ATR Tools
First Release
218 replies to this topic
#176 DrVenkman OFFLINE
DrVenkman
  • 3,633 posts
  • Back off, man! I'm a scientist.
Posted Wed Jun 13, 2018 4:26 PM
Regarding the "no window/no icon" issue some are reporting, I have some details of my own. I tried the latest build tonight on my Win10 64-bit Home system tonight and had the same problem - no icon in the task bar, no program window. I opened the Windows Task Manager and found the ATR Tools process was present but consuming 0% CPU time and basically not doing anything.
So I went to the Details tab of the Task Manager, right clicked on the process and selected "Analyze wait chain" - it seems that for some reason, ATR Tools was waiting for another running task on my laptop (Roland Cloud Manager, a background application for account validation and download/access to Roland VST soft-synths). I killed the Roland Cloud Manager process and the ATR Tools window and taskbar icon both appeared immediately.
#177 SS OFFLINE
SS
  • 6,229 posts
Posted Wed Jun 13, 2018 6:10 PM
  -  06/13/2018  -  Changed SendMessage() to SendNotifyMessage() for Font Display.
ATRTools-027f.zip
This newest build is working fine on my Win10 x64 system. I also just tried out a drag-and-drop of an EXE file into a newly created ATR and that worked fine for me as well.
#178 rdea6 OFFLINE
rdea6
  • 2,762 posts
Posted Wed Jun 13, 2018 6:18 PM
attachicon.gifATRTools-027f.zip
Recent files: Is always empty for me on all startups, but they show if the program never closes between new ATR's
#179 FULS OFFLINE
FULS
    Moonsweeper
  • 338 posts
Posted Wed Jun 13, 2018 6:30 PM
That works for me.
Thank you DrVenkman for the work around.
And thank you AtariGeezer for such a useful tool.
#180 DjayBee OFFLINE
DjayBee
    Moonsweeper
  • 332 posts
Posted Thu Jun 14, 2018 1:46 AM
Thanks, but it did not solve the long startup time when LibreOffice is running.
It waits for soffice.bin.
Edited by DjayBee, Thu Jun 14, 2018 1:48 AM.
#181 flashjazzcat OFFLINE
flashjazzcat
  • 14,160 posts
Posted Thu Jun 14, 2018 2:26 AM
Updated version running OK here. ;)
#182 Keatah OFFLINE
Keatah
    Missile Commander
  • 21,783 posts
Posted Thu Jun 14, 2018 5:03 PM
Which OS are you using?
Drag-n-Drop works from Win95 to XP and I think I checked it on Win 7 too...
XP. Still no go here. If I want to open an ATR image, I have to go through the pull-down menus and all that. Can't drop an ATR image into the program to open it and can't drop it onto the exe. or shortcut either.
Though the equivalent program for Apple II (Ciderpress) allows this, so I don't believe it's my system unless there IS some difference or setting I'm not aware of.
#183 SS OFFLINE
SS
  • 6,229 posts
Posted Thu Jun 14, 2018 5:09 PM
I have nothing but disdain for WinXP. I would be inclined to blame that stupid OS for any troubles that befall you.
#184 AtariGeezer ONLINE
AtariGeezer
  • 2,853 posts
Posted Thu Jun 14, 2018 5:10 PM
Gotcha, a misinterpretation here on my end.  No, dropping an ATR isn't implemented yet,  Thought you were referring to files in general...
Now on the ToDo List :)
#185 Marsupilami OFFLINE
Marsupilami
    Chopper Commander
  • 129 posts
  • looking 4 Atari FR/DE/BX/IT software
Posted Fri Jun 15, 2018 1:53 PM
DrVenkman was right ! Thanks !  :thumbsup:
It seems to be a problem with some files related to my Nvidia driver and ATRtool 27e.
But the 27f version fixed the problem, well done ! Thanks for this great tool !
#186 rdea6 OFFLINE
rdea6
  • 2,762 posts
Posted Sat Jun 16, 2018 5:49 AM
This is a Work-In-Progress program that runs on Windows.
It allows you to do many things with ATR, XFD and PRO images...
http://www.fiftyonef...i/AtrTools.html
Jay
I think that my current problem with Atr Tools is that I don't have the original program set up file and this link is dead.
#187 SS OFFLINE
SS
  • 6,229 posts
Posted Sat Jun 16, 2018 6:08 AM
I don't have the original files either and installing v0.27f worked just fine for me.
#188 Mclaneinc OFFLINE
Mclaneinc
    Retro Madman
  • 6,245 posts
Posted Sun Jun 17, 2018 7:04 AM
Hi folks, just started a thread to try and finda DOS file cataloguing utility, ie scan disks, those with DOS files like BAS DAT or other Extensions get listed to a big list so I can find some stuff as otherwise unless you do them one at a time its all quite hidden.
Anyway, Rdea's suggest ATRtools and I tried scanning ATR's by the Tools option but it starts and then after a sec crashes, I tried 26F and 27f and both do it..
What am I doing wrong?
I'm sure its me...
Help in any part would be appreciated and will ATRtools batch scan loads of ATR's to make a list or one at a time?
I can get a listing if I OPEN an ATR initially (as long as it has a DOS format)...
AM I mistaking the scan for something else and as said will it do batched and compile a big list?
#189 Fox-1 / mnx OFFLINE
Fox-1 / mnx
  • 1,556 posts
  • What is your Alternate Reality?
Posted Sun Jun 17, 2018 8:28 AM
I think "XDIRLIST"  http://members.home.nl/stack/Atari/atarixle.html#XDIRLIST does what you want but it's an old MS-Dos tool.  Getting it to work on modern O.S.' requires some effort.
#190 Mclaneinc OFFLINE
Mclaneinc
    Retro Madman
  • 6,245 posts
Posted Sun Jun 17, 2018 8:46 AM
Thanks fox, I'll bet it hates X64 as well, so much hassle to get it to go...I'll look but if its all that I'll probably pass...I want to do all this but without wishing to hang myself :)
Thank you for the help Fox..
Paul..
Got it going with DOSBox but its clunky as hell...Works but clunky...Files have to be in the newly mounted drive before its added, so if you do a batch you need to restart and get the next lot of files and add then mount etc etc..
BUT, it does indeed work.. Still keen to know if ATRtools will do it and why it crashes...
But super help Fox..
Edited by Mclaneinc, Sun Jun 17, 2018 9:07 AM.
#191 Fox-1 / mnx OFFLINE
Fox-1 / mnx
  • 1,556 posts
Posted Sun Jun 17, 2018 9:17 AM
It's too bad Bo and Ernest don't do much Atari related things these days.  Their Atari 8-Bit MS-Dos tools were one of the first of this kind, all done in assembly, so, small and fast.  Had an MS-Dos box running for many years with basically nothing installed but Volkov Commander, SIO2PC, and all those tiny XL/XE tools.
#192 AtariGeezer ONLINE
AtariGeezer
  • 2,853 posts
Posted Sun Jun 17, 2018 12:03 PM
ATR Tools never used an installer.  Saving program settings to the Registry or an ".ini" file is done when closing the program.
#193 AtariGeezer ONLINE
AtariGeezer
  • 2,853 posts
Posted Sun Jun 17, 2018 12:06 PM
Thanks Paul,  I'll look into it...
#194 FULS OFFLINE
FULS
    Moonsweeper
  • 338 posts
Posted Tue Jun 19, 2018 7:56 PM
I couldn't find a copy of Missing Links that ran on an XL.
So using ATR Tools, I modified "M-ss-ng L-nks (1984)(Human Engineered Software)(US)[BASIC][OS-B][cr CSS]" to work with all Atari OS's.
I moved the hidden directory to where it should be and modified the Basic program that jumped illegally into the OS-B. It took awhile since I'm very rusty with Basic.
I then added Basic to the disk so it will work with Multi-Carts on the 800.
Boot up the "ALL Atari's" program without Basic installed.
Attached File  M-ss-ng L-nks (1984)(Human Engineered Software)(US)BASICOS-Bcr CSS.atr   90.02KB   35 downloads
Attached File  M-ss-ng L-nks (1983)(Human Engineered Software) ALL Atari's.atr   90.02KB   46 downloads
#195 morelenmir OFFLINE
morelenmir
  • 1,544 posts
Posted Sat Aug 4, 2018 2:12 PM
This is an amazing piece of software, it takes up where 'makeATR' leaves off and runs another half mile or so!  It is absolutely invaluable for putting together disks for for flashing SDX and U1MB/SIDE2/other hardware mods.
Many, many thanks for continuing to support it.
#196 morelenmir OFFLINE
morelenmir
  • 1,544 posts
Posted Wed Sep 19, 2018 12:12 PM
On loading an *.ATX image I find the 'ATX>Convert ATX to ATR' menu item greyed out. Is this a currently unimplemented feature for a later version or am I doing something wrong?
#197 AtariGeezer ONLINE
AtariGeezer
  • 2,853 posts
Posted Wed Sep 19, 2018 12:16 PM
You have to create an ATR image before you can convert it...
  • SS likes this
#198 morelenmir OFFLINE
morelenmir
  • 1,544 posts
Posted Wed Sep 19, 2018 12:25 PM
I see...  So I cannot convert an existing *.ATX image in to a *.ATR?
Update:
Yes I can.  Excellent!!!
Edited by morelenmir, Wed Sep 19, 2018 12:27 PM.
  • SS likes this
#199 tjlazer OFFLINE
tjlazer
  • 2,127 posts
  • Retro Atari Addict
Posted Thu Oct 25, 2018 12:35 AM
Found a bug, if you try to rename a file in a disk image you open, it won't let you press enter after typing new name and if you press ESC or cancel it sometimes adds weird characters or crashes.
#200 AtariGeezer ONLINE
AtariGeezer
  • 2,853 posts
Posted Thu Oct 25, 2018 4:19 PM
Thanks for the report, will look into it :)
