cycles explanation
I cant figure out what cycle can someone explain to me wha
2 replies to this topic
#1 esplonky OFFLINE
esplonky
    Moonsweeper
  • 419 posts
  • Kinetic, Not synthetic.
Posted Sat Oct 8, 2011 6:04 PM
I want to know what cycles are and how to calculate how many i have in my game.
#2 Random Terrain OFFLINE
Random Terrain
    Visual batari Basic User
  • 22,680 posts
  • Controlled Randomness
    Replay Value
    Nonlinear
Posted Sun Oct 9, 2011 12:11 AM
Have you looked at this section of the bB page yet:
http://www.randomter...ands.html#debug
#3 SpiceWare ONLINE
SpiceWare
  • 6,885 posts
  • Medieval Mayhem
Posted Sun Oct 9, 2011 10:22 AM
A cycle is like "a second of time", but much-much faster.  Similar to how 60 seconds occur in a minute, 76 cycles occur during the time it takes to draw a single scan line on your TV.  The Atari has 19,912 (if using the standard 262 scan line count for an NTSC display) cycles per frame(1 update of the TV's display, which gets updated 60 times per second - also known as 60 frames per second, or 60 fps).
That sounds like a lot, but the Atari's video chip is so primitive that the CPU must update it in real-time as the screen is being drawn.  Games often display 192 scan lines of picture, so subtracting out 192 * 76 only leaves 5,320 cycles of time for your game logic.  The section of the game that draws the screen is known as the kernel, and is one of the things that bB does for you.  bB does other things as well, so you only get what's left over (of the 5,320 cycles) after bB has finished it's processing.
While this is probably more detailed than you're looking for - the Atari uses a 6507, which is a 6502 derivative, so you can reference 6502 tutorials.  Looking at the 6502 opcodes you'll see info like this:
LDA (LoaD Accumulator)
Affects Flags: S Z
MODE		   SYNTAX	   HEX LEN TIM
Immediate	 LDA #$44	  $A9  2   2
Zero Page	 LDA $44	   $A5  2   3
Zero Page,X   LDA $44,X	 $B5  2   4
Absolute	  LDA $4400	 $AD  3   4
Absolute,X	LDA $4400,X   $BD  3   4+
Absolute,Y	LDA $4400,Y   $B9  3   4+
Indirect,X	LDA ($44,X)   $A1  2   6
Indirect,Y	LDA ($44),Y   $B1  2   5+
+ add 1 cycle if page boundary crossed
The column labeled TIM is how many cycles each instruction uses.
