Can you play original XBOX games on the 4gig slim XBOX 360?...
21 replies to this topic
#1 ataridave OFFLINE
ataridave
  • 1,173 posts
Posted Fri Sep 30, 2011 12:56 PM
I just got one of these consoles, and it's fantastic! But I have been told that you cannot play original XBOX games on it. Is this true?? I know that there are some available for download on XBL.
#2 segasaturn OFFLINE
segasaturn
    Dragonstomper
  • 558 posts
Posted Fri Sep 30, 2011 1:00 PM
YEs it's true(you can't play an original xbox game). You need to get a 250 gig hard drive. I got mine at gamestop(the hard-drive)
#3 Rex Dart OFFLINE
Rex Dart
  • 6,658 posts
  • NO CASH VALUE
Posted Fri Sep 30, 2011 1:06 PM
You don't need a hard drive when you can use any old USB device, right? Also, I imagine there's a difference between original xbox discs and downloads.
#4 segasaturn OFFLINE
segasaturn
    Dragonstomper
  • 558 posts
Posted Fri Sep 30, 2011 1:17 PM
http://support.microsoft.com/kb/911314
This is what microsoft says. (see if this helps clear questions)
#5 keilbaca OFFLINE
keilbaca
    Fight like a robot!
  • 7,703 posts
  • Berzerk (Atari 2600) champ
Posted Fri Sep 30, 2011 1:43 PM
All the original xbox 360 hard drives have been able to play xbox games, backwards compatibility.
If you buy a standard 360 drive (not one for slim), spend 10 bucks and get a slim case for the hard drive (or just float the drive inside of it, case not needed), take apart the original drive, and insert into the slim.
#6 ataridave OFFLINE
ataridave
  • 1,173 posts
Posted Fri Sep 30, 2011 2:15 PM
What about one of these flash drives?: http://www.gamestop....y-sandisk/77578
#7 Rex Dart OFFLINE
Rex Dart
  • 6,658 posts
  • NO CASH VALUE
Posted Fri Sep 30, 2011 2:44 PM
I would think any old flash drive 8GB or larger would work. Haven't specifically tried using one for old xbox compatibility junk, but I do use one for saves & storing XBLA games.
#8 ataridave OFFLINE
ataridave
  • 1,173 posts
Posted Fri Sep 30, 2011 3:52 PM
Personally, I would rather buy this one then the much more expensive 250gig drive. I mean, I don't plane on using Netflix, or downloading any shows, movies, or music onto my 360. Just game saves, and XBLA games.
#9 keilbaca OFFLINE
keilbaca
    Fight like a robot!
  • 7,703 posts
Posted Fri Sep 30, 2011 3:55 PM
I think only the hard drives keep the compatibility folder required for original xbox games.
#10 Rex Dart OFFLINE
Rex Dart
  • 6,658 posts
  • NO CASH VALUE
Got a spare 4GB SD Micro & USB reader laying around? Give it at try.
#11 Itchy Koala OFFLINE
Itchy Koala
    Dragonstomper
  • 987 posts
I highly recommend using the extra space on a 250 gig hard drive to download games to your hard drive. Every game I own is downloaded to my hard drive so I can game for several hours at a time without putting very much stress on my system.
and to get back on topic, I am able to play (some) original xbox games with my 250 gig, but without I cannot.
Edited by Itchy Koala, Fri Sep 30, 2011 3:57 PM.
#12 ataridave OFFLINE
ataridave
  • 1,173 posts
Posted Fri Sep 30, 2011 4:19 PM
OK, well I guess I'll shell out for this, then!
#13 Atariboy ONLINE
Atariboy
  • 7,260 posts
  • River Raider
Posted Fri Sep 30, 2011 4:24 PM
Flash drives don't enable Xbox backwards compatibility.
I hope you're also planning to use that 250gig hd for other things besides Xbox BC, such as XBLA games, installing disc games to the hard drive, expansion packs, etc. Xbox backwards compatibility was pretty poor. Barely half of the library is compatible and the majority of the games that are backwards compatible don't really perform right (I've played perhaps 20 original Xbox games on the 360 at one time or another, and maybe 1/3 of those performed close to 100% with the rest having issues ranging from nagging problems like frame rate drops that weren't there on the Xbox to critical issues).
It's a pretty expensive accessory just to play the ~10% or so of the original Xbox library that actually works correctly on the 360. You could buy numerous Xbox consoles for what you'd be paying for a 250 gig hard drive and every game would be guaranteed to work the way the programmers intended.
Edited by Atariboy, Fri Sep 30, 2011 4:27 PM.
#14 Itchy Koala OFFLINE
Itchy Koala
    Dragonstomper
  • 987 posts
Posted Fri Sep 30, 2011 4:57 PM
He's right about that, I forgot to mention it's not going to enable every xbox game to play on the 360.
#15 segasaturn OFFLINE
segasaturn
    Dragonstomper
  • 558 posts
Posted Fri Sep 30, 2011 6:13 PM
yeah their right. What games do you want to play? Here is a list of the compatible games for the 360. See if the games you want to play are on there...... http://en.wikipedia....e_with_Xbox_360
#16 Austin ONLINE
Austin
  • 12,347 posts
Posted Sat Oct 1, 2011 4:56 AM
Definitely check the compatibility list. If there's a lot of stuff you want to play that won't work, might as well just buy an original XBOX. People are practically giving them away these days, heh.
#17 TheGameCollector OFFLINE
TheGameCollector
  • 1,067 posts
Posted Sat Oct 1, 2011 5:09 AM
For me it was a real bummer. Couldn't play Oddworld: Stranger's Wrath, Sudeki, X-Men Legends or X-Men Legends II on my new system and the 1st Baldur's Gate Dark Alliance had a lot of lag in places. I gave up trying to run regular Xbox games on the 360 and just kept my Xbox hooked up alongside it.
#18 Austin ONLINE
Austin
  • 12,347 posts
Posted Sat Oct 1, 2011 5:10 AM
^ Same here. :lolblue:
#19 RARusk OFFLINE
RARusk
  • 1,105 posts
  • Excuse me, which way to Tokyo?
Posted Sat Oct 1, 2011 10:02 AM
BC on the 360 sucks a hard one. Since most of the games had issues even when they worked MicroSoft shouldn't have bothered.
Besides, the original Xbox's are pretty much a dime-a-dozen these days. The hard part is maintaining the hardware, especially the power supply and DVD-ROM drives. In addition, you can mod the Xbox to pretty much do anything but mow your lawn.
#20 Atariboy ONLINE
Atariboy
  • 7,260 posts
  • River Raider
Posted Sat Oct 1, 2011 4:45 PM
I'm glad it's there. A few classics run very well and shine with upscaling on a HDTV. And I get to enjoy 16:9 modes without bothering to hook my Xbox up to my HDTV and negatively affecting my picture quality in the process.
The Halo titles, the Ninja Gaiden titles, Black, Sid Meier's Pirates, Dreamfall, Indigo Prophecy, Atari Anthology (It's natively 1080i and runs perfectly on the 360's emulator, allowing me to enjoy this game in HD yet keep my Xbox hooked up to my Trinitron for the best picture quality with the average Xbox game) and several others have impressed me.
But more often than not, the games just perform too poorly to make it worthwhile. It's well worth checking out if you already have a hard drive. But in my opinion it's far too flawed and limited to justify buying an expensive accessory for the express purpose of using it for Xbox backwards compatibility.
But for the occasional Xbox game that's compatible and runs without issue, it's a nice thing to have around.
Edited by Atariboy, Sat Oct 1, 2011 4:57 PM.
#21 Hyper_Eye OFFLINE
Hyper_Eye
  • 2,996 posts
  • IDSPISPOPD
Posted Sun Oct 2, 2011 2:46 AM
I finished a couple games on Xbox 360 that played very well. Half-Life 2 before it was available on 360. I played through Black on 360 and I don't remember having a single issue. That was a great game. I replayed Halo 2 all the way through. It has some small known glitches but for the most part it worked fine and looked good. I plan to finally finish Doom 3 RoE on it... or I might just use one of my Xbox's. I haven't decided.
#22 TheGameCollector OFFLINE
TheGameCollector
  • 1,067 posts
Posted Sun Oct 2, 2011 3:07 AM
Yeah I did quite enjoy the fact Sonic Mega Collection Plus runs on it. It allowed me to play some good classics without paying for them again.
I still don't have Sonic's Ultimate Genesis Collection yet, but I will some day "Just For The F Of It" (as Mark Hoppus' old discontinued +44 blog site was called).
