Is This Sound Reaosning?
2 replies to this topic
#1 yell0w_lantern OFFLINE
yell0w_lantern
    Dragonstomper
  • 623 posts
  • Miki is Back!
Posted Thu Jan 19, 2012 8:52 AM
Sorry, that should read, "Reasoning".
I'm getting a 'pres play on tape' message when I try to load disk images to my C64 using an Ultimate 1541 II. When I use a different C64 I do not get this message.
I'm going to replace the kernal with Jiffy DOS thinking that the 'press play on tape' message must be due to a DOS error since DOS means, "disk operating system."
Edited by yell0w_lantern, Thu Jan 19, 2012 8:52 AM.
#2 The Usotsuki OFFLINE
The Usotsuki
  • 1,911 posts
  • Also called "Licca"
Posted Thu Jan 19, 2012 9:14 AM
Stock kernel usually says that unless you specify device 8 (the floppy drive).
#3 yell0w_lantern OFFLINE
yell0w_lantern
    Dragonstomper
  • 623 posts
  • Miki is Back!
Posted Thu Jan 19, 2012 9:33 AM
Right, you have to do something like this:
LOAD"*",8,1
The thing is that the same load method (the Ultimate II 'run' option) is producing different results on two different computers.
