flashjazzcat Posted December 4, 2011 Share Posted December 4, 2011 I'm quite surprised Mathy wasn't beta testing this. Quote Link to comment Share on other sites More sharing options...
Marius Posted December 4, 2011 Share Posted December 4, 2011 Sorry for bringing this whole blackbox related issue up. I have chosen to use U1MB without blackbox on my other Atari Setup. For reasons described above I'm not going to take a risk with my BlackBox. I'm the only one that suffers from this issue, so everyone could let it rest by now. Without the BlackBox U1MB works like a charm, and it's a fabulous upgrade. I'm wondering how many BlackBox owners also did order this U1MB upgrade. I think that amount of people is not that high. Anyway: concentrate on other things candle. It is not important (anymore). Good luck and thanks a lot for all your support! Marius Quote Link to comment Share on other sites More sharing options...
Dropcheck Posted December 9, 2011 Share Posted December 9, 2011 Hi Candle, I've managed to loose those resistors you sent. Those darn things just got up and walked off. Probably with a little bit of help my feline helper. I've got a couple days off and I was going to install the board. Need to know what their value was. I should be able to subsitute from my parts bin. Thanks, Quote Link to comment Share on other sites More sharing options...
+Larry Posted December 9, 2011 Share Posted December 9, 2011 Have you checked in the litter box? (Yuck!) -Larry Hi Candle, I've managed to loose those resistors you sent. Those darn things just got up and walked off. Probably with a little bit of help my feline helper. I've got a couple days off and I was going to install the board. Need to know what their value was. I should be able to subsitute from my parts bin. Thanks, Quote Link to comment Share on other sites More sharing options...
Dropcheck Posted December 9, 2011 Share Posted December 9, 2011 Have you checked in the liter box? (Yuck!) -Larry Hi Candle, I've managed to loose those resistors you sent. Those darn things just got up and walked off. Probably with a little bit of help my feline helper. I've got a couple days off and I was going to install the board. Need to know what their value was. I should be able to subsitute from my parts bin. Thanks, I would really NOT like to dig through it. Quote Link to comment Share on other sites More sharing options...
candle Posted December 9, 2011 Author Share Posted December 9, 2011 anything in value between 100 and 220 ohms will do Quote Link to comment Share on other sites More sharing options...
Rybags Posted December 9, 2011 Share Posted December 9, 2011 220 Ohms - red, red, brown. That's for my kit, 800XL. I'd guess they should all be the same. Quote Link to comment Share on other sites More sharing options...
Dropcheck Posted December 9, 2011 Share Posted December 9, 2011 Quote Link to comment Share on other sites More sharing options...
Roydea6 Posted December 9, 2011 Share Posted December 9, 2011 Is there anything posted yet about installation into the XE line of computers? I can only find pictures and connection points for the XL computers. Quote Link to comment Share on other sites More sharing options...
enito Posted December 9, 2011 Share Posted December 9, 2011 hehe me too im waiting the howto for 130xe..hope this guide come soon...greets Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted December 9, 2011 Share Posted December 9, 2011 I'm just waiting for something to be posted. 1 Quote Link to comment Share on other sites More sharing options...
Rybags Posted December 11, 2011 Share Posted December 11, 2011 Pretty much done, although I didn't do the wiring for D6/D7 VBXE select. Couple of notes: - my PBI clip fouls against the wiring soldered near the PBI connector. People with thru vias rather than pads mightn't have the same problem. So, I'm just grinding off some of the clip now with a 240V cheap Dremel clone. - for those with VBXE you'll need to find another source for CASINH if yours gets it from the MMU. I just grabbed it from a pad near the PBI. - once again VBXE owners, make sure you have a non-RAMBO core enabled (I forgot to do this, so off to fix that now) Quote Link to comment Share on other sites More sharing options...
candle Posted December 11, 2011 Author Share Posted December 11, 2011 Gary, there are no pads in places of vias - they are just vias filled with solder if you set vbxe core to rambo, then ultimate memory will map and vbxe memory won't - there will be no clash on system bus, and nothing wrong will happend Quote Link to comment Share on other sites More sharing options...
Rybags Posted December 11, 2011 Share Posted December 11, 2011 (edited) Forgot to mention - the annoying Phi 2 glitches have gone, they were due to the 32in1 OS which I'll now probably put in my 600XL or maybe a 130XE. Also, the Diagnostic OS... it gives weird results. Regardless of RAM scheme it reports the same. Ran just then, it's getting 55,000 something. Pretty sure it was 65,536 with IDE Plus 2 removed. One question... is there a utility for setting the RTC ? I probably won't use it, or the SpartaDos due to IDE Plus 2 having both, but it'd be nice to set it though. Just checked the reference page... the interface to RTC is via an SPI link ? OK... got the clock set, just disable IDE+2 and enable U1Meg. Date display on config screen shows the wrong day... "Sat 11-12-2011" Edited December 11, 2011 by Rybags Quote Link to comment Share on other sites More sharing options...
candle Posted December 11, 2011 Author Share Posted December 11, 2011 thats because sdx rtc driver setting it incorrectly was mentioned before diagnostics got never done, so it will show only base ram it won't ever show 65536 bytes, - you have 2k wasted on hw register space it will show 56k with basic or any other cartridge enabled (including internal sdx) Quote Link to comment Share on other sites More sharing options...
Mathy Posted December 11, 2011 Share Posted December 11, 2011 Hello Jon I'm quite surprised Mathy wasn't beta testing this. Sorry, I can no longer resist asking: What were you expecting me to beta-test? Mathy Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted December 11, 2011 Share Posted December 11, 2011 Sorry, I can no longer resist asking: What were you expecting me to beta-test? Why hesitate? I was (presumably incorrectly) under the impression that there were Ultimate 1MB boards out in the field, being beta tested with hardware configurations unavailable to the original designer. I was expressing surprise that you weren't one of these imagined beta-testers. Quote Link to comment Share on other sites More sharing options...
Mathy Posted December 11, 2011 Share Posted December 11, 2011 Hello Jon I haven't done anything on the Atari in years, except for those two weekends a year they call NOMAM and Fujiama. So I'm not doing any testing at the moment (except patience :-) ). The U1MB doesn't have separate ANTIC and CPU access in 1MB mode, one for the reason I developed my own upgrade, plus the U1MB has SD(X) on board. That's two reasons why the U1MB isn't "my thing". Mathy Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted December 11, 2011 Share Posted December 11, 2011 I haven't done anything on the Atari in years, except for those two weekends a year they call NOMAM and Fujiama. So I'm not doing any testing at the moment (except patience :-) ). The U1MB doesn't have separate ANTIC and CPU access in 1MB mode, one for the reason I developed my own upgrade, plus the U1MB has SD(X) on board. That's two reasons why the U1MB isn't "my thing". Ah - no problem Mathy. Sorry for the misunderstanding. Quote Link to comment Share on other sites More sharing options...
sloopy Posted December 11, 2011 Share Posted December 11, 2011 (edited) This is where i connected the wires for my U1MB... and dont mount the U1MB where i did, the hole in the pic next to the AV jack is where the right mount post is supposed to go. The other mount is supposed to go in a hole drilled between the power switch and power jack... (the unlabeled wire is A4, and isnt for the U1MB...) edit: NOTE- THE GREY (not BROWN) WIRE AND THE PINK WIRE ARE LABELED BACKWARDS IN THE ABOVE PICTURE!!! edit: THE GREY WIRE IS R/W, PINK WIRE IS RST... and the wires in the connector on the U1mb are green, grey, pink, and blue, top to bottom... sloopy. Edited January 9, 2012 by sloopy Quote Link to comment Share on other sites More sharing options...
Roydea6 Posted December 12, 2011 Share Posted December 12, 2011 This is where i connected the wires for my U1MB... and dont mount the U1MB where i did, the hole in the pic next to the AV jack is where the right mount post is supposed to go. The other mount is supposed to go in a hole drilled between the power switch and power jack... (the unlabeled wire is A4, and isnt for the U1MB...) sloopy. Are there any traces to cut on the 130xe as there are in the 800xl.? Quote Link to comment Share on other sites More sharing options...
candle Posted December 12, 2011 Author Share Posted December 12, 2011 today Roy i was ill past week, so not much got done Quote Link to comment Share on other sites More sharing options...
sloopy Posted December 12, 2011 Share Posted December 12, 2011 This is where i connected the wires for my U1MB... and dont mount the U1MB where i did, the hole in the pic next to the AV jack is where the right mount post is supposed to go. The other mount is supposed to go in a hole drilled between the power switch and power jack... (the unlabeled wire is A4, and isnt for the U1MB...) sloopy. Are there any traces to cut on the 130xe as there are in the 800xl.? YES! from what i understand they need to be done now matter the machine the U1MB is installed into, or the U1MB will be broken... sloopy. Quote Link to comment Share on other sites More sharing options...
sloopy Posted December 12, 2011 Share Posted December 12, 2011 today Roy i was ill past week, so not much got done Glad your feeling better :') sloopy. Quote Link to comment Share on other sites More sharing options...
candle Posted December 14, 2011 Author Share Posted December 14, 2011 (edited) need to learn something more about making menus/tabs whatever before i'll have it organised better, but here it is whats essentian to whole XE line: XE installation guide and this is how it should look like when installed Sebastian Edited December 14, 2011 by candle Quote Link to comment Share on other sites More sharing options...
