Assembly question
4 replies to this topic
#1 atari2600land OFFLINE
atari2600land
    I should be a myrmecologist.
  • 9,715 posts
  • Shwam.
Posted Mon Jan 30, 2012 8:17 PM
How does one do "if a>#07eh" in assembly? Right now I've got this:
    movx a,@r0
    add a,#07eh        ; check right boundary
    jnz loop_2b
Which I'm guessing only checks to see if the sprite is at (and only at) #07eh, but I'd like to check for greater numbers than #07eh as the game progresses and the sprites move faster.
#2 Rybags ONLINE
Rybags
  • 14,199 posts
Posted Mon Jan 30, 2012 8:45 PM
In 6502 you need one of the compared numbers in A.
e.g.
LDA XPOS
CMP #LEFTSIDE
BCS NOT_HIT
CMP does a subtract without affecting the register. Carry is set if A >= the immediate data or content on memory. Carry clear if A < data.
Branches are relative and limited in range. If the range isn't big enough then you can use JMP - but Jump can't have conditions so you typically branch around it on the opposite condition.
e.g.
LDA XPOS
CMP #LEFTSIDE
BCC HIT
JMP NOT_HIT
#3 atari2600land OFFLINE
atari2600land
  • 9,715 posts
  • Shwam.
Posted Mon Jan 30, 2012 9:05 PM
What does the Odyssey2 use? 6502?
#4 GroovyBee OFFLINE
GroovyBee
    Games Developer
  • 9,274 posts
  • Busy bee!
Posted Tue Jan 31, 2012 6:52 PM
:? Erm... How can you code in assembly language for the Videopac if you don't know what the processor is? Anyways... something like this should work (however I'm not a Videopac programmer) :-
    add a,#081h        ; check right boundary
    jc BeyondRightBoundary
Which will jump to the BeyondRightBoundary label when a >= 0x7F (which is like saying a > 0x7E).
You'll need to make reference to chapter 5 in the following document for a list of 8048 opcodes :-
http://home.mnet-onl...s-48/mcs-48.pdf
#5 atari2600land OFFLINE
atari2600land
  • 9,715 posts
  • Shwam.
Posted Wed Feb 1, 2012 2:10 AM
Yeah, I know. I am trying really hard to learn assembly, but it's really hard. And what's even more difficult is that if I decide to do assembly for the Atari 2600, I'd need to learn more assembly! There are still some things I just don't get yet, but I hope to some day make a game that's good for the Videopac (the Odyssey2 here in the US.) Maybe Fatso! will be it...
