ROM PAL to NTSC conversion needed or...?
6 replies to this topic
#1 Silntdoogood OFFLINE
Silntdoogood
    Chopper Commander
  • 140 posts
Posted Thu Nov 10, 2011 6:02 PM
I'm new to the home-brew editing/writing type people. I've been playing them for years, just not working on them. I would presume these are problems that have been confronted at some point, so linking to forums threads are acceptable answers.
I dug up a home-brew ROM that is only available in a PAL format. I've been running it in Stella, and it is no big problem. Large margins on the top and left of the screen, but no walking or anything. I am thinking of putting a cart together for this, to use on a real system. It's an NTSC system. I am not expecting this to work as well in this setting. Is there any easy conversion process to get the ROM from PAL to NTSC, or does it need re-coded from scratch?
#2 GroovyBee OFFLINE
GroovyBee
    Games Developer
  • 9,798 posts
  • Busy bee!
Posted Thu Nov 10, 2011 6:05 PM
If its homebrew you might want to try and track down the original author before you start hacking it and making a cart out of it.
#3 Phredreeke OFFLINE
Phredreeke
    Chopper Commander
  • 198 posts
Posted Thu Nov 10, 2011 6:23 PM
IIRC PAL to NTSC is harder than the other way around, as PAL has a longer VBLANK period.
There's no region lockout though so a PAL game will work on an NTSC 2600, but chances are your TV wont be able to sync to it, and if it does the colors will be wrong.
#4 Silntdoogood OFFLINE
Silntdoogood
    Chopper Commander
  • 140 posts
Posted Thu Nov 10, 2011 7:31 PM
I am actively trying to track down the original author, in hopes there's already an NTSC build out there.
#5 GroovyBee OFFLINE
GroovyBee
    Games Developer
  • 9,798 posts
  • Busy bee!
Posted Thu Nov 10, 2011 7:42 PM
It might help if you let people know what the game is called or provide some screenshots of it, if you don't know.
#6 Silntdoogood OFFLINE
Silntdoogood
    Chopper Commander
  • 140 posts
Posted Fri Nov 11, 2011 2:53 PM
Well, now I feel like an idiot. I was running it on the Puppy Arcade, and running that from a flash-drive install. I went to grab a screencap, and the flash-drive is now corrupt or in need of formatting.If I can recover the ROM, I'll post a screenie. I knew using a flash-drive as a primary shortened their life...but I didn't think I'd loose it this quickly. Hopefully it's something easy to fix...or I have a backup of the ROM somewhere. :(
#7 CPUWIZ OFFLINE
CPUWIZ
    Commander
  • 33,941 posts
  • I am the one who knocks!
Posted Fri Nov 11, 2011 3:19 PM
Flash drive corruption or not, what is the name of the game?
