5200 gold kit
AtariBrian
I've been thinking about the tinfoil improvement. I cleaned my carbon dots and the mesh where a connection is made, but I still need to squeeze the buttons a bit harder than I'd like. Do you simply glue a tiny bit of tinfoil to each carbon dot? Doesn't the glue interfere with the connection?
your fire buttons have packed in? @cafeman i have one with tinfoil i got from ebay years ago and it works great. for the fire buttons they cut a longer strip for each of sets of contacts. and yes superglue a tinfoil piece from using a hole punch. im gonna take mine apart tonight or tomorrow and check it out. or put in the gold and problems should be solved forever. it helps for when im playing koffi and adventure 2 ;)
Edited by AtariBrian
Yep, just glue (something stronger than Elmer's like Krazy Glue or Gorilla Glue) a bit of tin foil to the carbon dots on the fire buttons and the Start/Pause/Reset buttons. The glue doesn't interfere with the connection as it's not part of the connection... the connection is made between the foil and the flex circuit. You're just replacing the carbon dot as a conductor with the foil. Works pretty well in my experience, although for ergonomic reasons I still prefer a Wico or Competition Pro joystick over the standard 5200 stick. I just personally hate side-mounted fire buttons on all systems that feature them (5200, Colecovision, Intellivision, 7800)
  • 2 weeks later...
I did the Aluminum Foil Dots this week and it's like the controllers are completely different ones. Who would have thought such a simple solution would make such a difference. I've fot some rev 9 flex circuits on order. Current ones in my controllers are Rev 7. Since I don't play my 5200 heavily, it'll probably be more than enough for my purposes.
