CX-22 Trackball Left Button Not Working
How to disasemble.
38 replies to this topic
#1 thegamezmaster OFFLINE
thegamezmaster
  • 2,284 posts
Posted Sun Oct 9, 2011 6:33 AM
Hello, got one that the left button doesn't work and having trouble taking apart. Can anyone help? Thanks.
#2 Ataritard OFFLINE
Ataritard
    Moonsweeper
  • 288 posts
Posted Mon Oct 10, 2011 12:05 AM
Take the six screws out of the bottom and pry it apart. It's snug but should come apart. Take the tape off the button contacts and clean them with an eraser or cleaner of some kind and they should work like new.
#3 thegamezmaster OFFLINE
thegamezmaster
  • 2,284 posts
Posted Mon Oct 10, 2011 2:38 PM
Thanks, I'll give it a try and let you know how it works.
#4 thegamezmaster OFFLINE
thegamezmaster
  • 2,284 posts
Posted Thu Nov 24, 2011 10:06 AM
Are the two middle screws different? Can't get out. Help please.
#5 Ataritard OFFLINE
Ataritard
    Moonsweeper
  • 288 posts
Posted Sun Nov 27, 2011 9:54 PM
They are all the same on mine... Are yours not Phillips heads? The two in the middle are deep in there. Can your screw driver reach them?
#6 thegamezmaster OFFLINE
thegamezmaster
  • 2,284 posts
Posted Mon Nov 28, 2011 5:00 AM
They look like some type of security screws. They aren't Phillips and won't even move with a Phillip's screwdriver.
#7 Ataritard OFFLINE
Ataritard
    Moonsweeper
  • 288 posts
Posted Mon Nov 28, 2011 10:03 AM
That's what mine looks like after I take the two middle screws out. You should be able to pry it apart now.
#8 thegamezmaster OFFLINE
thegamezmaster
  • 2,284 posts
Posted Sat Dec 10, 2011 5:27 AM
What did you use to get those two odd middle screws out? Any suggestions would really help me,thanks.
#9 Ataritard OFFLINE
Ataritard
    Moonsweeper
  • 288 posts
Posted Wed Dec 14, 2011 8:30 PM
If the bottom of the holes look like security screws then the Phillips screws have already been taken out. Take something long and thin like a toothpick and stick it down in the hole. If it goes deeper in the middle, then the screw has already been taken out.
#10 thegamezmaster OFFLINE
thegamezmaster
  • 2,284 posts
Posted Thu Dec 15, 2011 2:07 AM
Not quite sure what you mean. The two screws are still in there and unit will not come apart. I'm stumped as how to get out. Thanks.
#11 Ataritard OFFLINE
Ataritard
    Moonsweeper
  • 288 posts
Posted Thu Dec 15, 2011 8:32 AM
Does it look like this?
#12 thegamezmaster OFFLINE
thegamezmaster
  • 2,284 posts
Posted Thu Dec 15, 2011 10:46 AM
Yes but very hard to see just what the screw head looks like. Even shining a flashlight down there. Similar to a star type shape, maybe and hollow in the middle.
#13 Ataritard OFFLINE
Ataritard
    Moonsweeper
  • 288 posts
Posted Thu Dec 15, 2011 10:46 PM
Hollow in the middle...?
What I'm saying is... There is no screw.
#14 thegamezmaster OFFLINE
thegamezmaster
  • 2,284 posts
Posted Fri Dec 16, 2011 6:44 AM
There's something in there because I can only get 4 corner screws out and it still won't come apart. I'm stumped. Thanks tho for all the help, I appreciate it.
#15 Ataritard OFFLINE
Ataritard
    Moonsweeper
  • 288 posts
Posted Fri Dec 16, 2011 11:33 PM
That's too bad. I wanted to hear it popped open. Oh well.
#16 thegamezmaster OFFLINE
thegamezmaster
  • 2,284 posts
Posted Sat Dec 31, 2011 6:01 AM
Still no luck. Won't come apart and two odd looking security screws in the middle screws holes. Bummer!
#17 dendawg OFFLINE
dendawg
    Chopper Commander
  • 204 posts
Posted Sun Jan 8, 2012 1:38 AM
Sounds like it's probably a Torx or Security Torx (just like a Torx screw except there's a pin in the middle of the star) screw in there.
#18 thegamezmaster OFFLINE
thegamezmaster
  • 2,284 posts
Posted Sun Jan 8, 2012 6:52 AM
Thanks for the reply. Don't have any of those, darn it. Not sure but doesn't look like it has a pin in the middle as far as I can make out.
#19 Ataritard OFFLINE
Ataritard
    Moonsweeper
  • 288 posts
Posted Sun Jan 15, 2012 11:57 PM
Can you take a screw from one of the four corners and screw it into one of the two middle holes?
#20 thegamezmaster OFFLINE
thegamezmaster
  • 2,284 posts
Posted Tue Apr 3, 2012 7:43 AM
Can't get the two middle ones out. That's the problem.
#21 tripletopper OFFLINE
tripletopper
    Star Raider
  • 58 posts
Posted Tue Apr 17, 2012 2:15 AM
I'm in the same sitch as theGamezmaster. Then I got to the point of the "two middle screws" not coming out. At first I thought it was a proprietary screw, so I searched Atari CX22 Bristol Screw and came on this page. Then I read this forum, and I got Ataritard's comment, the center holes also had the same sized philips head screws. theGamezmaster insists it's a proprietary screw. So I took a leap of faith. I noticed the lip between the top and bottom was a little loose, so I took a flathead, carefully separated it by running the flathead around the seam to make it loose enough so a pry doesn't damage the casing in case I did t wrong, pried it open and viola. It was opened. I used CD cleaner (Isopropyhol) to clean it. Will test it tomorrow when housemates are awake.
By the way, if a left hand button is ruined, does that mean the main user before me was right handed? And if that's the case, why do right handers put up with left-handed Street Fighter joysticks, especially when you have to pull of those Dragon Punches? If both hands can type equally well, why use your good hand or the button pressing when it can be used for the more complex motion of moving a joystick/paddle/trakball? Posting this segue as a separate post unrelated to the trakball.
#22 thegamezmaster OFFLINE
thegamezmaster
  • 2,284 posts
Posted Tue Apr 17, 2012 6:46 AM
So were you able to take out the two middle screws? Sorry if it's a dumb question.
#23 tripletopper OFFLINE
tripletopper
    Star Raider
  • 58 posts
Posted Tue Apr 17, 2012 7:29 AM
It's not a dumb question. It's just found one person who said you could pry it open, and it doesn't permanently ruin the trakball. If you didn't ask the question, I wouldn't have found this answer, so thank you.
#24 thegamezmaster OFFLINE
thegamezmaster
  • 2,284 posts
Posted Tue Apr 17, 2012 2:11 PM
Thank you for your input. I'll give what you did a try! Thanks again.
#25 thegamezmaster OFFLINE
thegamezmaster
  • 2,284 posts
Posted Tue Apr 17, 2012 3:07 PM
Tried what tripletopper did and it came apart! Further checking when assembled the button doesn't work. Take it apart and press on the button, it works. So I've tried putting tape on it, no luck. So I put some glue on it, waiting for it to harden and will try again. If that doesn't work, guess it's time for a new button and switch. Thanks everyone.
