monsoft Posted November 16, 2018 Share Posted November 16, 2018 But only kernel + init was implemented and nothing more And there is no way to load anything more as I/O was not ported according to notes in Kernel README file. So it was nice try but unfortunately abandoned long time ago. I was also trying to compile version 0.21 under Debian but looks like there is some issue with "atari/keyboard.s" kernel file: luna -qOo keyboard.o keyboard.s In file atari/keyboard.s Included from keyboard.s atari/keyboard.s:11: invalid expression atari/keyboard.s:11: byte out of range 2 Errors, stopped after pass 2 Makefile:38: recipe for target 'keyboard.o' failed so no luck Quote Link to comment Share on other sites More sharing options...
Juraj Posted August 5, 2023 Share Posted August 5, 2023 Hi @monsoft it's five years later But i found your post and find solution. you have to fix line 11 in atari/keyboard with following code then compile with make, make packages,make dist, i am now working on apps to get it running on atari800 xl emulator locktab: .byte keyb_ctrl, %10000000, keyb_caps, keyb_ex3 1 Quote Link to comment Share on other sites More sharing options...
_The Doctor__ Posted August 5, 2023 Share Posted August 5, 2023 31 minutes ago, Juraj said: Hi @monsoft it's five years later But i found your post and find solution. you have to fix line 11 in atari/keyboard with following code then compile with make, make packages,make dist, i am now working on apps to get it running on atari800 xl emulator locktab: .byte keyb_ctrl, %10000000, keyb_caps, keyb_ex3 can you post up the final working version for running directly on real Atari 8 bit? Quote Link to comment Share on other sites More sharing options...
