Epic Adventure
200 replies to this topic
#76 Byte Knight OFFLINE
Byte Knight
  • 1,135 posts
  • Intellivision / Apple II
Posted Sun Aug 28, 2011 5:00 PM
Latest version:
• Added level III with randomized items.
• Level I is easier - two stabs to kill dragon, one to kill troll. No hawk or wizard (so my kids can beat the game!).
• Different title screen - I think the Evil Magician's castle & gate looks cooler...
• Orc disappears after you kill the wizard, so you're free to explore.
• Should work on Harmony cart now (untested).
Attached File  epicadv15.bin   32KB   241 downloads
#77 disjaukifa OFFLINE
disjaukifa
  • 2,125 posts
  • Berzerker In Training
Posted Sun Aug 28, 2011 5:05 PM
Latest version:
Good build! Great work, I like it how you programmed in an easy setting, thats a really nice touch. Looking forward to further updates! If I find any bugs I'll post about them!
#78 ScumSoft OFFLINE
ScumSoft
    Moonsweeper
  • 373 posts
Posted Sun Aug 28, 2011 5:53 PM
Latest version:
Tested, everything seems fine now.
#79 Byte Knight OFFLINE
Byte Knight
  • 1,135 posts
Posted Sun Aug 28, 2011 8:07 PM
Thanks! That's one of my favorite freatures about Adventure - an easy level to explore the environment and figure out the gameplay.
#80 Byte Knight OFFLINE
Byte Knight
  • 1,135 posts
Posted Sun Aug 28, 2011 8:13 PM
Latest version:
Great - thanks for trying it out! I have yet to start my AV mod for the 2600 Jr. Yet another project put on hold while I try to finish this game...
BTW, how does the "torch effect" look in the dark mazes on the Harmony cart? Is it light enough to find your way around?
Edited by Byte Knight, Sun Aug 28, 2011 9:33 PM.
#81 ScumSoft OFFLINE
ScumSoft
    Moonsweeper
  • 373 posts
Posted Sun Aug 28, 2011 10:26 PM
Looks alright, although I've always found it to be a bit painful on my eyes and hard to keep track of where the player is unless you carry an item. If you've been searching for a more elegant fading flicker effect, I would be more than happy to whip up some examples, if you'd like?
Edited by ScumSoft, Sun Aug 28, 2011 10:26 PM.
#82 Byte Knight OFFLINE
Byte Knight
  • 1,135 posts
Posted Mon Aug 29, 2011 7:30 AM
Go for it! Here's the current lighting effect code:
temp1=(rand&15)
 if temp1=0 then pfcolors:
 $22
end
 if temp1>0 then pfcolors:
 $00
end
#83 ScumSoft OFFLINE
ScumSoft
    Moonsweeper
  • 373 posts
Posted Mon Aug 29, 2011 1:01 PM
Sure thing then, I figured it was something basic. I'll have an example posted in a bit.
[edit]Ok I've attached a small example that should be easy to implement, flicker changes depending on player position(player not drawn in example) use joystick to adjust flicker periods.
I recommend linking it like I am (in my Adventure mini-game in EggVenture), to your dragon so that the flicker period is always being adjusted as he moves, and when he is killed then the flicker holds on a pattern based on where the dragon stopped, this way killing it has a good or bad effect on the game :)
  rem Adjust the FlickerTimer and choose FlickerPattern
  FlickerTimer = FlickerTimer + 1
  if FlickerTimer & DragonX > 3 then goto FlickerPattern1
  if FlickerTimer & DragonY > 3 then goto FlickerPattern2
Edited by ScumSoft, Mon Aug 29, 2011 3:49 PM.
#84 Byte Knight OFFLINE
Byte Knight
  • 1,135 posts
Posted Tue Aug 30, 2011 10:44 AM
That looks cool, although I can get a similar effect by making my random number smaller...
Some people mentioned that they'd like a "fade in and out" effect, which I did here:
Attached File  epicadv16.bin   32KB   239 downloads
What do you guys think - better or worse?
#85 IG-88 OFFLINE
IG-88
    Space Invader
  • 42 posts
  • 468,739 posts
Posted Tue Aug 30, 2011 2:12 PM
I like it. I'm also really enjoying the game over-all. Great work!!
#86 abaudrand OFFLINE
abaudrand
    Chopper Commander
  • 241 posts
Posted Tue Aug 30, 2011 2:19 PM
Its really a brillant game. I love the Gfx.
#87 ScumSoft OFFLINE
ScumSoft
    Moonsweeper
  • 373 posts
Posted Tue Aug 30, 2011 7:26 PM
It looks okay, but doesn't resemble torch flicker anymore. You need a fade in then a flicker out effect, then a flicker in :)
#88 Byte Knight OFFLINE
Byte Knight
  • 1,135 posts
Posted Tue Aug 30, 2011 8:00 PM
I agree that the torch effect has been lost, but now it's got a more "magical effect". It kinda gives you the feeling of the Evil Magician's presence...
#89 ScumSoft OFFLINE
ScumSoft
    Moonsweeper
  • 373 posts
Posted Thu Sep 1, 2011 3:23 PM
Here's a thought, leave the color on so people can practice the maze until the Evil Magician is out, then make it strobe like that :) Mwahahaha!
#90 eegad OFFLINE
eegad
    Moonsweeper
  • 369 posts
Posted Sat Sep 3, 2011 2:01 PM
Latest version:
Hmmm....doesn't seem to work for me. I just downloaded both v15 and v16 and copied onto my Harmony cart. Both versions just give a scrambled screen when loaded on my heavy sixer. Any thoughts? Does the file maybe need to have a particular extension (other than .bin) to tell Harmony what bank select method to use???
Edited by eegad, Sat Sep 3, 2011 2:02 PM.
#91 Byte Knight OFFLINE
Byte Knight
  • 1,135 posts
Posted Sat Sep 3, 2011 9:18 PM
You probably need to update your Harmony cart to the latest firmware version that supports DPC+.
#92 Legend OFFLINE
Legend
    Moonsweeper
  • 346 posts
Posted Sat Sep 3, 2011 11:27 PM
Just played for the first time. Very cool.
One thing I noticed was that after I entered the cave through the small hole, I entered a screen that looked like it would be the inside of the red castle and went towards the bottom left of the screen and I went through into the gold castle from the top.
Also, there seems to be nothing in the cave other than that and when I exit through the bottom, a few screens to the left, I come out the front of a castle but can't get back in.
The blinking mazes are kinda cool, but quickly drove me nuts! Maybe if they faded a little slower.
Another thing was I entered the blue maze where the eye was several times. Eventually, the eye just disappeared, but I still moved slowly through that room.
I was playing on game setting 1.
Not sure how I feel about only having one key to open all castles.
Edited by Legend, Sat Sep 3, 2011 11:38 PM.
#93 Byte Knight OFFLINE
Byte Knight
  • 1,135 posts
Posted Sun Sep 4, 2011 9:33 AM
Hey Legend,
Thanks for checking out the game. You found the "secret entrance" to the wizard's castle - it was originally a bug that I left in because it gives you a shortcut into the castle if you've got the amulet. Although you can see the gold castle room from the wizard's chamber while holding the amulet, you can't actually enter the room. Now you see how the chalice stolen so easily!
I think the blinking mazes are much better than the flickering mazes found in earlier versions - much less seizure inducing...
I believe I fixed the disappearing palintir bug for the next version.
I've got zero k left in the graphics bank, so I'd have to get rid of another item in order to add another key...
Now go try levels 2 & 3!
#94 Legend OFFLINE
Legend
    Moonsweeper
  • 346 posts
Posted Sun Sep 4, 2011 11:34 AM
Hey Legend,
I wasn't really suggesting to add more keys. Actually, the first time I played I hadn't properly read the instructions so I spent forever looking for more keys. :dunce:
Should there have been something in the wizard's castle? It was empty.
I still think the blinking mazes could fade a little slower and gradually if possible.
One idea I did have was for mazes where the player dies if they touch the walls. Just an idea that would make it a little more challenging.
#95 eegad OFFLINE
eegad
    Moonsweeper
  • 369 posts
Posted Sun Sep 4, 2011 3:24 PM
That sounded reasonable since I'd never updated the bios/firmware on the harmony cart since I got it when it was first released. So I just did that. No go. Still gives a scrambled screen (like what you'd see if you pulled a cart out of the console in the middle of playing). This was on my heavy sixer, so I figured I'd also try it on my light sixer since I HAVE found a few things that won't play on one console or the other through the years (offhand, moon patrol doesn't work on the heavy via harmony, and the actual purchased atariage holiday cart from a couple years ago (with stay frosty, etc) plays on the light but not the heavy). weird, and i've never figured out how that can be, although i have posted about it in the forums previously. In any case, Epic Adventure v15 and v16 won't work on either console (but the files DO play on the latest Stella, so it would seem that my files are not corrupt in any case). Also, tried renaming the file extension from .bin to .dpc - still no luck. Very odd. Any other thoughts? The game looks great and I'd love to play it on real hardware rather than an emulator.
#96 RevEng OFFLINE
RevEng
    Bit Player
  • 5,174 posts
Posted Sun Sep 4, 2011 3:42 PM
You should try one of the other DPC+ games and see if you have problems with them too: Charge!, Eggventure, and Frantic.
#97 RevEng OFFLINE
RevEng
    Bit Player
  • 5,174 posts
Posted Sun Sep 4, 2011 4:43 PM
Epic Adventure was featured today in the gaming industry news site Game Set Watch!
Congrats Byte Knight!
#98 Byte Knight OFFLINE
Byte Knight
  • 1,135 posts
Posted Sun Sep 4, 2011 10:01 PM
That's cool! Although the original link suggests playing the game on a DS with Stella. I seriously doubt StellaDS supports DPC+...
#99 Byte Knight OFFLINE
Byte Knight
  • 1,135 posts
Posted Sun Sep 4, 2011 10:07 PM
It"s pretty hard to navigate the mazes with a joystick, especially when fleeing an enemy!
#100 gambler172 OFFLINE
gambler172
  • 3,351 posts
  • none
Posted Mon Sep 5, 2011 10:32 AM
Hi BK
Works great.One of the best games for the 2600..... :)
greetings Walter
