Sears Tele-games Hockey - Tennis III power adapter?
7 replies to this topic
#1 coyo5050 OFFLINE
coyo5050
    Dragonstomper
  • 601 posts
Posted Sun Oct 2, 2011 5:05 PM
Anyone know what one this uses, what specs or what comparable power supply I might be able to use with it? The manual is useless just gives and old Sears part # of 99732 and googling that gets me no where. There is nothing listed on the unit either. Battery compartment had some corrosion on the metal contacts and I tried to clean that up. Trying to verify if the unit is bad by eliminating the potential battery issues first.
I am assuming this was made by APF Electronics since the sticker on back lists the name btw
Thanks!
Edited by coyo5050, Sun Oct 2, 2011 5:33 PM.
#2 dave2236 OFFLINE
dave2236
    Space Invader
  • 36 posts
Posted Mon Oct 10, 2011 4:03 PM
I dont know about your model, but most of the old Pong version systems used a 9Vdc 100-300 mA Power cord.
#3 FujiSkunk OFFLINE
FujiSkunk
  • 7,531 posts
  • Behold the Fuji!
Posted Sun Apr 27, 2014 7:48 PM
Necro-post!
Over two years later and Google still isn't much help.  So I decided to find out the hard way, and fortunately I don't think I fried my Hockey-Tennis III in the process.  The picture signal is pretty weak and doesn't even display correctly until I hit the reset button, but I'm assuming that's old age combined with the original design.
Anyway, I'm using a universal plug set to 9 volts DC with a positive tip.  The universal puts out 900mA tops, which seems to be more than enough juice for this thing.
#4 chas10e OFFLINE
chas10e
    Dragonstomper
  • 760 posts
Posted Wed Apr 30, 2014 9:00 PM
does that also take batteries ? ... each battery is 1.5V so if 4 batteries 6V & if 6 batteries 9V .... trouble is the end connector is same 1/8" jack on both Atari (Sears) products)
Ebay prices can be outrageous  at times but can be found on there for reasonable ....
Best Electronics has NOS Pong battery eliminators I think for ten bucks mebbe 12
#5 FujiSkunk OFFLINE
FujiSkunk
  • 7,531 posts
  • Behold the Fuji!
Posted Thu May 1, 2014 9:04 AM
The Hockey-Tennis III does take batteries, yes, six "C" batteries in all. The power jack actually requires a barrel plug, different from the 1/8" headphone-like plug the Atari 2600 and other Sears consoles take.  The good news is such plugs are easily found in universal power kits.  The hard part is figuring out the polarity when there isn't any info printed on the console.
#6 chas10e OFFLINE
chas10e
    Dragonstomper
  • 760 posts
Posted Fri May 2, 2014 1:58 PM
ok 6 batteries ... so 9v DC
searching around it may be the same as the "Sears Video Arcade II" ...
I don't think you are going to find the original specifically. It's a 3.5mm barrel 9v positive center. I can hook you up with something that works.
DON'T use an NES adapter as it puts out 10vAC
Sega System 1 might work (System 2 is a bit different)
Edited by chas10e, Fri May 2, 2014 1:59 PM.
#7 FujiSkunk OFFLINE
FujiSkunk
  • 7,531 posts
  • Behold the Fuji!
Posted Fri May 2, 2014 3:55 PM
There is a good chance the Video Arcade II would work, yes.  Nice find.
Of course those are a lot rarer than universal adapters, but if you have one around it's worth trying.
And yeah, stay away from the NES adapters.
#8 hunmanik OFFLINE
hunmanik
    Chopper Commander
  • 233 posts
Posted Wed Dec 3, 2014 10:24 PM
On a completely unrelated project I first stumbled across this pic (probably eBay), then I stumbled across this thread, and realized the two need to be joined together!
