Opry99er Posted April 19, 2015 Share Posted April 19, 2015 (edited) That's how it was on my TripTech card IIRC. I thought it funny that there was a zero day... Edited April 19, 2015 by Opry99er Quote Link to comment Share on other sites More sharing options...
Omega-TI Posted April 19, 2015 Share Posted April 19, 2015 Sorry about that. I've never had a clock, so I implemented from the documentation I had. Can we confirm then that days of the week on the CorComp clock should be 0-6? Hi Tursi, Yes, it's confirmed, 0-6. 1 Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted May 9, 2015 Share Posted May 9, 2015 I am using CFHDX with the HDX server. I can get the TI to open a files directory, no problem, but... I have spent hours trying to track this down: how in the heck do you get CFHDX to open a DSK file from the PC?? Quote Link to comment Share on other sites More sharing options...
Asmusr Posted May 9, 2015 Share Posted May 9, 2015 I don't think it can do that. I hope I'm wrong because that's the reason I gave up using HDX. Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted May 9, 2015 Share Posted May 9, 2015 It seems like it should, being that you set a disk directory as well as a files directory. Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted May 10, 2015 Share Posted May 10, 2015 What would be helpful is to find to documentation for the TI99 side of CFHDX. The document mentioned in the readme file is not present on the disk or in the zip file. HDX1 works just fine for FIAD, even sub-directories. I tried a few different methods to access a disk and no-go, such as HDX.(diskfilename). Quote Link to comment Share on other sites More sharing options...
Omega-TI Posted May 10, 2015 Share Posted May 10, 2015 AFAIK, the HDX will only work with individual files under the FIAD structure. It will however allow you to copy entire disks back and forth using DSK2PC. Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted May 11, 2015 Share Posted May 11, 2015 (edited) Correct with the cfhdxs software you can only access files in the files directory. With the HDX DSR you can use a disk image utility to send/receive disk images to/from the pc.. so this only works on my PEB 4/a and Geneve which both have the HDX mods on their rs232 cards. http://www.ti99-geek.nl/Projects/dsk2pc/dsk2pc.html is said utility. It's great for archiving disk collections etc.. Greg Edited May 12, 2015 by arcadeshopper Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted May 11, 2015 Share Posted May 11, 2015 Bogus. Quote Link to comment Share on other sites More sharing options...
Omega-TI Posted May 11, 2015 Share Posted May 11, 2015 Greg, I got a kick out of the graphic for a 'broken link'... << THIS >> should work. Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted May 12, 2015 Share Posted May 12, 2015 Greg, I got a kick out of the graphic for a 'broken link'... << THIS >> should work. I will NEVER remember not to put stuff after a link on a line.. fixed my post too Quote Link to comment Share on other sites More sharing options...
