 PM
^^^ Anyone? Trying to avoid making a separate topic for this. :)
#235 Philsan OFFLINE
Philsan
  • 3,714 posts
Posted Wed Nov 8, 2017 12:55 AM
To copy unprotected floppy, you can use an Atari connected to 1050 and SIO2SD in chain.
#236 SS OFFLINE
SS
  • 6,139 posts
Posted Wed Nov 8, 2017 5:53 AM
I have successfully backed up a couple of my own floppies using my 1050 drive set as drive #2 and my UNO Cart as drive #1.
You can also use a SIO2PC or a SIO2SD to back up floppy disks. If they are commercial disks, however, you might run into some copy protection issues.
#237 Zap! ONLINE
Zap!
  • 1,735 posts
Posted Wed Nov 8, 2017 12:09 PM
Thanks guys, and yes, I'm talking about unprotected floppies. One final question though, because I would prefer not to buy more than one device. None of the carts can do this right, such as Ultimate Cart and Side 2? If the answer is no as I assume it is, any chance Side 3 will do it all?
#238 SS OFFLINE
SS
  • 6,139 posts
Posted Wed Nov 8, 2017 12:53 PM
Right now the UNO Cart is the closest to being able to do it all but its ATR support is not perfect. I'd wager that the UNO Cart has been able to handle about 2/3 of the ATRs that I've thrown at it, *almost* all of the XEX files, and just about 100% of the CAR images. Side 3 might be the best bet for all around support but there is very little information about it at the moment and no real timeframe of when we might expect to see it available for purchase either.
#239 Philsan OFFLINE
Philsan
  • 3,714 posts
Posted Wed Nov 8, 2017 1:04 PM
A cheap SIO2XX device (for example $20 SIO2PC-USB) is a good investment; it's the only device that emulates perfectly a disk drive and with it (and a memory expansion) you can load all software (executables versions of carts are available).
Eventually you can buy a cart, to quickly load a big part of the software without memory expansions.
#240 _The Doctor__ OFFLINE
_The Doctor__
  • 5,532 posts
Posted Wed Nov 8, 2017 1:09 PM
I think newbies should get boost points for reading/using the newbie topic and search functions first!
#241 dmsc OFFLINE
dmsc
    Moonsweeper
  • 441 posts
Posted Wed Nov 8, 2017 7:16 PM
Hi!
I would add to the first post a reference to RespeQt, instead of AspeQT, and also the cheap sio2pc-usb options available today.
#242 Philsan OFFLINE
Philsan
  • 3,714 posts
Posted Sat Nov 11, 2017 2:18 AM
If you help me posting infos and links, I can update first post.
For example, what are differences between RespeQt and AspeQt? Are they compatible so I can add RespeQt near AspeQt?
#243 dmsc OFFLINE
dmsc
    Moonsweeper
  • 441 posts
Posted Sat Nov 11, 2017 9:04 PM
Hi!
Yes, RespeQt is based on AspeQt code with further fixes and additions, developed as open source. You can download over github for Windows/MacOS/Linux https://github.com/j...espeQt/releases
There is also a dedicated forum here in AA: http://atariage.com/...io2pc-software/
About the DIY cheap SIO2PC-USB cables, I think that this video is good:
The USB serial cable can be purchased cheap, see for example: https://www.aliexpre...1858974923.html
#244 Philsan OFFLINE
Philsan
  • 3,714 posts
Posted Sun Nov 12, 2017 4:13 PM
First post updated, thanks.
I knew Nir's video but I I had not thought of putting it in the first post.
Keep up the good work on FastBasic!
#245 Mclaneinc OFFLINE
Mclaneinc
  • 6,042 posts
Posted Mon Nov 13, 2017 7:44 AM
For those that do backup their collection and don't mind sharing it, I beg you to make a thread in the standard forum to let people know, as said in the thread, you just might have some stuff that's not been found so far..
Paul..
#246 Zap! ONLINE
Zap!
  • 1,735 posts
Posted Mon Nov 13, 2017 10:05 PM
Paul..
Great idea!
#247 Schmudde OFFLINE
Schmudde
    Chopper Commander
  • 198 posts
Posted Tue Dec 19, 2017 1:08 PM
I'm looking for a manual for Go and unfortunately, we don't have them here at Atari Age like we do for the 2600/7800/5200/Lynx/Jaguar. It would be nice to list sources for manuals in the newbie section. So far, I've checked archive.org's section and Atarimania without luck, but there may be other repositories. Manuals can still be useful sources of information for newbies.
#248 Philsan OFFLINE
Philsan
  • 3,714 posts
Posted Sun Feb 18, 2018 5:42 AM
In the last weeks many users asked what are the best A8 homebrews.
It's a hard question for every platform. You have to follow the scene closely to reply.
So I decided to add "4. Best homebrews?".
Everyone of us has his point of view but I think KazKompo best game of the year contest is a good objective starting point to know the best ones.
In the latest months I found that people is amazed by A8 Rastaconverter generated pictures. No other contemporary computer can match those results.
So I added "8. Graphic capabilities" too.
#249 CharlieChaplin OFFLINE
CharlieChaplin
  • 2,951 posts
Posted Thu Feb 22, 2018 6:31 PM
At the end of point 4. Best homebrews you write: "You can download them in the "4. Where to find software?" websites."
Small correction: You can download them at the "3. Where to find software" websites.
And some nitpicking: You added "7. Graphic capabilities" (not 8.)...   ;-)
But your topic for newbies is great !! Quite often, when a newbie Atari owner turns up at Abbuc forum, I give links to the Abbuc newbie section (Tipps für Einsteiger), which explains how to connect the Atari and the Atari peripherals (disks, tapes, etc.), how to load programs from the peripherals, etc. - and also link to your topic for newbies, which explains what Atari models (and keyboards) are available, what modern peripherals are available and much much more...
#250 Philsan OFFLINE
Philsan
  • 3,714 posts
Posted Sat Feb 24, 2018 2:01 AM
Thank you Andreas!
Also tagged with one or more of these keywords: newbies
