HandyMusic
101 replies to this topic
#26 sage OFFLINE
sage
    Dragonstomper
  • 720 posts
Posted Tue Sep 27, 2011 1:48 AM
it dosnt compile
D:\LYNX\sound\chipper (beta)\lynxtc>lyxass handymusic.asm
HandyMusic PCM IRQ Address: $3277
Sound Engine IRQ Address: $3644
HandyMusic Memory left: $3F60
handymusic.asm: 721:ERROR:
Unsolved labels !
whats going wrong?
Let the chipper compile it, it knows what to do.
This is done if you click on "export tc" or "export bll", the tracks are then exported for the selected driver, compiled and an image is build.
#27 rockfistus OFFLINE
rockfistus
    Chopper Commander
  • 203 posts
Posted Tue Sep 27, 2011 4:44 PM
I'd love to help beta test or whatever, My programming for this kind of stuff is crap though. So I can't help there. I've got 15 years or so of tracking experience though.
#28 philipj OFFLINE
philipj
    Moonsweeper
  • 360 posts
Posted Tue Sep 27, 2011 5:36 PM
I not to good with trackers, but I do have some musical experience. As time would allow I'd like to beta test as well.
Edited by philipj, Tue Sep 27, 2011 5:37 PM.
#29 sage OFFLINE
sage
    Dragonstomper
  • 720 posts
Posted Wed Sep 28, 2011 1:15 AM
U R welcome.
#30 sage OFFLINE
sage
    Dragonstomper
  • 720 posts
Posted Wed Sep 28, 2011 10:12 AM
just as a note:
the archive also contains new (bugfixed) versions of lyxass and lynxdir (ROM image builder), but without the source nor documentation.
#31 matashen OFFLINE
matashen
    Moonsweeper
  • 468 posts
Posted Wed Sep 28, 2011 1:03 PM
in chipper the export to bll runs, the exporttc dosnt run, some files are dont found.
Regards
Matashen
#32 sage OFFLINE
sage
    Dragonstomper
  • 720 posts
Posted Thu Sep 29, 2011 1:44 PM
Anyone else have the same problem?
#33 TailChao OFFLINE
TailChao
    Moonsweeper
  • 402 posts
  • Bup?
Posted Fri Sep 30, 2011 4:34 AM
It is exporting fine for me, and I'm using the new version.
#34 sage OFFLINE
sage
    Dragonstomper
  • 720 posts
Posted Fri Sep 30, 2011 4:45 AM
Matashen: I checked it with Windows, with wine and from linux command line, all run fine. Please try again from the latest archive, and do not update the files in the current directory, but create a new one. Check that no environment varaible is set which would lead to either lyxass executed from elsewhere on your system or includfiles not loaded from lyxntc but from you include directory.
#35 sage OFFLINE
sage
    Dragonstomper
  • 720 posts
Posted Sun Oct 2, 2011 2:13 PM
Version 1.4.9 is out, with improved exporter code (size!) and a few other changes in the lynx player code... mainly cosmetic ones :-) File- and pathnames have been changed to something ... eh ... more intuitive.
#36 sage OFFLINE
sage
    Dragonstomper
  • 720 posts
Posted Sun Dec 4, 2011 5:43 AM
some news:
I ported the player routine to c (well inline assembler, but hell, who cares). Only newcc65 is supported now _and_ a few bugfixes had to be done to ra65. did nobody noticed or cared that in this thing the macro processing and localy symbols were f***ed up?
#37 matashen OFFLINE
matashen
    Moonsweeper
  • 468 posts
Posted Sun Dec 11, 2011 4:11 PM
I dont found the c-routines for the newcc65. where can i download ?
#38 sage OFFLINE
sage
    Dragonstomper
  • 720 posts
Posted Sat Dec 17, 2011 12:58 PM
you need the patched ra65, which i would have to compile for windows first.
#39 TailChao OFFLINE
TailChao
    Moonsweeper
  • 402 posts
  • Bup?
Posted Sat Feb 11, 2012 11:07 AM
Driver version 1.3 is now available here.
The changes are as follows:
*Short note mode added for music scripts.
*As requested by Sage: channel timers are only disabled for changes, making the waveforms much cleaner.
*Better channel redirection setup, giving more time for running your game. There's also much more free memory to add extra features to HandyMusic later.
As usual, all music and sound effects made for the old versions are completely compatible.
The next version will include a SPL style sound compiler, HMCC. So at that point it will be a complete replacement for Epyx's HSPL libraries.
Enjoy!
Edited by TailChao, Thu Feb 11, 2016 6:20 PM.
#40 sage OFFLINE
sage
    Dragonstomper
  • 720 posts
Posted Sat Feb 11, 2012 4:20 PM
good work.
... and after the usual change it is already working as driver for chipper exports.
-> will be included in the next update.
#41 karri OFFLINE
karri
  • 1,799 posts
Posted Sun Feb 12, 2012 3:27 AM
Wow. This is really a complete sound programming language. I have to try it out.
Karri
#42 sage OFFLINE
sage
    Dragonstomper
  • 720 posts
Posted Sun Feb 12, 2012 6:16 AM
good work.
Update! Find it at the usual place ;)
#43 TailChao OFFLINE
TailChao
    Moonsweeper
  • 402 posts
  • Bup?
Posted Sun Feb 12, 2012 11:13 AM
It will be a little nicer to use in the next release when HMCC is done, since then you can do straight notes instead of frequencies like:
using triangle_powpow ; specify instrument used for the following
	   as4 40 ; note on for triangle powpow instrument, a-sharp in 4th octave, wait 40/60ths of a second
	   rest 20 ; note off + rest for 20/60ths of a second
But of course, things can always be exported from Sage's tracker.
I liked working with HSPL when I was finishing up Zaku, but the driver was so heavy on both memory and CPU. There was also no stereo support out of the box and you could not use integrate mode on instruments, only SFX. It was also very easy to get the driver to mess up and change the music waveforms with those of a recently played SFX.
So this driver was designed to replace HSPL completely in my current project. Also be a little more friendly to use from the game side, and not require an Amiga.
Thanks very much! The tracker support is always appreciated :)
#44 TailChao OFFLINE
TailChao
    Moonsweeper
  • 402 posts
  • Bup?
Posted Thu Sep 27, 2012 11:47 PM
Driver version 1.3c is available here.
Changes are as follows:
*HMCC Lynx-SASS Compiler added (source included).
*Bug fixed where note off commands in music scripts were not clearing the instrument decode delay.
Enjoy!
Edited by TailChao, Thu Feb 11, 2016 6:21 PM.
#45 sage OFFLINE
sage
    Dragonstomper
  • 720 posts
Posted Sat Sep 29, 2012 3:27 PM
Only one line changed, right?
(beside some renamed variables)
#46 TailChao OFFLINE
TailChao
    Moonsweeper
  • 402 posts
  • Bup?
Posted Sat Sep 29, 2012 6:52 PM
Driver side the addition of "STZ HandyMusic_Channel_DecodeDelay,X" at line 203 of HM_Mus.asm is all I am recalling. So that should be it, the compiler didn't really affect the driver at all.
#47 LX.NET OFFLINE
LX.NET
    Dragonstomper
  • 659 posts
Posted Tue Oct 2, 2012 1:51 AM
I will definitely check this out when Tiny Lynx Adventure becomes less tiny.
I haven't done music before other than getting abcmusic compiled and trying the Austin Powers demo music.
One question though: is the HandyMusic driver enough to play the music and sound effects or is sage's tracker required?
Keep up this work.
#48 sage OFFLINE
sage
    Dragonstomper
  • 720 posts
Posted Tue Oct 2, 2012 2:04 AM
Its is stand-alone. But Chipper can export for TailChao's driver. With some limitations on the instruments.
#49 TailChao OFFLINE
TailChao
    Moonsweeper
  • 402 posts
  • Bup?
Posted Thu Oct 11, 2012 9:42 AM
Keep in mind this was all made for the old BLL-Assembly environment. If you're using CC65 I have no idea how easy or difficult it may be to talk to the driver.
But as Sage said, the driver can work by itself. It just needs supplied music and SFX data which can both be generated using HMCC and SASS. SFX are very easy to make, and HMCC will even generate an equates file with useful constants regarding all your noises.
I would still recommend trying music in Chipper first. Sage made a very good tool.
Keep up this work.
At this point with HMCC, the suite has all I need for my current game. So things may be slow or just bugfixes for awhile.
But a MIDI->SASS converter is a strong possibility.
#50 obschan OFFLINE
obschan
    Chopper Commander
  • 168 posts
Posted Thu Nov 1, 2012 12:01 AM
I got it working with the latest cc65, that's a great piece, and the documentation is outstanding.
Thank you very much for this great work, it's very informative !
