S1500 Posted February 15, 2011 Share Posted February 15, 2011 How hard would it be, whether XB or assembly, to have a program make a totally random "CALL CHAR" to a character and cycle through random variants really fast? We've seen this before in tons of games where it just randomly turns off & on pixels to signify static on a TV or an explosion. I'd love to see a TI do that instead of pre-defined 8x8 pixel junk graphics. Quote Link to comment Share on other sites More sharing options...
Opry99er Posted February 15, 2011 Share Posted February 15, 2011 That would be pretty easy to do. =) In assembly you could randomize and use hex. Since BASIC doesn't understand hex as numeric (for the most part) it would be quite a bit slower, but fun anyway. I bet Karsten or Marc Hull has something to show on this... give them just a minute or two. =) Probably by the time I'm done posting this response, the ol' Hullinator will have it whipped up. Quote Link to comment Share on other sites More sharing options...
+adamantyr Posted February 15, 2011 Share Posted February 15, 2011 How hard would it be, whether XB or assembly, to have a program make a totally random "CALL CHAR" to a character and cycle through random variants really fast? We've seen this before in tons of games where it just randomly turns off & on pixels to signify static on a TV or an explosion. I'd love to see a TI do that instead of pre-defined 8x8 pixel junk graphics. TI BASIC and Extended BASIC are slow... neither are particularly good at animation this way, you can see the "wipe" effect as the old pattern overwrites the new one. Very easy in assembly, using a random routine to pad out an 8-byte value. This would create an extremely "chaotic" pattern that wildly changes rapidly. A trickier one is to have the pattern change in an incremental fashion... having it stay more or less the same but only have a few pixels change value at a time. Off the top of my head, the easiest way to do this is to create a random "bit mask" with very sparse changes, and then apply it with an XOR over top the old pattern so that it only gradually changes a few pixels at a time to different bit values. Adamantyr Quote Link to comment Share on other sites More sharing options...
sometimes99er Posted February 16, 2011 Share Posted February 16, 2011 (edited) Here's a demo cartridge that does just that. It was named "no signal". A followup was named "television". Edit: Oops, the television demo does not work with Classic99. Works fine with Win994a and MESS. I probably have to revisit the source and do a complete VDP register set or something. Edited February 16, 2011 by sometimes99er Quote Link to comment Share on other sites More sharing options...
lucien2 Posted February 16, 2011 Share Posted February 16, 2011 I coundn't resist. I need some assembly practice. STATIC.zip DEF START REF VSBW,VMBW,VWTR,KSCAN WS1 BSS 32 RNDPTN BSS 10 SEED EQU >83C0 STATUS EQU >837C SAVRTN DATA 0 NOISE BYTE >05,>9F,>BF,>DF,>E4,>F0,254 BYTE >01,>FF,0 START MOV R11,@SAVRTN LWPI WS1 * SOUND TABLE -> VDP LI R0,>1800 LI R1,NOISE LI R2,10 BLWP @VMBW * COLORS LI R0,>0713 BLWP @VWTR LI R0,>380 LI R1,>1F00 L1 BLWP @VSBW INC R0 CI R0,>400 JLT L1 * SCREEN CLR R5 L8 LI R0,30 BL @RAND CLR R1 MOV R0,R1 AI R1,65 SWPB R1 MOV R5,R0 BLWP @VSBW INC R5 CI R5,32*24 JLT L8 * RANDOM PATTERNS (CHARS 0..29) LI R6,>1000 L5 LI R5,30 L4 LI R4,RNDPTN L3 LI R0,>100 BL @RAND SWPB R0 MOVB R0,*R4+ CI R4,RNDPTN+8 JLT L3 MOV R5,R0 DEC R0 AI R0,65 SLA R0,3 A R6,R0 LI R1,RNDPTN LI R2,8 BLWP @VMBW DEC R5 JNE L4 CI R6,>1000 JNE L6 LI R6,>800 LI R0,>0402 BLWP @VWTR JMP L2 L6 LI R6,>1000 LI R0,>0401 BLWP @VWTR * START SOUND L2 MOVB @>83CE,@>83CE JNE L7 LIMI 0 LI R0,>1800 MOV R0,@>B000 MOV R0,@>83CC LI R1,>0100 SOCB R1,@>83FD MOVB R1,@>83CE LIMI 2 * KEYBOARD L7 LIMI 2 LIMI 0 BLWP @KSCAN MOVB @STATUS,R0 ANDI R0,>2000 JEQ L5 * QUIT LI R0,>0401 BLWP @VWTR MOV @SAVRTN,R11 CLR @STATUS RT RAND LI R1,>6EF5 MPY @SEED,R1 AI R2,>7AB9 MOV R2,@SEED CLR R1 SWPB R2 DIV R0,R1 MOV R2,R0 RT Quote Link to comment Share on other sites More sharing options...
matthew180 Posted February 16, 2011 Share Posted February 16, 2011 I coundn't resist. I need some assembly practice. RAND LI R1,>6EF5 MPY @SEED,R1 AI R2,>7AB9 MOV R2,@SEED CLR R1 SWPB R2 DIV R0,R1 MOV R2,R0 RT You might want to check out this thread: http://www.atariage.com/forums/topic/163646-not-prime/ You can get a much faster, and smaller, random number routine. Quote Link to comment Share on other sites More sharing options...
lucien2 Posted February 16, 2011 Share Posted February 16, 2011 You can get a much faster, and smaller, random number routine. Thank you. I've been using the same random number generator fin my assembly programs for about 25 years now, and I got it straight from the Tombstone City code that came with the E/A package. I actually found it the ROM (TI-99/4A Intern Book) in the GPL interpreter. But I made a typing error it is >6FE5, not >6EF5. Also, the code above has the non random feature of producing an odd number, then even, then odd, then even, etc. Not very random. I saw that in my exemple. I first used 4 random words and they were fixed lines on the screen. Then I used 8 random bytes and it worked. Quote Link to comment Share on other sites More sharing options...
Tursi Posted February 18, 2011 Share Posted February 18, 2011 Edit: Oops, the television demo does not work with Classic99. Works fine with Win994a and MESS. I probably have to revisit the source and do a complete VDP register set or something. Huh.. so it doesn't! If you ever figure out why let me know! Quote Link to comment Share on other sites More sharing options...
Bones-69 Posted February 21, 2011 Share Posted February 21, 2011 Little XB effort.... 100 ! XBSTATIC 110 DIM A$(16) :: RANDOMIZE 120 FOR I=1 TO 16 :: READ A$(I) :: NEXT I :: FOR I=1 TO 9 :: FOR D=1 TO 16 :: B$(I)=B$(I)&A$(RND*15+1) :: NEXT D :: NEXT I 130 CALL CLEAR :: CALL COLOR(1,16,2) :: CALL SCREEN(2) 140 FOR I=1 TO 9 :: CALL COLOR(1,2,16) :: CALL CHAR(32,B$(I)) :: CALL COLOR(1,16,2) :: NEXT I :: GOTO 140 150 DATA 0,1,2,3,4,5,6,7,8,9,A,B,C,D,E,F Quote Link to comment Share on other sites More sharing options...
sometimes99er Posted February 21, 2011 Share Posted February 21, 2011 Little MiniMem tryout ... 100 CALL CLEAR 110 CALL SCREEN(16) 120 FOR A=1024 TO 1031 130 CALL POKEV(A,RND*256) 140 NEXT A 150 GOTO 120 Quote Link to comment Share on other sites More sharing options...
sometimes99er Posted February 21, 2011 Share Posted February 21, 2011 Xenon on tms9918a http://www.youtube.com/watch?v=e6FJxFtZ63k Quote Link to comment Share on other sites More sharing options...
matthew180 Posted February 21, 2011 Share Posted February 21, 2011 Wow! That's fantastic. I'd love to see a break down of the graphics. Quote Link to comment Share on other sites More sharing options...
Fishsta Posted February 22, 2011 Share Posted February 22, 2011 I did this program as a "Basic Musing". With it I made 10 random Char strings. Obviously TI Basic cycles too slowly to make any decent attempt at making it look like white noise. Alright, my knowledge of TI BASIC is a bit limited, but it was flooding back somewhat with typing old listings. WHTENOIZ.zip 1 Quote Link to comment Share on other sites More sharing options...
