Programming in GPL Assembler on TI99/4a
15 replies to this topic
#1 JonnyBritish OFFLINE
JonnyBritish
    Moonsweeper
  • 425 posts
Posted Sun Apr 3, 2011 10:08 AM
Interesting to read about GPL assemblers on tis forum. I was under the impression you needed a ti 990 minicomputer to do this? What if any would be the advantage of coding in GPL?
#2 RXB OFFLINE
RXB
  • 3,156 posts
Posted Sun Apr 3, 2011 12:48 PM
Mostly in GPL I can do about 3 times as much in the same amount of space of memory as Assembly. because GPL is extreamely compact and the TI OS is designed around it.
An example is AMS support built into RXB. The entire amount of GROM memory is only 700 bytes and allows commands AMSON, AMSOFF, AMSPASS, AMSMAP and AMSBANK.
Also including ISR (Interupt Service Routine) Hooks to be controlled. This would be a very expensive amount on memory to use in Assembly.
GPL allows full control of the AMS including using a GPL command MOVE that is only 7 bytes and moves any kind of memory to any kind of memory of any size.
With Classic99 when you put the TI99/4A with System Throttling to System Maximum it can really go to town. Besides 90% of all the cartridges are GPL and only after people figured out how to make GPL simulators did they start making ROM Cartridges.
Typically a 6K GROM programs would take up 18K in Assembly as you also need the support routines loaded which is also 1K mimimum. GPL is best for control and set up of the machine, Assembly is best at use after a GPL set up.
VEIW40 DATA EADSR * Viewer 40 Column
DATA MV40
STRI 'V40'
MV40 DST @>8356,@>8358 * Get the PAB file line length
DSUB @>8354,@>8358 * Subtract the PAB offset
MOVE 10,V@-10(@>8358),@FAC * Get the address of the line loaded by DSR
AND >1F,V@-9(@>8358) * Set for error check
CH >04,@FAC * Opcode higher then Read?
BS DSREXT * Yes
CASE @FAC * Like the XB ON x GOTO
BR VOPEN * OPEN
BR VCLOSE * CLOSE
BR DSREXT * READ
MOVE 880,V@80,V@0 * WRITE to screen
MOVE 80,V*FAC2,V@880 * Save the Data Buffer address string
SCAN * Get a key
BR DSREXT * No key
FREEZE SCAN * Check for a key again
BR FREEZE * Yes, so just loop in FREEZE
BS DSREXT * Keep loading lines to screen
VOPEN MOVE 128,V@>0380,V@-128(@>8370) * Show the file opened
ST >F0,@FAC * VDP Register 1 value for video mode
MOVE 1,@FAC,#1 * Set to TEXT MODE
ST >F0,@>83D4 * Put a copy here for OS updates
ST >20,V@0 * Space at screen here
MOVE 959,V@0,V@1 * Ripple it on entire screen
DSREXT CALL RETURN * Exit back to DSR
VCLOSE SCAN * Wait for user to exit last line on screen
BR VCLOSE * Close DSR
MOVE 128,V@-128(@>8370),V@>0380 * Show the closed file
ST >E0,@>8300 * VDP Register 1 value for video mode
MOVE 1,@>8300,#1 * Set to GRAPHICs MODE
ST >E0,@>83D4 * Put a copy here for OS updates
BR DSREXT * Exit this routine
This is a fake DSR and Device in GPL that reads a file and puts it on screen one line at a time with a key scan to keep on showing each line. It even switches the TI from Graphics mode to Text mode and back when done.
Can you imagine the size of a Assembly program to do this?
By the way in GPL a DSR can call a DSR that can call a DSR and it will work it's way back to the original in GPL. No one uses a Assembly DSR that can do this as you need GPLLNK DSR to keep track.
Edited by RXB, Mon Apr 4, 2011 4:34 AM.
#3 AMenard OFFLINE
AMenard
    Dragonstomper
  • 539 posts
Posted Mon Dec 4, 2017 9:17 AM
Was there ever a native GPL dev environment for the TI99/4A either cart or disk based?
#4 RXB OFFLINE
RXB
  • 3,156 posts
Posted Mon Dec 4, 2017 11:26 AM
Most of the TI99/4A carts are GPL GROM carts.
Yea  Ryte Data GPL Assembler (what I use) and like 6 others made.
Swedish GPL Assembler
Weiand GPL Assembler
RAG GPL Assember (RAG GPL Linker)
Some of the ones I have messed with but keep going back to the Ryte Data GPL Assembler as my favored one.
#5 AMenard OFFLINE
AMenard
    Dragonstomper
  • 539 posts
Posted Mon Dec 4, 2017 11:30 AM
Thanks, I'll do some reading on GPL.
#6 RXB OFFLINE
RXB
  • 3,156 posts
Posted Tue Dec 5, 2017 2:40 AM
GPL HOW 2 Series video
A complete series on how to program GPL (Graphics Progroamming Language) on the TI-99/4A.
Each tutorial has its own support package with example code, GPL assembler, etc.
Video tutorials done by Rich, the programmer of Rich Extended Basic.
(Author: RXB)
GPLHOW2A - Introduction video / zip
GPLHOW2B - Sprite demo video / zip
GPLHOW2C - How to make a Screen Editor like TI Writer or Editor Assembler video / zip
GPLHOW2D - Editor Assembler TI BASIC support.video / zip
GPLHOW2E - DMII cartridge upgrades and how GPL works video / zip
GPLHOW2F - TI Basic to GPL. Converting a TI Basic program to GPL video / zip
GPLHOW2G - TI Basic CALL SOUND to GPL video / zip
GPLHOW2H - Simultaneous sound lists and interrupt timer in GPL video / zip
GPLHOW2I - XB2GPL demo of a XB game Baloons converted into a GPL program video / zip
GPLHOW2J - Update to GPLHOW2I and adds a automatic music to the game from the last demo video / zip
GPLHOW2K - How to make XB Program Image files into I/V 254 files video / zip
#7 ralphb OFFLINE
ralphb
    Dragonstomper
  • 567 posts
Posted Tue Dec 5, 2017 6:03 AM
You asked about native GPL assemblers, but note that there is also a cross GPL assembler.
  • RXB likes this
#8 AMenard OFFLINE
AMenard
    Dragonstomper
  • 539 posts
Posted Tue Dec 5, 2017 6:49 AM
(Author: RXB)
Wow, Thanks!
#9 senior_falcon OFFLINE
senior_falcon
  • 1,177 posts
Posted Tue Dec 5, 2017 11:49 AM
Is there a debugger for GPL that lets you see what is happening when the program misbehaves?  Something like the debuger in Classic99, but which provides disassembled GPL code and that lets you single step through a GPL program and set breakpoints, etc.  I can see something like that being very useful.
#10 AMenard OFFLINE
AMenard
    Dragonstomper
  • 539 posts
Posted Tue Dec 5, 2017 12:43 PM
Ah, the youngare so lazy these days...  :grin:
You just have to learn all the hex representation of the token in ram that you write down on a paper pad with a blunt #2 pencil  :grin:
Edited by AMenard, Tue Dec 5, 2017 12:43 PM.
#11 Lee Stewart OFFLINE
Lee Stewart
  • 3,695 posts
Posted Tue Dec 5, 2017 4:08 PM
Gazoo worked that way in his head.  Wish he were still with us,  :sad:
...lee
#12 lucien2 OFFLINE
lucien2
    Moonsweeper
  • 292 posts
Posted Tue Dec 5, 2017 4:44 PM
...that lets you single step through a GPL program and set breakpoints, etc.
You can do that with the Classic99 debugger: http://atariage.com/...dpost&p=3134616
It does not disassemble the instruction, but if you have a GPL listing with the addresses of each instruction, thats no problem.
#13 AMenard OFFLINE
AMenard
    Dragonstomper
  • 539 posts
Posted Tue Dec 5, 2017 6:36 PM
...lee
I recently downloaded a couple of 6502 assembler books from Archive.org
Most of the give the corresponding numerical value for each instruction. One of them, the one I got that is more Apple II oriented recommend to learn those value as to make the use of the built in monitor more efficient.
Of course, compared to modern CPU, the 6502 assembler has less instructions/values to remember.
The last assembler I used was for the 68000 when I was working on my Bsc at the university. But that's a good thing since it feels like I'm learning it for the first time :-)
#14 MueThor OFFLINE
MueThor
    Space Invader
  • 49 posts
  • Location:OMG, yet another good former TI customer from Germany ;-)
Posted Fri Dec 22, 2017 3:58 AM
Dear RXB,
Thank you for your explanations on GPL.
At this point I have a question: Of course Assembly Language programs written for EA run faster than GPL programs, or?
Regards
Edited by MueThor, Fri Dec 22, 2017 4:01 AM.
#15 Lee Stewart OFFLINE
Lee Stewart
  • 3,695 posts
Posted Fri Dec 22, 2017 6:24 AM
Actually, I believe the GPL interpreter in the console ROM is actually pretty fast, considering that the console ROM is running on the 16-bit bus with no wait states and that the interpreter is working with single-byte tokens.  The problem, I think, is that GROM access is interminably slow.
...lee
  • RXB likes this
#16 TheBF OFFLINE
TheBF
    Dragonstomper
  • 616 posts
Posted Sun Dec 24, 2017 8:27 AM
...lee
Hmmm... makes me wonder if I should make a GPL Cross-compiler that uses Forth source code.
It already uses a parameter stack and return stack.
So much code, so little time.
