Painting Colecovision/Controllers
19 replies to this topic
#1 cOLeCoHiTMan OFFLINE
cOLeCoHiTMan
    Moonsweeper
  • 457 posts
  • Let's Go Red Wings!
Posted Mon Jan 9, 2012 3:24 PM
Has anyone tried using Krylon Fusion Plastic paint to
a) mod a Colecovision case to another color?
b) make the ADAM controllers match the Colecovision black? I see lots of the Adam controllers out there not so many Colecovision black ones.
I'm tempted to try on the damaged cover I have once I get the replacement from 4jays.net.
http://www.krylon.co...on_for_plastic/
#2 pimpmaul69 ONLINE
pimpmaul69
  • 4,665 posts
  • INTV Brotherhood Technician
Posted Mon Jan 9, 2012 4:15 PM
http://www.
Ipod Touch 3G 32GB Bezel Mid Frame for Glass Digitizer
Expedited shipping available
 Returns: Accepted within 30 days
Buy It Now
$6.98
Free shipping Time left:4d 20h 50m
Use plastic dye
#3 RedRaider OFFLINE
RedRaider
    Dragonstomper
  • 594 posts
  • RRTech Labs
Posted Sat May 19, 2012 11:28 PM
Did you ever paint your controllers?
If so, I would like to see some pics.
#4 cOLeCoHiTMan OFFLINE
cOLeCoHiTMan
    Moonsweeper
  • 457 posts
Posted Sun May 20, 2012 10:21 AM
nope.. still sitting in a box. you say the white one that another member did didn't you?
#5 RedRaider OFFLINE
RedRaider
    Dragonstomper
  • 594 posts
  • RRTech Labs
Posted Sun May 20, 2012 3:35 PM
I sure did, very sexy.
#6 cOLeCoHiTMan OFFLINE
cOLeCoHiTMan
    Moonsweeper
  • 457 posts
Posted Sun May 20, 2012 7:24 PM
I'm in an apartment so I need to go to a relatives house where I have lots of free space for painting LOL
what i want to do is find an almond colour to match the controllers to do the main console, then do the power button, reset button and the front by door in a brownish-red.... if that doesn't look good, all one colour like the albino one!
#7 RedRaider OFFLINE
RedRaider
    Dragonstomper
  • 594 posts
  • RRTech Labs
Posted Sun May 20, 2012 7:35 PM
Are you considering sanding the system smooth or keeping the existing textured finish?
#8 cOLeCoHiTMan OFFLINE
cOLeCoHiTMan
    Moonsweeper
  • 457 posts
Posted Sun May 20, 2012 7:39 PM
Straight painting over after maybe a light sanding to make paint grab better..
If i mess up, I'll just use another console case and pop the guts in it...
#9 RedRaider OFFLINE
RedRaider
    Dragonstomper
  • 594 posts
  • RRTech Labs
Posted Sun May 20, 2012 7:47 PM
I'm debating on whether to keep the texture or not? If I keep it I'm going either flat black or semi-gloss. If I decide to sand it, gloss with clear coat all the way.
The trick will be not to mess up in all the little channels and crevices, those at the kicker if you want a complete quality job.
#10 RedRaider OFFLINE
RedRaider
    Dragonstomper
  • 594 posts
  • RRTech Labs
Posted Mon May 21, 2012 1:25 PM
Ok, decided to go with Vinyl Dye for both the Colecovision and Intellivision.
Light sanding only, then dying.
#11 SKELETOR68 OFFLINE
SKELETOR68
    Moonsweeper
  • 359 posts
Posted Tue May 22, 2012 11:14 AM
Would like to see the finished Coleco.
#12 Yurkie OFFLINE
Yurkie
    Q*bert Champion
  • 3,825 posts
  • Offering mods for ColecoVision and NESRGB
Posted Tue May 22, 2012 1:04 PM
You NEVER want to sand. Vinyl Dye chemically bonds with the surface. Sanding is just asking for problems. Wash the housings in the sink with DAWN dishsoap and use a plastic safe scotchbrite pad. and then clean with 99% Isopropyl Alcohol. You might want to wear gloves with the alcohol because it will dry the hell out of your skin. Use a toothbrush to get in all the tight spots with the alcohol. If you want to spend extra ask the Vinyl Dye seller they sell surfuce cleaner, but from my understanding alcohol will do the same thing.
#13 RedRaider OFFLINE
RedRaider
    Dragonstomper
  • 594 posts
  • RRTech Labs
Posted Tue May 22, 2012 1:59 PM
Thank you for the advice Yurkie. :thumbsup:
#14 cOLeCoHiTMan OFFLINE
cOLeCoHiTMan
    Moonsweeper
  • 457 posts
Posted Tue May 22, 2012 7:49 PM
I bought a box of TSP.. is that bad to use?
#15 Yurkie OFFLINE
Yurkie
    Q*bert Champion
  • 3,825 posts
Posted Tue May 22, 2012 11:32 PM
What is TSP? Tractor Supply Plus?
#16 cOLeCoHiTMan OFFLINE
cOLeCoHiTMan
    Moonsweeper
  • 457 posts
Posted Wed May 23, 2012 4:38 AM
trisodium phosphate
http://www.homedepot...er-400-g/912197
#17 Yurkie OFFLINE
Yurkie
    Q*bert Champion
  • 3,825 posts
Posted Wed May 23, 2012 11:21 AM
I used the above method for around 27 sets of Mario controllers and 25 or 30 Smurf controllers with fantastic results. If you choose to try something else best of luck.
#18 the.golden.ax OFFLINE
the.golden.ax
  • 12,499 posts
Posted Wed May 23, 2012 11:34 AM
Same here, done the same steps on hundreds of 7800 controllers over the years. Why mess with what works I say. :thumbsup:
#19 cOLeCoHiTMan OFFLINE
cOLeCoHiTMan
    Moonsweeper
  • 457 posts
Posted Wed May 23, 2012 12:11 PM
well I've already got armour all on the case so i was figuring i'd need a stronger clean than dishsoap to clean it... got no problem trying the other steps.
#20 the.golden.ax OFFLINE
the.golden.ax
  • 12,499 posts
Posted Wed May 23, 2012 12:42 PM
Yikes, armor all is going to prevent dye from sticking.
