Nonogram - game released
game assembler cartridge
128 replies to this topic
#76 matthew180 OFFLINE
matthew180
  • 2,606 posts
Posted Thu Sep 15, 2011 7:18 AM
I like the tube, especially the bubble! But I hope the ultimate game will not have a timer? The pressure, man, the pressure!! :P
I'm the slow and methodical type, and I usually blow any kind of time limits in games. But hey, this is not about me. ;)
#77 InsaneMultitasker OFFLINE
InsaneMultitasker
  • 2,365 posts
Posted Thu Sep 15, 2011 6:16 PM
Here's trying out some rollin' eyes.
Posted Image
Maybe it could stare at you, and then look down on the board from time to time. When time is running out, it could start rollin' its eyes. I'll drop the blinking completely. A lot of "older" cartoons (stop motion) didn't have blinking, so I guess it won't be that "unnatural".
You could always close/open the eyelids based on how much time is left or make them bloodshot when time expired :twisted:
#78 sometimes99er OFFLINE
sometimes99er
  • 4,204 posts
Posted Sat Sep 17, 2011 12:33 AM
Thanks for feedback.
Okay, I basically rearranged a few things and added stuff. No additional code. Binary attached.
  • Palette changed
  • Font changed
  • Logo changed
  • Eyeballs and pupils added
  • Bubble added
Other than that, I'm playing with a few ideas and tested old and new puzzles.
Edited by sometimes99er, Sat Jan 7, 2012 6:53 PM.
#79 sometimes99er OFFLINE
sometimes99er
  • 4,204 posts
Posted Mon Oct 3, 2011 6:15 AM
Ah man, time flies. Thought I could find an hour here and there to do the things that would make it something I'd release into the contest, but no. Sorry.
Edited by sometimes99er, Sun Aug 30, 2015 6:17 AM.
#80 sometimes99er OFFLINE
sometimes99er
  • 4,204 posts
Posted Mon Sep 7, 2015 2:36 AM
Version 0.1
[attachment=409482:nonoc.bin]
[attachment=409481:nono.rpk]
[attachment=409480:nono.obj] Program name: NONO
[attachment=409479:nono.dsk] File and program name: NONO
So I'm breathing new life into this one.
When it comes to code and design, I'm taking one step back. Much on the back of mineSweeper. I was definitely going for something more action oriented (game project), but we'll cram this one in.
Instructions
Nothing much you can do. You can move the cursor around using ESDX and IJKL. And you can select different sized levels with the keys 1, 2 and 3.
Edited by sometimes99er, Wed Oct 21, 2015 4:18 AM.
#81 Willsy OFFLINE
Willsy
  • 3,100 posts
Posted Mon Sep 7, 2015 3:19 AM
This would be good for Forth. TurboForth or fbForth. You could draw the puzzles in the block editor and load them in at runtime. Logic in the software would then analyse the rows and columns.
Nice idea. :thumbsup:
#82 sometimes99er OFFLINE
sometimes99er
  • 4,204 posts
Posted Wed Sep 9, 2015 3:24 AM
Version 0.2
[attachment=409804:nonoc.bin]
[attachment=409803:nono.rpk]
[attachment=409802:nono.obj] Program name: NONO
[attachment=409801:nono.dsk] File and program name: NONO
What's new
Each level, picture or puzzle is represented in memory as a series of words (16 bits). The first puzzle is a 5 by 5 cell picture, and is represented by 5 words. I was going to allow individual sizes of height and width for each puzzle, but now height and width is always the same. Also, due to the source of puzzles, and I guess for learning curve and increased difficulty, it will only have 5 by 5, 10 by 10 and finally 15 by 15 cell picture puzzles. In the end I may fine tune or totally change several of the puzzles to be more TI related.
So this update includes a routine for calculating and displaying row numbers. Also a routine for making the cursor bits flash.
Instructions
Still not a lot you can do. You can move the cursor around using ESDX and IJKL. And you can select different sized levels with the keys 1, 2 and 3.
#83 sometimes99er OFFLINE
sometimes99er
  • 4,204 posts
Posted Thu Sep 10, 2015 3:00 AM
Version 0.3
[attachment=409996:nonoc.bin]
[attachment=409995:nono.rpk]
[attachment=409994:nono.obj] Program name: NONO
[attachment=409993:nono.dsk] File and program name: NONO
News
For calculating the row numbers I use SRL (Shift Right Logical). And now for the columns I'm using SZC (Set Zeros Corresponding).
Again I've chosen not to use the 32K Expansion Memory, so no easy internal roll out of pixels in RAM. Puzzles are stored in ROM and at all times referenced therefrom. The bone of a 15 by 15 cell puzzle occupies 30 bytes. A 5 by 5 takes 10 bytes.
This update also includes routines for painting and marking. And timer is functional, but that's all.
Instructions
You move the cursor around using ESDX and/or IJKL. You can paint with Q key. You can mark with W. And you can still select different sized puzzles using 1, 2 and 3. And Fctn Quit works too.
Future stuff
Obviously we need to add a routine for checking if the puzzle is solved, ability to proceed etc.
#84 sometimes99er OFFLINE
sometimes99er
  • 4,204 posts
Posted Fri Sep 11, 2015 3:17 AM
I tried changing the cursor blinking from white, gray and black to white, the red colors and black, and finally leaving out the black. Also with different delays. Went back to what we already got.
Routine for checking if a puzzle is solved, is coming along nicely. Been interrupted too many times in this session to actually finish it.
As a rather lazy solution, I thought I would use the timer to simply time how long it would take you to solve all puzzles. And I think I would try and fit 64 puzzles in there. That would then easily take you an hour to complete the game. - Now I was thinking about introducing / reintroducing the tube. The one with bubbles in the fluid (see post #75). So if you didn't finish the puzzle in time, before the fluid ran out, it would ... restart the game, or the level, or something. Maybe random amounts of fluid per level. Maybe I should leave 'stress' out all together. You just play as far as you want and that's that. Your achievement is what level you made. Yeah well, of course there should be an on-screen prize for completing the game.
:party:
#85 sometimes99er OFFLINE
sometimes99er
  • 4,204 posts
Posted Sat Sep 12, 2015 12:58 AM
Keys 1, 2 and 3 removed. That was just handy for testing different sized puzzles.
Key R added. Whenever you think you've screwed up big time, you can easily reset the current puzzle.
Key Enter added. Whenever you've solved a puzzle, and want to proceed to the next.
This session ended with requirements definition of what happens when a puzzle is solved. Cursor will be deactivated, colors and characters will change, numbers are cleared, messages are displayed, timer is paused, and maybe it's time for a sound-effect.
#86 sometimes99er OFFLINE
sometimes99er
  • 4,204 posts
Posted Sat Sep 12, 2015 2:59 AM
Playtesting level 22. Video capture and then last frame mockup. Tried magenta as background, then changed it to dark green. More easy on the eye, I think.
#87 sometimes99er OFFLINE
sometimes99er
  • 4,204 posts
Posted Sun Sep 13, 2015 5:48 AM
Version 0.4
[attachment=410418:nonoc.bin]
[attachment=410417:nono.rpk]
[attachment=410416:nono.obj] Program name: NONO
[attachment=410415:nono.dsk] File and program name: NONO
News
Fully playable. Crashes when you get beyond level 33.
Instructions
Movement: ESDX or IJKL
Paint: Q
Mark: W
Reset: R
Quit: Fctn Quit
Future stuff
Sounds. More levels. Splash screen. Surprise thing when all puzzles are solved.
Edited by sometimes99er, Sun Sep 13, 2015 5:50 AM.
#88 Opry99er OFFLINE
Opry99er
  • 10,607 posts
Posted Sun Sep 13, 2015 7:17 AM
I have never seen this game before. :)
What a fascinating concept!
#89 ralphb OFFLINE
ralphb
    Dragonstomper
  • 626 posts
Posted Sun Sep 13, 2015 8:07 AM
News
Fully playable.
Awesome!  This is my favorite puzzle game (much more fun than Sudoku), and your version plays really well.
My only suggestion would be to make the cursor blink somewhat less ... aggressively ...  after a while it's making me really nervous.  :mad:
#90 sometimes99er OFFLINE
sometimes99er
  • 4,204 posts
Posted Sun Sep 13, 2015 9:14 AM
Thanks. :)
Regarding the cursor. Yes, there must be something, and I guess I maybe got used to it, as it is. A few days ago I tried more subtle color changes, in the so called blinking, but reverted back. And I guess we react differently to rapid changes in light, colors, sounds etc. Well, bottom-line, I'll try out a few other ideas.
#91 sometimes99er OFFLINE
sometimes99er
  • 4,204 posts
Posted Thu Sep 17, 2015 1:11 PM
Version 0.5
[attachment=411085:nonoc.bin]
[attachment=411084:nono.rpk]
[attachment=411083:nono.obj] Program name: NONO
[attachment=411082:nono.dsk] File and program name: NONO
News
Sounds. More levels. Splash screen. Cursor blinking can be turned off.
Instructions
Paint: Q
Mark: W
Reset: R
Blinking on/off: B
Enter: Next puzzle when solved
Quit: Fctn Quit
#92 Opry99er OFFLINE
Opry99er
  • 10,607 posts
Posted Tue Sep 22, 2015 7:49 AM
Nonogram takes #4 in the weekly pre-NES top 10 in the game tracker this week. :) #9 in the overall weekly tracker.
#93 sometimes99er OFFLINE
sometimes99er
  • 4,204 posts
Posted Tue Sep 22, 2015 9:02 AM
Excellent. Thanks.  :thumbsup:
It's kind of fun to keep track of your own playtime. The overall totals etc. has to be taken with a grain of salt, but very nice to have someone do the statistics and it generates a bit of activity here and there. Nice.
#94 sometimes99er OFFLINE
sometimes99er
  • 4,204 posts
Posted Tue Sep 22, 2015 9:19 AM
Here are my times for this past week (September 14th through 20th)...
Online (non-eligible):
Nonograms - 205 minutes in 3 sessions
Nonogram solver - 22 minutes
TI-99:
Nonogram - 163 minutes in 3 sessions
This week I dealt exclusively with Nonograms, which is some kind of puzzle where you get a grid and on its left and top side you get numbers denoting strips of filled cells which run down or to the right, but aren't allowed to overlap or even touch (at least one blank field must be in between). Sometimes99er, the author of TI-99 Minesweeper, also has made a TI-99 version of this game, and basically I solved all the puzzles in his version. I also tried some nonograms on an online site, but the best thing I get are 15x15 grids. On larger grids, I didn't manage to actually solve one. I tried a "puzzle of the week" which is 30x30, and after 86 minutes, I had the majority of it solved, but I had thrown in a mistake somewhere, so it didn't work out, and I gave up and left it to an online Nonogram solver. However, I also attempted to do a Nonogram of my own which is 14x14 and shown below (without the solution!), Can you find out what it is? :-)
See original post and the puzzle mentioned in the game tracker post #639.
I solved it. Copied the picture to a graphic editor, had a fat marker, red and blue, with the right and left mouse buttons. Very nice.
Spoiler
And very big thanks to Kurt for playing my games extensively and going the extra mile.
#95 sometimes99er OFFLINE
sometimes99er
  • 4,204 posts
Posted Sat Oct 3, 2015 2:11 AM
Streamlining and playtesting. 5 cell markers made a bit longer. About 10 puzzles removed. 5 puzzles moved around. Will try and adapt some iconic TI graphics into puzzles.
If you have an idea for a puzzle or a ready made one, please post here or send me a message (at AtariAge).
Edited by sometimes99er, Sat Oct 3, 2015 2:24 AM.
#96 sometimes99er OFFLINE
sometimes99er
  • 4,204 posts
Posted Wed Oct 21, 2015 4:17 AM
Added option for choosing color of cursor (and guides).
Deleted and added puzzles. Now adding classic TI-99/4A images as puzzles.
#97 sometimes99er OFFLINE
sometimes99er
  • 4,204 posts
Posted Thu Nov 12, 2015 7:07 AM
Version 1.0
[attachment=419964:nonoc.bin]
[attachment=419963:nono.rpk]
[attachment=419962:nono.obj] Program name: NONO
[attachment=419961:nono.dsk] File and program name: NONO
News
End of game screen.
Puzzle flow fine-tuned.
Added a few puzzles from classic TI games.
Added Kurt's puzzle.
Instructions
Movement: ESDX and IJKL
Paint: Q
Mark: W
Reset puzzle: R
Blinking on/off: B
Next color when blinking off: N
Next puzzle when solved: Enter
Quit: Fctn Quit
#98 neglectoru OFFLINE
neglectoru
    Star Raider
  • 67 posts
Posted Fri Nov 13, 2015 6:03 PM
Picross / griddlers / nonograms are perhaps my favorite kind of puzzle. Thanks so much for this release!
#99 sometimes99er OFFLINE
sometimes99er
  • 4,204 posts
Posted Sun Nov 22, 2015 12:49 AM
Here's a handy one page manual for printout (click picture below).
#100 Ksarul OFFLINE
Ksarul
  • 5,152 posts
Posted Sun Nov 22, 2015 6:44 AM
And it works beautifully on real iron too. . .  :)
Also tagged with one or more of these keywords: game, assembler, cartridge
