I have among other Ataris a Brazilian unit manufacturer in 1988. Which then uses the PALM video system/format. It is not working, if I insert the cartridge (palm cartridge of course) and it shows noise and static on the screen. I opened the console and it seems that the solder joint and soldering points at the RIOT is failing, apparently the circuit track whereon the solder is suppose to adhere is gone. Below is a pic of the:
Any insight on how to best approach such issue would be appreciated.
