mimo Posted December 10, 2011 Share Posted December 10, 2011 do you think some hot glue on the usb connector could help? seems that it could be a week spot? Quote Link to comment Share on other sites More sharing options...
+Larry Posted December 10, 2011 Share Posted December 10, 2011 All's well that ends well! Looks like it was another separated pin 1 that only made intermittent contact. Got it fixed with Sloopy's counsel. Thanks, Sloopy! -Larry Quote Link to comment Share on other sites More sharing options...
sloopy Posted December 10, 2011 Author Share Posted December 10, 2011 yesterday i had to order more from my soldering consumables supplier, seems the batch of solder paste i have has issues... as i was having issue with pin seperation, and thought i was doing something wrong, as i am used to using plain 60/40 rosin core solder, which is a pain in the cornholio to clean off... this stuff is much easier to clean and thought the issues i was having were not enough solder or it spreading under the FTDI chip and creating bridging, but it seems the paste wasnt mixed properly, so flux isnt mixed with the tin/lead correctly and making cold solder joints... a new batch of solder paste is on its way to me, so the few remaining ones i have left are waiting for this... (they know who they are ;') sloopy. Quote Link to comment Share on other sites More sharing options...
GoodByteXL Posted December 11, 2011 Share Posted December 11, 2011 ... this stuff is much easier to clean and thought the issues i was having were not enough solder or it spreading under the FTDI chip and creating bridging, but it seems the paste wasnt mixed properly, so flux isnt mixed with the tin/lead correctly and making cold solder joints... Hm, I had similar issues with newly produced solder while doing some breadboards and with baught new hardware (from Asus), which also had bad connections. I was told by an experienced solderer that this is related to nowadays ROHS type solder. Luckily, I was able to acquire some old stuff and this works indeed much better. Quote Link to comment Share on other sites More sharing options...
sloopy Posted December 11, 2011 Author Share Posted December 11, 2011 ... this stuff is much easier to clean and thought the issues i was having were not enough solder or it spreading under the FTDI chip and creating bridging, but it seems the paste wasnt mixed properly, so flux isnt mixed with the tin/lead correctly and making cold solder joints... Hm, I had similar issues with newly produced solder while doing some breadboards and with baught new hardware (from Asus), which also had bad connections. I was told by an experienced solderer that this is related to nowadays ROHS type solder. Luckily, I was able to acquire some old stuff and this works indeed much better. 60/40 rosin core is easy to find... problem is, the rosin flux is not easy to clean off, the paste i bought was 60/40, but with water clean flux instead of rosin (solvent clean)... the problem with it was the flux wasnt mixed thoroughly with the solder... RoHS compliant solder is easy if you have a iron that is capable of handling it, it has a higher melting temp, which most 15-25 watt irons dont... sloopy. Quote Link to comment Share on other sites More sharing options...
GoodByteXL Posted December 11, 2011 Share Posted December 11, 2011 RoHS compliant solder is easy if you have a iron that is capable of handling it, it has a higher melting temp, which most 15-25 watt irons dont... hm, my Weller TCP doesn't like it ... Quote Link to comment Share on other sites More sharing options...
sloopy Posted December 12, 2011 Author Share Posted December 12, 2011 RoHS compliant solder is easy if you have a iron that is capable of handling it, it has a higher melting temp, which most 15-25 watt irons dont... hm, my Weller TCP doesn't like it ... Yeah thats a fixed temp iron, regular 60/40 solder melts at ~180-190*C, where as lead free (aka RoHS compliant) solder usually has a 220*C and higher... 195-200*C is a common temp for older fixed temp irons like yours, so they have issues with lead-free solder... sloopy. Quote Link to comment Share on other sites More sharing options...
+Larry Posted December 14, 2011 Share Posted December 14, 2011 I ran into an interesting issue today. I have a CSS Quintopus -- the 6-jack SIO connection device. I've had the SIO2PC-USB device plugged into the Quintopus for several days. If I want to use AspeQt, I connect the USB cable to it. If I want to use APE, then I connect the USB cable to it. Fairly easy to swap back and forth. But today, APE stopped communicating with the Atari. Reloaded APE, rebooted the PC, disconnected the USB cable and reattached it. Nothing worked. Finally, I removed the SIO2PC-USB device from the Quintopus. Instantly, APE worked again. Looked pretty harmless, but the moral of the story is not to plug them in at the same time. @Sloopy -- presume that the SIO2PC-USB device is powered by the USB (and not the Atari)? -Larry Quote Link to comment Share on other sites More sharing options...
a8isa1 Posted May 16, 2012 Share Posted May 16, 2012 Sloopy, are these still available to order? I love the small form factor! Have they been tested along side real drives? I ask because I have an ATR8000 which as always been tempermental with SIO2PCs of the past. Once last thing, what's the longest USB cable I can use? I have a *slight* logistical problem running a cable from the ATR8000 to my linux box. Would be nice if I could solve it with a custom long cable versus moving hardware -Steve Sheppard Quote Link to comment Share on other sites More sharing options...
sloopy Posted May 16, 2012 Author Share Posted May 16, 2012 heh, seems Rays post made some interest... yes, my newer ones work fine with other devices... early ones didnt have the diode on the DataIn line, so could have some issues... USB spec is 15meters IIRC, beyond that you would need a USB repeater... I have been busy with RL, VBXE, incognito, and other things, so i have a couple of these left, (and a stack of ones with issues i need to look at...) current pricing is $25/35 for standard/ deluxe (without or with activity LED) sloopy. Quote Link to comment Share on other sites More sharing options...
sloopy Posted May 16, 2012 Author Share Posted May 16, 2012 I ran into an interesting issue today. I have a CSS Quintopus -- the 6-jack SIO connection device. I've had the SIO2PC-USB device plugged into the Quintopus for several days. If I want to use AspeQt, I connect the USB cable to it. If I want to use APE, then I connect the USB cable to it. Fairly easy to swap back and forth. But today, APE stopped communicating with the Atari. Reloaded APE, rebooted the PC, disconnected the USB cable and reattached it. Nothing worked. Finally, I removed the SIO2PC-USB device from the Quintopus. Instantly, APE worked again. Looked pretty harmless, but the moral of the story is not to plug them in at the same time. @Sloopy -- presume that the SIO2PC-USB device is powered by the USB (and not the Atari)? -Larry I dont know why i didnt see this post... I would guess you got it sorted out? and yes, my sio2pc-usb are powered by USB, not the atari... too many issues with powering it via atari, no known issues powering it from USB... sloopy. Quote Link to comment Share on other sites More sharing options...
+Larry Posted May 17, 2012 Share Posted May 17, 2012 Hi Sloopy- Yes, everything is working now, but I can't remember what I did/didn't do. :-( -Larry Quote Link to comment Share on other sites More sharing options...
imajeff Posted May 9, 2013 Share Posted May 9, 2013 Sloopy are you still selling these or anyone? I might be interested pretty soon although I might do better with the option of a 30 ft cable. I didn't know about this kind until I saw one (deluxe) on ebay being sold as-is, but since it's not in US I would be paying a lot for shipping. Quote Link to comment Share on other sites More sharing options...
Mclaneinc Posted May 9, 2013 Share Posted May 9, 2013 30ft? Surely there will be drop out on that length? Quote Link to comment Share on other sites More sharing options...
a8isa1 Posted May 9, 2013 Share Posted May 9, 2013 30ft? Surely there will be drop out on that length? 25ft (on the TTL side) seems just fine. However, I'm not able to reliably use divisor 0 (no matter how short the cable). I hope Sloopy is able to get back to these soon. Thumbs up on these, BTW -SteveS Quote Link to comment Share on other sites More sharing options...
imajeff Posted May 10, 2013 Share Posted May 10, 2013 Yes for one, I would never try lengthening USB, and my point was that I could not do this with that adapter (the only line there would be USB). I would also not recommend making TTL lines very long; not designed for that. So what I was getting at was that I need the RS-232 version of sio2pc and not USB. With good RS-232C levels, I often go 50+ ft. (industrial purpose such as programming the big turret press from a PC on the other side of the building). That's what RS-232 was made for. 1 Quote Link to comment Share on other sites More sharing options...
bernie Posted March 11, 2017 Share Posted March 11, 2017 Are any available? Quote Link to comment Share on other sites More sharing options...
