cc65 cfg-file has changed in the svn
No replies to this topic
#1 karri OFFLINE
karri
  • 1,774 posts
Posted Tue Mar 22, 2011 11:52 PM
This is just a small note that the latest lynx.cfg changes may break some old projects.
What has happened is that I split up the executable header into 3 parts:
exehdr.s part that contains the lnx header for handy
bootldr.s that contains a new bootloader following Wookies ideas
defdir.s that contains a default directory.
Any of these parts can be replaced by your own code.
But in order to use these you need to modify the cfg files.
SYMBOLS {
    __STACKSIZE__: type = weak, value = $0800; # 2k stack
    __STARTOFDIRECTORY__: type = weak, value = $00DF; # start just after loader
    __BLOCKSIZE__: type = weak, value = 1024; # cart block size
    __EXEHDR__:    type = import;
    __BOOTLDR__:   type = import;
    __DEFDIR__:    type = import;
MEMORY {
    ZP:     file = "", define = yes, start = $0000, size = $0100;
    HEADER: file = %O,               start = $0000, size = $0040;
    BOOT:   file = %O,               start = $0200, size = __STARTOFDIRECTORY__;
    DIR:    file = %O,               start = $0000, size = 8;
    RAM:    file = %O, define = yes, start = $0200, size = $BE38 - __STACKSIZE__;
SEGMENTS {
    EXEHDR:   load = HEADER, type = ro;
    BOOTLDR:  load = BOOT,   type = ro;
    DIRECTORY:load = DIR,    type = ro;
If you leave out a line like
then you can create your own directory instead with whatever you want to put in the rom.
These "type = import" will drag in the cc65 compiler default code for various code segments.
So to create a BLL download compatible binary you can do this instead:
SYMBOLS {
    __BLLHDR__:    type = import;
MEMORY {
    HEADER: file = %O,               start = $0000, size = $000a;
    RAM:    file = %O, define = yes, start = $0400, size = $BC38 - __STACKSIZE__;
SEGMENTS {
    BLLHDR:   load = HEADER, type = ro;
The new compiler includes 3 built-in cfg files already:
- normal dual-buffered -C lynx-cfg
- collision detection + dual-buffered -C lynx-coll.cfg
- downloadable BLL binary -C lynx-bll.cfg
Karri
Edited by karri, Tue Mar 22, 2011 11:55 PM.
