ColecoVision A.E. - Unreleased
43 replies to this topic
#1 NIAD OFFLINE
NIAD
  • 6,060 posts
Posted Wed Jul 27, 2011 8:30 PM
As I mentioned in the thread concerning the huge lot of CV&ADAM goodies I acquired from a former Coleco employee, I came across a rom dump of the ColecoVision version of A.E. on a data pack made with the In-House Coleco Cart Copier program. As many of you know, A.E. was only made available on a compilation data pack for the ADAM called "The Best of Broderbund", which also included Choplifter.
I have converted the data pack to an ADAMem compatible DDP Image file and have given it a pretty thorough testing. Everything seems to be in order with the exception of a sound effects bug (enemy ship explosions) that are corrected after you lose a ship. The reason for a DDP Image file instead of a Disk Image file is that the Coleco Cart Copier creates a non-standard media without a directory and there are about 10 games in all on the original DDP that would overrun a 160K Disk.
I have created a ROM Image for use with CV emulators as well on a real CV via the AtariMax SD Cart, but in the conversion some further issues have arisen (corrupted graphics and lock-ups) and I will have to try the transfer again. If this second attempt fails, we'll have to wait to see if one of the Homebrew programmers can fix the issues and provide a good/clean rom image.
If these issues are fixed, CollectorVision will be producing a run of cartridges complete with a box (which looks fantastic!) and manual and after they are sold out... the good rom image will be made available for free. So keep your fingers crossed that these issues can be resolved.
Following are some screenshots and the DDP Image for use with ADAMem / Virtual ADAM.
Edited by NIAD, Wed Jul 27, 2011 8:35 PM.
#2 retroillucid OFFLINE
retroillucid
  • 7,733 posts
Posted Wed Jul 27, 2011 8:48 PM
And here's how the box would look like... :)
#3 ozma wars OFFLINE
ozma wars
    Dragonstomper
  • 710 posts
Posted Wed Jul 27, 2011 11:57 PM
pls sign me as a customer for that...thanks.
Max
#4 Cebus Capucinis OFFLINE
Cebus Capucinis
    Not-so-secretly Trolling
  • 8,013 posts
  • Wiseass Extraordinaire
Posted Thu Jul 28, 2011 12:01 AM
I am all over a cart of this! :)
#5 NIAD OFFLINE
NIAD
  • 6,060 posts
Posted Thu Jul 28, 2011 4:32 PM
A little update... I finally got the rom file pulled from the DDP Image correctly and have reinserted the code to display the ColecoVision BIOS title screen. All that is left is for the two sound effects bugs to be fixed and some further testing after which we'll be good to go for a CIB release! :D
#6 cmart604 ONLINE
cmart604
    Intellivision Hoarder
  • 12,059 posts
  • Running out of things to buy.
Posted Thu Jul 28, 2011 6:14 PM
:thumbsup: Awesome news! Very cool! :)
#7 purenergy OFFLINE
purenergy
    Dragonstomper
  • 650 posts
Posted Thu Jul 28, 2011 6:38 PM
Very nice! I would also like to see this on a cartridge.
Edited by purenergy, Thu Jul 28, 2011 6:39 PM.
#8 NIAD OFFLINE
NIAD
  • 6,060 posts
Posted Thu Jul 28, 2011 7:56 PM
It's all up to Retroillucid now as far as a CIB cartridge release. The two sound effects bugs are going to be looked into by Daniel Bienvenu/NewColeco. Hopefully he will be able to fix them without having to spend a lot of time on it since he is so busy with other projects, but if there is no easy remedy, Retroillucid and I feel that the game is still in a good enough state to warrant a CIB cart release.
Actually, I hope the next time I play it is when I plug the real cartridge into a CV as I am burnt out on the game! :roll:
#9 newcoleco OFFLINE
newcoleco
  • 1,323 posts
  • Always Tired
Posted Fri Jul 29, 2011 12:56 PM
I was able to patch the sound issue, and I've done it by changing 5 bytes in the rom file and add 12 more bytes at the end (the patch itself).
During my investigation on this ROM file, I've noticed that RST $8 is set to call an outside routine that is certainly related to some codes of the Best of Broderbund compilation. If RST $8 is not used anywhere in the ROM file, then I declare the ROM file ready to be published.
rst08:
	jp	L2C56
rst10:
	ret
I should have worked on Lock'n Chase sounds, so excuse me if it takes me time. I have to stop working on A.E., but it was fun to do.
EXTRA : I've noticed all the free space and I think it can be used to show a splash screen of our own if we want to, something like the intro screen from the Apple II version could be nice I guess. The NMI is made in sush a way that we can check a flag to be synchronized with the refresh rate and show an animation while enabling the NMI properly.
http://www.youtube.com/watch?v=8H-_Y5AX8lU
NMI:
	jp	L8062
L8062:
	push	af
	ld	a,(X702B)
	set	7,a
	ld	(X702B),a
	bit	0,a
	jr	z,L8072
	pop	af
	retn
The modifications to add a title splash screen.
First, of course, change the Start Address to run code to the end of the ROM file.
800A : $C40C
Code for a splash screen should start by setting to $01 the byte @ $702B, turn off sound and init the VDP properly (turn off screen, no NMI, set video mode, update VRAM, then show screen). Then enable NMI and loop on the flag
loop:
	ld	a,(X702B)
	bit	7,a
	jr	z,loop
	ld	a,1
	ld	(X702B),a
; update VRAM for the animation then go back to the loop if no fire button detected
... you can figure out the rest of the code to do
And all you need to do to go back to the original code is call for MODE_1, turn off sound (if you played any) and jump for $8221 and that's pretty much it.
#10 nanochess OFFLINE
nanochess
    Processorus Polyglotus
  • 5,531 posts
  • Coding something good
Posted Fri Jul 29, 2011 1:46 PM
I like the backgrounds, the artist obviously took his time.
#11 rpgcollector OFFLINE
rpgcollector
    Moonsweeper
  • 256 posts
Posted Fri Jul 29, 2011 2:16 PM
Very nice. I am a customer for sure!!
#12 Pixelboy OFFLINE
Pixelboy
  • 7,980 posts
Posted Fri Jul 29, 2011 2:33 PM
Nice work, Daniel! :D
+1 for you!
#13 bennybingo OFFLINE
bennybingo
  • 6,204 posts
  • Wasting my life...one Shatner at a time.
Posted Fri Jul 29, 2011 3:49 PM
Count me in for a pre-order whenever this gets produced (fingers crossed)!
#14 retroillucid OFFLINE
retroillucid
  • 7,733 posts
Posted Fri Jul 29, 2011 4:08 PM
... whenever this gets produced (fingers crossed)!
It will! ;)
The front of the box is done, the rest is piece of cake
Label will be made this weekend or next week
I already have the ADAM "Best of Broderbund" so it'll be easy to make the A.E. manual (I've done some works on the manual already)
So expect to get your CIB copy of A.E. soon :)
#15 bennybingo OFFLINE
bennybingo
  • 6,204 posts
Posted Fri Jul 29, 2011 4:14 PM
WooHoo!!!!!!
#16 lucifershalo OFFLINE
lucifershalo
  • 2,978 posts
Posted Fri Jul 29, 2011 4:33 PM
does it look better than the Apple II and Atari 8 bit versions?
#17 retroillucid OFFLINE
retroillucid
  • 7,733 posts
Posted Fri Jul 29, 2011 4:44 PM
see post#1 for screenshots
IMO, the appleII version look better, but the CV version is more colorfull
#18 jblenkle OFFLINE
jblenkle
  • 4,615 posts
Posted Fri Jul 29, 2011 4:47 PM
Any thoughts on price yet? I might have to chip in for this one!!
Edited by jblenkle, Fri Jul 29, 2011 4:47 PM.
#19 NIAD OFFLINE
NIAD
  • 6,060 posts
Posted Fri Jul 29, 2011 6:13 PM
I was able to patch the sound issue, and I've done it by changing 5 bytes in the rom file and add 12 more bytes at the end (the patch itself)........
Thank you so very much for your work on correcting the sound bug and the further information on how to go about possibly adding further title/splash screens. Sorry to hear that this little project sidetracked you from further work on Lock'n Chase since I, as many others probably are, can't wait for this game to be finished and released.
If I come across anything else while I'm sorting through the rest of the stuff... I'll hold off on bugging you! Nah, just kidding, I'll send it to you right away! :P
#20 jeffgamer OFFLINE
jeffgamer
    Chopper Commander
  • 216 posts
Posted Fri Jul 29, 2011 7:47 PM
Please count me in for one! Merci!
#21 Madaracs OFFLINE
Madaracs
    Dragonstomper
  • 647 posts
Posted Tue Aug 2, 2011 3:18 PM
I am in for one of these, for sure! :thumbsup:
#22 Tempest OFFLINE
Tempest
    Fallen Moderator
  • 27,124 posts
Posted Sun Aug 11, 2013 7:49 AM
Sorry to bump this old thread, but since the ROM was just released I was wondering if this version is any different than the one on the Best of Broderbund? The only difference I see is that this one can run on a regular Colecovision where that other one needs an ADAM.
#23 NIAD OFFLINE
NIAD
  • 6,060 posts
Posted Sun Aug 11, 2013 11:56 AM
This version that I found, was released by CollectorVision on cartridge and now freely available for download in rom format (like I requested... thanks J-F) is the exact same version that was released on Data Pack by Coleco for the ADAM Computer. There is even code in the game that is specific to the ADAM Computer as NewColeco pointed out, but it does not harm anything.
#24 newcoleco OFFLINE
newcoleco
  • 1,323 posts
  • Always Tired
Posted Sun Aug 11, 2013 12:12 PM
When I think they published the ROM file without my modification that fixes a minor sound issue. Oh well, it's fine! :P
#25 Tempest OFFLINE
Tempest
    Fallen Moderator
  • 27,124 posts
Posted Mon Aug 12, 2013 7:28 AM
So what's the story behind this then? Was Coleco actually planning on releasing it for the Colecovision and in the process of porting it from the ADAM version, or is this some Coleco employee's personal hack?
