Any info on Video Technology Laser 500 computer?
285 replies to this topic
#276 nippur72 OFFLINE
nippur72
    Star Raider
  • 87 posts
Posted Thu Jan 17, 2019 10:47 AM
I've extended the emulator to work with double sided disks :-) Yes the tracks are reversed on the second side, I guess it makes sense to minimize head movements and also for backward compatibility.
I've also added some debug features for the disk drive so you can see exactly how it works. From the JavaScript console modify the variables:
fdc_debug_move = true;   // debugs movements of the drive head
fdc_debug_data_size = true;   // debugs changes in 8/16 bit flag
fdc_debug_read = true;  // debugs byte reads
fdc_debug_write = true;   // debugs byte writes
fdc_debug_side = true;   // debugs changes in disk side (0/1)
The self-sync bit flag seems to be either 255 (on) or 213 (off) but there are less ONs that OFFs, suggesting that the controller switches automatically to ON somewhere.
#277 RedskullDC OFFLINE
RedskullDC
    Combat Commando
  • 9 posts
Posted Thu Jan 17, 2019 11:43 PM
Hi Nippur72,
Nice work on the double-sided code. Works fine here for me!
Looking at the read/write code, I think that whenever the *WRREQ bit (bit 6 in port $10) is turned ON, the controller defaults to writing in self-sync mode.
Writing $FF (255) to port $11 turns self-sync *ON*.
Writing *any other* value to port $11 turns self-sync *OFF*.
I think the 213 ($D5) value is just incidental, as the A register happens to be holding $D5 (next byte written after the self-sync sequence).
It's interesting to note that the self-sync flag is turned off *after* the $D5 byte is actually written to the data output register.
That suggests the self-sync flag is not sampled by the FDC prior to the byte being output, but can be changed mid-byte.
I'm presuming the $D5 byte is *not* written as a 10 bit byte?  I don't have the real hardware to test unfortunately.
(It doesn't actually matter either way if the $D5 ID byte is written as 8 or 10 bits, it will still just magically work :) )
RAM:66BF D3 10                       out     (10h), a        ; turn on *WRREQ - self-sync *on* by default.
RAM:66C1 7A                          ld      a, d            ; D = $FF here
RAM:66C2 D3 13                       out     (13h), a
RAM:66C4             loc_66C4:
RAM:66C4 CD 11 79                    call    WRITE_DISK_BYTE_D
RAM:66C7 10 FB                       djnz    loc_66C4        ; Write $FF 127 times on first loop, sector_gap on rest
RAM:66C9 16 D5                       ld      d, 0D5h
RAM:66CB CD 11 79                    call    WRITE_DISK_BYTE_D
RAM:66CE D3 11                       out     (11h), a        ; self-sync *off*
RAM:66D0 16 AA                       ld      d, 0AAh
RAM:66D2 CD 11 79                    call    WRITE_DISK_BYTE_D
RAM:66D5 16 96                       ld      d, 96h
Here is the current state of my disassembly of DOS1.1:
http://crisis.com.au...OS_1.1_DISS.zip
Includes the Boot Sector at $A200
Main DOS from $5E00-$7FFF  (loaded into bank#6, executed in slot#1)
High memory routines copied to $FEE0-$FFAD
I've concentrated more on the read/write routines than on the high-level BASIC stuff,
but it should be reasonably easy to follow.
Regards,
Leslie
#278 RedskullDC OFFLINE
RedskullDC
    Combat Commando
  • 9 posts
Posted Mon Feb 4, 2019 6:35 AM
Hi James, et al.
The BASIC with the 500 appears to be pretty good but the way the first letter of the tokens are stored seems unique.  At least I haven't seen anything like it before.
Maybe some sort of logic or math operation with it's position in the table?
The tokeniser routine at $2509 in the ROM as it processes the input line, uses the first ascii character it finds
as an index into a 26 word pointer table, for A-Z:
RAM:2509             TOKENIZE:                               ; CODE XREF: sub_2457+7D↑j
RAM:2509                                                     ; sub_2457+93↑j
RAM:2509 E1                          pop     hl              ; convert basic keyword to 1 byte TOKEN
RAM:250A CD 15 31                    call    sub_3115
RAM:250D E5                          push    hl
RAM:250E 21 E9 1B                    ld      hl, KEYWD_PTR_ARRAY ; 26 char table, first letter of each
RAM:2511 D6 41                       sub     41h ; 'A'       ; A now ZERO OFFSET into table
RAM:2513 87                          add     a, a
RAM:2514 4F                          ld      c, a
RAM:2515 06 00                       ld      b, 0
RAM:2517 09                          add     hl, bc
RAM:2518 5E                          ld      e, (hl)
RAM:2519 23                          inc     hl
RAM:251A 56                          ld      d, (hl)         ; DE now points at inividual letter table
RAM:251B E1                          pop     hl
RAM:251C 23                          inc     hl
RAM:1BE9 1D 1C       KEYWD_PTR_ARRAY:dw KEYWORDS_A           ; DATA XREF: sub_2457+B7↓o
RAM:1BEB 2E 1C                       dw KEYWORDS_B
RAM:1BED 2F 1C                       dw KEYWORDS_C
RAM:1BEF 83 1C                       dw KEYWORDS_D
RAM:1BF1 B0 1C                       dw KEYWORDS_E
RAM:1BF3 D1 1C                       dw KEYWORDS_F
RAM:1BF5 E7 1C                       dw KEYWORDS_G
RAM:1BF7 FB 1C                       dw KEYWORDS_H
RAM:1BF9 00 1D                       dw KEYWORDS_I
RAM:1BFB 1C 1D                       dw KEYWORDS_J
RAM:1BFD 20 1D                       dw KEYWORDS_K
RAM:1BFF 28 1D                       dw KEYWORDS_L
RAM:1C01 5C 1D                       dw KEYWORDS_M
RAM:1C03 81 1D                       dw KEYWORDS_N
RAM:1C05 94 1D                       dw KEYWORDS_O
RAM:1C07 AA 1D                       dw KEYWORDS_P
RAM:1C09 C8 1D                       dw KEYWORDS_Q
RAM:1C0B C9 1D                       dw KEYWORDS_R
RAM:1C0D 0A 1E                       dw KEYWORDS_S
RAM:1C0F 47 1E                       dw KEYWORDS_T
RAM:1C11 62 1E                       dw KEYWORDS_U
RAM:1C13 6B 1E                       dw KEYWORDS_V
RAM:1C15 7B 1E                       dw KEYWORDS_W
RAM:1C17 93 1E                       dw KEYWORDS_X
RAM:1C19 97 1E                       dw KEYWORDS_Y
RAM:1C1B 98 1E                       dw KEYWORDS_Z
RAM:1C1D 55          KEYWORDS_A:     db 'U'                  ; DATA XREF: RAM:KEYWD_PTR_ARRAY↑o
RAM:1C1E 54                          db 'T'
RAM:1C1F CF                          db 0CFh
RAM:1C20 AB                          db 0ABh                 ; AUTO $AB
RAM:1C21 4E                          db 'N'
RAM:1C22 C4                          db 0C4h
RAM:1C23 F7                          db 0F7h                 ; AND $F7
RAM:1C24 42                          db 'B'
RAM:1C25 D3                          db 0D3h
RAM:1C26 06                          db 6                    ; ABS $06
RAM:1C27 54                          db 'T'
RAM:1C28 CE                          db 0CEh
RAM:1C29 0E                          db  0Eh                 ; ATN $0E
RAM:1C2A 53                          db 'S'
RAM:1C2B C3                          db 0C3h
RAM:1C2C 15                          db  15h                 ; ASC $15
RAM:1C2D 00                          db    0
RAM:1C2E 00          KEYWORDS_B:     db 0                    ; DATA XREF: RAM:1BEB↑o
RAM:1C2F 4C          KEYWORDS_C:     db 'L'                  ; DATA XREF: RAM:1BED↑o
RAM:1C30 4F                          db 'O'
.... and so on.
Following program will list all the keywords and their corresponding single-byte tokens:
10 A=&H1C1D
20 C=&H40
30 C=C+1
40 B=PEEK(A)
50 IF B=0 THEN A=A+1:GOTO 30
60 PRINT CHR$©;
70 IF B > 127 THEN 110
80 PRINT CHR$(B);
90 A=A+1
100 B=PEEK(A):GOTO 70
110 B=(B AND 127)
120 PRINT CHR$(B),
130 A=A+1
140 B=PEEK(A)
150 PRINT" Token:$";HEX$(B)
160 A=A+1
170 IF A < &H1E96 THEN 40
Still working on discovering all the entry points for the BASIC commands and keywords.
Regards,
Leslie
#279 nippur72 OFFLINE
nippur72
    Star Raider
  • 87 posts
Posted Sat Feb 9, 2019 4:56 AM
do you already know about "basck" ? it's tool in the Z88DK compiler that automatically scans a ROM dump and finds MS basic entry points:
# File size: 32768
# Specific Z80 CPU code detected
# Microsoft 8080/Z80 BASIC found
#  Extended syntax detected (classic version)
#  Double precision maths detected
#  Microsoft signature not found
BASTXT 	= $8041   ; BASIC program start ptr (aka TXTTAB)
#    CPDEHL (compare DE and HL), code found at $5FA1
#    (Detected position for ORG:  0)
INPORT 	= $8579   ; Current port for 'INP' function
OTPORT 	= $857C   ; Current port for 'OUT' statement
SEED 	= $8586   ; Seed for RND numbers
LSTRND2 	= $8580   ; Last RND number
BUFFER 	= $8149   ; Start of input buffer
TMSTPT 	= $839F   ; Temporary string pool pointer
TMPSTR 	= $83BF   ; Temporary string
NXTOPR 	= $83E3   ; Address ptr to next operator
PROGND 	= $83E9   ; BASIC program end ptr (aka VARTAB)
VAREND 	= $83EB   ; End of variables
ARREND 	= $83ED   ; End of arrays (lowest free mem)
SGNRES 	= $852F   ; Sign of result
TEMPST 	= $83A1   ; (word), temporary descriptors
TEMPPT 	= $839F   ; (word), start of free area of temporary descriptor
PRMLEN 	= $840D   ; (word), number of bytes of obj table
NOFUNS 	= $84DE   ; (byte), 0 if no function active
PRMLN2 	= $8475   ; (word), size of parameter block
FUNACT 	= $84E1   ; (word), active functions counter
PRMSTK 	= $840B   ; (word), previous block definition on stack
SUBFLG 	= $83CC   ; (byte), flag for USR fn. array
TEMP 	= $83CE   ; (word) temp. reservation for st.code
VALTYP 	= $838E   ; (word) type indicator
PRITAB 	= $1EAE   ; (word) Arithmetic precedence table
TEMP2 	= $83E3   ; (word) temp. storage used by EVAL
TEMP3 	= $83C4   ; (word) used for garbage collection or by USR function
SAVTXT 	= $83D6   ; (word), prg pointer for resume
CURLIN 	= $803F   ; (word), line number being interpreted
OLDLIN 	= $83E5   ; (word), old line number set up ^C ...
OLDTXT 	= $83E7   ; (word), prg pointer for CONT
FPREG 	= $852B   ; Floating Point Register (FACCU, FACLOW on Ext. BASIC)
FPEXP 	= $852E   ; Floating Point Exponent
DBL_FPREG 	= $852B   ; Double Precision Floating Point Register (aka FACLOW)
DBL_LAST_FPREG 	= $853A   ; Last byte in Double Precision FP register (+sign bit)
CPDEHL 	= $5FA2   ; compare DE and HL
FNDNUM 	= $3507   ; Load 'A' with the next number in BASIC program
GETINT 	= $350A   ; Get a number to 'A'
DEPINT 	= $34EF   ; Get integer variable to DE, error if negative
FPSINT 	= $34E9   ; Get subscript
POSINT 	= $34EC   ; Get positive integer
GETVAR 	= $59B7   ; Get variable address to DE
DIM 	= $59B2   ; DIM command
CHKSTK 	= $5E9E   ; Check for C levels of stack
OPRND 	= $304E   ; Get next expression value
SYNCHR 	= $5FA8   ; Check syntax, 1 byte follows to be compared
LFRGNM 	= $655B   ; number in program listing and check for ending ')'
HLPASS 	= $3DFA   ; Get back from function passing an INT value HL
MIDNUM 	= $6560   ; Get number in program listing
INT_RESULT_A 	= $3C6F   ; Get back from function, result in A (signed)
GETYPR 	= $320F   ; Test number FAC type (Precision mode, etc..)
TSTSGN 	= $3C35   ; Test sign of FPREG
_TSTSGN 	= $3C76   ; Test sign in number
INVSGN 	= $3C64   ; Invert number sign
STAKFP 	= $3C88   ; Put FP value on stack
NEGAFT 	= $49F9   ; Negate number
LOG 	= $3AC0   ; LOG
EXP 	= $4A63   ; EXP
TAN 	= $4C4C   ; TAN
ATN 	= $4C61   ; ATN
DBL_ABS 	= $3FC6   ; ABS (double precision BASIC variant)
RND 	= $4B14   ; RND
SUBCDE 	= $3999   ; Subtract BCDE from FP reg
FPADD 	= $399C   ; Add BCDE to FP reg
SCALE 	= $3A6B   ; Scale number in BCDE for A exponent (bits)
PLUCDE 	= $3A4B   ; Add number pointed by HL to CDE
COMPL 	= $3A57   ; Convert a negative number to positive
PHLTFP 	= $3C95   ; Number at HL to BCDE
FPBCDE 	= $3C98   ; Move BCDE to FPREG
MLSP10 	= $3C1E   ; Multiply number in FPREG by 10
FPMULT 	= $3B05   ; Multiply BCDE to FP reg
DIV10 	= $3B5D   ; Divide FP by 10
DIV 	= $3B66   ; Divide FP by number on stack
DCBCDE 	= $3E48   ; Decrement FP value in BCDE
BCDEFP 	= $3CA3   ; Load FP reg to BCDE
LOADFP 	= $3CA6   ; Load FP value pointed by HL to BCDE
CMPNUM 	= $3CF1   ; Compare FP reg to BCDE
FPINT 	= $3E24   ; Floating Point to Integer
FLGREL 	= $3C44   ; CY and A to FP, & normalise
INT 	= $3E6E   ; INT
DBL_SUB 	= $3FEC   ; Double precision SUB (formerly SUBCDE)
DBL_ADD 	= $3FF3   ; Double precision ADD (formerly FPADD)
FIX 	= $3E4F   ; Double Precision to Integer conversion
INT_MUL 	= $3F29   ; Integer MULTIPLY
MLDEBC 	= $3EE1   ; Multiply DE by BC
_ASCTFP 	= $42A0   ; ASCII to FP number
H_ASCTFP 	= $429B   ; ASCII to FP number (also '&' prefixes)
PRNUMS 	= $62D2   ; Print number string
PRS 	= $62D3   ; Create string entry and print it
PRS1 	= $62D6   ; Print string at HL
STR 	= $624C   ; STR BASIC function entry
SAVSTR 	= $6255   ; Save string in string area
MKTMST 	= $626F   ; Make temporary string
CRTMST 	= $6272   ; Create temporary string entry
SSTSA 	= $6437   ; Move string on stack to string area
TOSTRA 	= $643F   ; Move string in BC, (len in L) to string area
TSALP 	= $6440   ; TOSTRA loop
FDTLP 	= $2EA7   ; Find next DATA statement
DATA 	= $29EA   ; DATA statement: find next DATA program line..
RESTOR 	= $5FBA   ; 'RESTORE' stmt, init ptr to DATA program line..
NEW_STMT 	= $27B5   ; Interprete next statement
GO_TO 	= $2993   ; Go To..
MAKINT 	= $350D   ; Convert tmp string to int in A register
CONCAT 	= $63FF   ; String concatenation
TESTR 	= $62EB   ; Test if enough room for string
TOPOOL 	= $649E   ; Save in string pool
TSTOPL 	= $62AD   ; Temporary string to pool
EVAL 	= $2ED4   ; (a.k.a. GETNUM, evaluate expression (GETNUM)
EVAL1 	= $2ED7   ; Save precedence and eval until precedence break
EVAL3 	= $2EE9   ; Evaluate expression until precedence break
CRTST 	= $627D   ; Create String
QTSTR 	= $627E   ; Create quote terminated String
DTSTR 	= $6281   ; Create String, termination char in D
GETSTR 	= $6448   ; Get string pointed by FPREG 'Type Error' if it is not
GSTRCU 	= $644B   ; Get string pointed by FPREG
GSTRHL 	= $644E   ; Get string pointed by HL
GSTRDE 	= $644F   ; Get string pointed by DE
TSTSTR 	= $3E1D   ; Test a string, 'Type Error' if it is not
LNUM_RANGE 	= $241A   ; Read numeric range function parameters
LNUM_PARM 	= $2921   ; Read numeric function parameter
_CHRGTB 	= $281A   ; Pick next char from program
_CHRCKB 	= $281B   ; Pick current char (or token) on program
UCASE_HL 	= $3115   ; Get char from (HL) and make upper case
UCASE 	= $3116   ; Make char in 'A' upper case
RINPUT 	= $0C1C   ; Line input
OUTC 	= $57D9   ; Output char in 'A' to console
DATSNR 	= $2222   ; 'SN err' entry for Input STMT
SNERR 	= $2228   ; entry for '?SN ERROR'
ULERR 	= $29CA   ; entry for '?UL ERROR'
# JP table for statements = $1AD1
# TOKEN table position = $1C1D, word list in 'extended BASIC' mode.
#	Token range: 88
# -- STATEMENTS --
#	USING		[229]	- $5CD1
#	TAB(		[220]	- $2C53
#	SPC(		[224]	- same as TAB(
#	= assignment		[240]
#	+ operand		[242]	- $304E
#	- operand		[243]	- $30F7
#	" string		[34]	- $627E
#	NOT		[225]	- $31FA
#	& specifier		[38]	- $3124
#	ERR		[227]	- $3083
#	ERL		[226]	- $3093
#	VARPTR		[232]	- $30A3
#	USR		[234]	- $12B6
#	INSTR		[222]	- $327C
#	TOKEN_?		[230]	- $6565
#	TOKEN_?		[233]	- $5964
#	TOKEN_?		[228]	- $64A2
#	TOKEN_?		[133]	- $5310
#	TOKEN_?		[223]	- $32F1
#	ELSE		[162]
#	AUTO      	[171]	- $2B15
#	AND      	[247]
#	ABS      	[6]	- $3C57
#	ATN      	[14]	- $4C61
#	ASC      	[21]	- $6484
#	CLOSE      	[195]	- $859A
#	CONT      	[154]	- $602D
#	CLEAR      	[146]	- $60D8
#	CINT      	[28]	- $3D61
#	CSNG      	[29]	- $3DD7
#	CDBL      	[30]	- $3E03
#	CVI      	[43]	- $5099
#	CVS      	[44]	- $509C
#	CVD      	[45]	- $509F
#	COS      	[12]	- $4BA9
#	CHR$      	[22]	- $6494
#	CALL      	[182]	- $5410
#	COMMON      	[184]	- $8585
#	CHAIN      	[185]	- $8588
#	CSAVE      	[155]	- $1593
#	CLOAD      	[156]	- $1714
#	CLS      	[160]	- $0F14
#	COLOR      	[167]	- $0F19
#	CRUN      	[207]	- $1958
#	COPY      	[210]	- $1AC7
#	DELETE      	[170]	- $36FD
#	DATA      	[132]	- $29EA
#	DIM      	[134]	- $59B2
#	DEFSTR      	[173]	- $28D0
#	DEFINT      	[174]	- $28D3
#	DEFSNG      	[175]	- $28D6
#	DEFDBL      	[176]	- $28D9
#	DEF      	[152]	- $32CA
#	DRAW      	[212]	- $12BE
#	ELSE      	[162]	- $29EC
#	END      	[129]	- $5FD8
#	ERASE      	[166]	- $6091
#	ERROR      	[168]	- $2B0A
#	ERL      	[226]
#	ERR      	[227]
#	EXP      	[11]	- $4A66
#	EOF      	[47]	- $85BB
#	EQV      	[250]
#	FOR      	[130]	- $26D3
#	FIELD      	[192]	- $8591
#	FILES      	[198]	- $85A3
#	FN      	[223]
#	FRE      	[15]	- $6682
#	FIX      	[31]	- $3E4F
#	GOTO      	[137]	- $2994
#	GO TO      	[137]	- $2994
#	GOSUB      	[141]	- $297D
#	GET      	[193]	- $8594
#	GR      	[190]	- $10B5
#	HEX$      	[26]	- $6247
#	INPUT      	[133]	- $2D4A
#	IF      	[139]	- $2B47
#	INSTR      	[230]
#	INT      	[5]	- $3E62
#	INP      	[16]	- $3489
#	IMP      	[251]
#	INKEY$      	[233]
#	JOY      	[32]	- $1A7E
#	KILL      	[200]	- $85A9
#	KEY      	[205]	- $0FE2
#	LPRINT      	[158]	- $2B85
#	LLIST      	[159]	- $3519
#	LPOS      	[27]	- $326D
#	LET      	[136]	- $2A11
#	LINE      	[177]	- $2CDE
#	LOAD      	[196]	- $859D
#	LSET      	[201]	- $85AC
#	LIST      	[147]	- $351E
#	LOG      	[10]	- $3AC0
#	LOC      	[48]	- $85BE
#	LEN      	[18]	- $6478
#	LEFT$      	[1]	- $64E4
#	LOF      	[49]	- $85C1
#	MERGE      	[197]	- $85A0
#	MOD      	[252]
#	MKI$      	[50]	- $5080
#	MKS$      	[51]	- $5083
#	MKD$      	[52]	- $5086
#	MID$      	[3]	- $651D
#	MOTOR      	[209]	- $0F57
#	MOVE      	[211]	- $12BB
#	MON      	[214]	- $6B96
#	NEXT      	[131]	- $615C
#	NULL      	[150]	- $6041
#	NAME      	[199]	- $85A6
#	NEW      	[148]	- $5EF9
#	NOT      	[225]
#	OPEN      	[191]	- $858E
#	OUT      	[157]	- $3495
#	ON      	[149]	- $2A77
#	OR      	[248]
#	OCT$      	[25]	- $6242
#	OPTION      	[186]	- $38A8
#	PRINT      	[145]	- $2B8D
#	PUT      	[194]	- $8597
#	POKE      	[153]	- $373F
#	POS      	[17]	- $3272
#	PEEK      	[23]	- $3735
#	POINT      	[234]
#	PAINT      	[213]	- $85B8
#	RETURN      	[142]	- $29CF
#	READ      	[135]	- $2E1A
#	RUN      	[138]	- $2966
#	RESTORE      	[140]	- $5FBA
#	REM      	[143]	- $29EC
#	RESUME      	[169]	- $2AC0
#	RSET      	[202]	- $85AF
#	RIGHT$      	[2]	- $6514
#	RND      	[8]	- $4B14
#	RENUM      	[172]	- $3778
#	RESET      	[204]	- $85B5
#	RANDOMIZE      	[187]	- $38F2
#	RES      	[179]	- $12C1
#	STOP      	[144]	- $5FD4
#	SWAP      	[165]	- $6050
#	SAVE      	[203]	- $85B2
#	SPC(      	[224]
#	STEP      	[221]
#	SGN      	[4]	- $3C6C
#	SQR      	[7]	- $49FE
#	SIN      	[9]	- $4BAF
#	STR$      	[19]	- $624C
#	STRING$      	[228]
#	SPACE$      	[24]	- $64CB
#	SYSTEM      	[189]	- $858B
#	SET      	[178]	- $12C4
#	SOUND      	[206]	- $1198
#	THEN      	[219]
#	TRON      	[163]	- $604A
#	TROFF      	[164]	- $604B
#	TAB(      	[220]
#	TO      	[218]
#	TAN      	[13]	- $4C4C
#	TEXT      	[188]	- $0F8A
#	USING      	[229]
#	USR      	[222]
#	VAL      	[20]	- $653E
#	VARPTR      	[232]
#	VERIFY      	[208]	- $1962
#	WIDTH      	[161]	- $34BC
#	WAIT      	[151]	- $349C
#	WHILE      	[180]	- $5380
#	WEND      	[181]	- $53A1
#	WRITE      	[183]	- $54D3
#	XOR      	[249]
#	Z
#	[+      	[242]
#	[-      	[243]
#	[*      	[244]
#	[/      	[245]
#	[^      	[246]
#	[\      	[253]
#	['      	[231]
#	[>      	[239]
#	[=      	[240]
#	[<      	[241]
#280 RedskullDC OFFLINE
RedskullDC
    Combat Commando
  • 9 posts
Posted Tue Feb 12, 2019 5:24 AM
Hi Nippur72, et al.
I was aware of it, but hadn't though to try it.
Your list shows it does a pretty good job of locating most things.
Can I trouble you to test a couple of things on your real machine?
I'm looking at Bits #6 and #7 of &H6800 on write.
Bit#7 should be the cassette motor control output.
Bit#6 is turned on/off by a routine which hangs off the interrupt chain if a certain key combination is pressed:   SHIFT-CONTROL-1  (I think)
I'm wondering if Bit#6 controls the "GT" output of the gate array, which is connected to the character generator?
If so, it may switch visible character sets on machines which have CGA11 and CGA12 correctly jumpered?
Cheers,
Leslie
RAM:0A56             sub_A56:                                ; CODE XREF: RAM:0A1A↑p
RAM:0A56
RAM:0A56             ; FUNCTION CHUNK AT RAM:0AD3 SIZE 0000000B BYTES
RAM:0A56
RAM:0A56 06 02                       ld      b, 2            ; Bring in I/O Bank
RAM:0A58 CD E5 0A                    call    SET_BANK1_B     ; set Bank#1 to value in B reg, save old on stack, and return
RAM:0A5B 21 FF 6A                    ld      hl, 6AFFh       ; Keyboard row 'C'?
RAM:0A5E CB 76                       bit     6, (hl)         ; check CAPS LOCK ?
RAM:0A60 28 11                       jr      z, loc_A73
RAM:0A62 CD A3 0A                    call    CHECK_CONTROL_KEY ; check if control key is down - ZERO if true
RAM:0A65 20 2F                       jr      nz, loc_A96
RAM:0A67 21 F7 6F                    ld      hl, 6FF7h       ; check Row KA3
RAM:0A6A CB 6E                       bit     5, (hl)         ; bit 5 = '1' key?
RAM:0A6C 20 28                       jr      nz, loc_A96
RAM:0A6E 3E 3F                       ld      a, 3Fh ; '?'
RAM:0A70 32 F0 85                    ld      (byte_85F0), a
RAM:0A73
RAM:0A73             loc_A73:                                ; CODE XREF: sub_A56+A↑j
RAM:0A73 21 FB 85                    ld      hl, operation_flags2
RAM:0A76 CB 6E                       bit     5, (hl)
RAM:0A78 20 21                       jr      nz, loc_A9B
RAM:0A7A CB EE                       set     5, (hl)
RAM:0A7C 3A F9 85                    ld      a, (REG_6800W)  ; Saved copy of $6800 I/O Write byte
RAM:0A7F CB 77                       bit     6, a
RAM:0A81 20 0D                       jr      nz, loc_A90
RAM:0A83 CB F7                       set     6, a            ; what does Bit #6 in $6800 do in write mode
RAM:0A85 CB 9E                       res     3, (hl)
RAM:0A87
RAM:0A87             loc_A87:                                ; CODE XREF: sub_A56+3E↓j
RAM:0A87 32 00 68                    ld      (loc_67FF+1), a
RAM:0A8A 32 F9 85                    ld      (REG_6800W), a  ; Saved copy of $6800 I/O Write byte
RAM:0A8D C3 D3 0A                    jp      RESTORE_BNK1    ; Restore Bank#1 from values on the stack
RAM:0A90             ; ---------------------------------------------------------------------------
RAM:0A90
RAM:0A90             loc_A90:                                ; CODE XREF: sub_A56+2B↑j
RAM:0A90 CB B7                       res     6, a
RAM:0A92 CB DE                       set     3, (hl)
RAM:0A94 18 F1                       jr      loc_A87
#281 nippur72 OFFLINE
nippur72
    Star Raider
  • 87 posts
Posted Sat Feb 16, 2019 2:33 AM
I tried to flip bit 6 and bit 7 of &H6800 (with bank 1 switched to 2), but nothing happens. I tried that in 40 and 80 columns. Nothing.
I also tried CTRL+SHIFT+key on all keys, but it behaved normally.
MON
9000Z
DI
LD A, 02
OUT (41), A
LD A, C0
LD (6800), A
LD A, 01
OUT (41), A
EI
RET
If you have any other test you want me to run, just ask.
#282 nippur72 OFFLINE
nippur72
    Star Raider
  • 87 posts
Posted Sun Feb 17, 2019 2:05 AM
Leslie, I think you've found something  :)
not satisfied by yesterday's test, I debugged the unidentified bits in the emulator looking for how and when they were changed.
Bit 7 and 4 still remain untouched everywhere; but bit 6 it's the CAPS LOCK state (CAPLK in the schematics).
CAPLK is also triggered by CTRL+1 as you've found in your disasselmby. The reason? Laser 350 does not have a dedicated caps lock key, so they made it available via this key combination.
Somewhere in the keyboard routine there also should be the code that checks the actual caps lock key and flips the bit.
This is the code I used for debbuging in the emulator, you can try it yourself: open the JavaScript console (F12) and paste this:
(function() {
   let old_io_bit_7, old_caps_lock_bit, old_io_bit_4;
   debugBefore = ()=> {
      old_io_bit_7      = io_bit_7;
      old_caps_lock_bit = caps_lock_bit;
      old_io_bit_4      = io_bit_4;
   debugAfter = ()=> {
      let { pc } = cpu.getState();
      if(old_io_bit_7 != io_bit_7)           console.log(`bit 7 changed from ${old_io_bit_7     } to ${io_bit_7     } at ${hex(pc,4)}`);
      if(old_caps_lock_bit != caps_lock_bit) console.log(`bit 6 changed from ${old_caps_lock_bit} to ${caps_lock_bit} at ${hex(pc,4)}`);
      if(old_io_bit_4 != io_bit_4)           console.log(`bit 4 changed from ${old_io_bit_4     } to ${io_bit_4     } at ${hex(pc,4)}`);
#283 RedskullDC OFFLINE
RedskullDC
    Combat Commando
  • 9 posts
Posted Mon Feb 18, 2019 12:20 AM
Hi Nippur72,
Thanks for the debug code!
That explains the code for the CTRL-1 == capslock!
I tried your debug code out with the "MOTOR ON" and "MOTOR OFF" commands from BASIC.
They are definitely flipping bit#7 in &H6800 writes.
"MOTOR ON" gives:
bit 7 changed from 0 to 1 at 0f7c
"MOTOR OFF" gives:
bit 7 changed from 1 to 0 at 0f7c
If you have a cassette recorder attached with the correct remote cable attached and the play and/or record buttons down,
it should start and stop the recorder.
Cheers,
Leslie
#284 nippur72 OFFLINE
nippur72
    Star Raider
  • 87 posts
Posted Mon Feb 18, 2019 5:27 AM
Ahah great! I wasn't even aware there was a "MOTOR" command! Nice finding as well!
Since there is no dedicated "cassette motor" plug, I guess it's not connected. Perhaps it's the REMOTE (70) pin on the VLSI chip (not connected in the 350/500/700 schematics)
#285 Platis OFFLINE
Platis
    Space Invader
  • 26 posts
Posted Tue Feb 19, 2019 3:03 PM
Maybe little off topic, but have you ever seen this book before?
https://www.ebay.com...=item4d8aa33a82
#286 RedskullDC OFFLINE
RedskullDC
    Combat Commando
  • 9 posts
Posted Sat Feb 23, 2019 12:31 AM
Hi Platis,
Can't say that I have seen that one.
Doesn't appear to be on any of the popular VZ200-300/LASER 310 repositories that I can see.
No use for programming the Laser 350/500/700 models of course.
Cheers,
Leslie
