Peritel boards
58 replies to this topic
#26 BillC OFFLINE
BillC
  • 1,835 posts
Posted Thu Nov 8, 2012 5:34 PM
Audio and composite video most likely.
Mitch
Some monitors have separate Horizontal & Vertical sync as well. This device was most likely for an Atari arcade game system, not a computer
#27 www.atarimania.com OFFLINE
www.atarimania.com
  • 1,726 posts
Posted Fri Nov 9, 2012 2:31 PM
I can't look this up right now but did you check whether the item appears in Atari's 8-bit master list? You'll find it on our site in the "docs" section.
Atari Frog
http://www.atarimania.com
#28 atari-passion OFFLINE
atari-passion
    Chopper Commander
  • 170 posts
Posted Sun Nov 18, 2012 9:43 AM
Hello,
I know what is this board :cool: , because I have in my xxxxxxxx :evil:
soon, I'll make pretty pictures :twisted:
Arnaud
Edited by atari-passion, Sun Nov 18, 2012 9:43 AM.
#29 atari-passion OFFLINE
atari-passion
    Chopper Commander
  • 170 posts
Posted Sun Nov 18, 2012 2:42 PM
Hello
this card is an adapter for French television standard.
it is present in my atari 800 French
my card is a revision of 1982.
same reference:
peritel Adaptor
CA061034
yes, 8 pin DIN for video
Posted Image
Posted Image
Posted Image
Arnaud
Edited by atari-passion, Sun Nov 18, 2012 2:49 PM.
#30 Stephen OFFLINE
Stephen
  • 7,136 posts
  • A8 Gear Head
Posted Sun Nov 18, 2012 4:04 PM
The mystery is solved! Thanks for posting.
#31 Mathy OFFLINE
Mathy
  • 2,680 posts
Posted Sun Nov 18, 2012 4:31 PM
Hello Arnaud
What's on the other side of the PCB?
Sincerely
Mathy
#32 mimo OFFLINE
mimo
    Preppie!
  • 6,813 posts
  • It's easy living in a bubble
Posted Mon Nov 19, 2012 8:03 AM
So if any are for sale I am v v interested
#33 bombidragon OFFLINE
bombidragon
    Chopper Commander
  • 132 posts
Posted Mon Nov 19, 2012 12:54 PM
I Need to see how many I have, I wonder how much it would be to have the chinese reproduce these? RGB is popular right now.
#34 mimo OFFLINE
mimo
    Preppie!
  • 6,813 posts
Posted Mon Nov 19, 2012 1:58 PM
that is a good idea, it looks pretty simple, should be fairly inexpensive to reproduce, maybe in a smaller form factor. Wonder if it would work on a 400/XL/xeż
#35 atari-passion OFFLINE
atari-passion
    Chopper Commander
  • 170 posts
Posted Mon Nov 19, 2012 3:03 PM
Hello,
here is the other side ;)
Posted Image
my Atari 400 has a similar card with a direct cable scart.
Arnaud
#36 Mathy OFFLINE
Mathy
  • 2,680 posts
Posted Mon Nov 19, 2012 3:35 PM
Hello guys
@Arnaud: Thanks for the picture.
@Mimo: Shouldn't be to hard for somebody who's designed PCB's before, to reduce this to at least half the size.
Sincerely
Mathy
#37 BillC OFFLINE
BillC
  • 1,835 posts
Posted Mon Nov 19, 2012 3:38 PM
It appears the DIN8 connector was commonly used for Peritel before they standardized on the SCART/Euro connector, which became compulsory on all new television sets sold in France starting from January 1980.
The ZX Spectrum +3 also used the DIN8 and I came across the following instructions for building an SCART adapter cable for it. It should be possible to adapt to other connectors using the SCART pinout information but RGB output may require a 15MHz compatible monitor.
Attached File  ZX Spectrum +3 Scart Lead.pdf   92.28KB   420 downloads
#38 mimo OFFLINE
mimo
    Preppie!
  • 6,813 posts
Posted Mon Nov 19, 2012 3:57 PM
I would doubt that it would need a 15mhz monitor. Surely this was produced to use in the home on a standard TV set
#39 mimo OFFLINE
mimo
    Preppie!
  • 6,813 posts
Posted Mon Nov 19, 2012 3:59 PM
Hello,
Posted Image
Arnaud
How different is the 400 board? Any chance of some pictures? I would love an rgb 400
#40 bombidragon OFFLINE
bombidragon
    Chopper Commander
  • 132 posts
Posted Thu Nov 22, 2012 10:28 AM
The Plot thickens. I Just realized I got my Atari 800 and 400 from the same guy and both of them have wood grain, screw down, cartridge doors made out of steel. I can't even find a picture of these things. All of the ones I have seen have plastic doors on hinges.
Will post pics later
Edited by bombidragon, Thu Nov 22, 2012 10:29 AM.
#41 bombidragon OFFLINE
bombidragon
    Chopper Commander
  • 132 posts
Posted Thu Nov 22, 2012 1:32 PM
I also have 2 more peritel boards for sale if someone wants to trade or such for them. PM if interested.
#42 adam242 OFFLINE
adam242
    Dragonstomper
  • 942 posts
Posted Thu Nov 22, 2012 11:26 PM
Does this board provide RGB output or is it simply an adapter for the 8-pin standard? My (admittedly limited) understanding of peritel/SCART is that is has connections for composite video as well.
If this board can be cloned to provide an easy RGB output, this is pretty exciting.. Just seems too good to be true.
#43 bombidragon OFFLINE
bombidragon
    Chopper Commander
  • 132 posts
Posted Thu Nov 22, 2012 11:47 PM
Everyone assumes thats what it does. The pic's above should show you how to hook it up.
#44 31336haxx0r OFFLINE
31336haxx0r
    Dragonstomper
  • 516 posts
Posted Fri Nov 23, 2012 3:14 AM
To what parts of the 400/800 does it get connected to?
#45 bombidragon OFFLINE
bombidragon
    Chopper Commander
  • 132 posts
Posted Fri Nov 23, 2012 8:40 AM
Bottom of the main circuit board like in the pic's above. I have not tried one yet because there isn't a space to put it in-in my 800.
Edited by bombidragon, Fri Nov 23, 2012 8:43 AM.
#46 mimo OFFLINE
mimo
    Preppie!
  • 6,813 posts
Posted Fri Nov 23, 2012 9:51 AM
I hope its rgb, the French 7800 has a similar daughter board and that outputs rgb
#47 bombidragon OFFLINE
bombidragon
    Chopper Commander
  • 132 posts
Posted Fri Nov 23, 2012 11:12 AM
Probably Better to wait until mimo gets his. If I had some extra time I could do it to mine.
#48 mimo OFFLINE
mimo
    Preppie!
  • 6,813 posts
Posted Fri Nov 23, 2012 11:40 AM
No guarantee of me fitting it quickly though, I am notoriously crap at getting on with things
#49 bombidragon OFFLINE
bombidragon
    Chopper Commander
  • 132 posts
Posted Fri Nov 23, 2012 7:45 PM
You noticed I'm not guaranteeing installing mine either.
#50 bombidragon OFFLINE
bombidragon
    Chopper Commander
  • 132 posts
Posted Sun Dec 30, 2012 11:12 PM
You get time to install the board mimo?
