Redemption calibration problems
5 replies to this topic
#1 Gaztee OFFLINE
Gaztee
  • 1,673 posts
Posted Wed Feb 1, 2012 7:30 PM
Finally got my grubby mitts on a redemption controller, but I'm having problems calibrating it to work with a cx40 or genesis/md pad. The instructions say to push the controller in all 4 directions before you start a game for the first time, but I can't get it to work. All that happens is that the ship (centipede) goes off in a NE direction & won't move any where else. With keystone kapers Kelly just runs left straight into the elevator & I can't get him out!
What am I doing wrong? I'm doing the calibration after the boot up screen!
Cheers in advance
Gaz
#2 Gaztee OFFLINE
Gaztee
  • 1,673 posts
Posted Thu Feb 9, 2012 8:45 PM
Nobody got squat for me?? :(
#3 sdamon OFFLINE
sdamon
  • 1,518 posts
Posted Fri Feb 10, 2012 9:38 AM
I don't have a Redemption, but I do know there is a calibration pot inside the 5200 itself that may help. Pics of where it is located can be found in this thread:
http://www.atariage...._1#entry2280867
#4 Gaztee OFFLINE
Gaztee
  • 1,673 posts
Posted Sat Feb 11, 2012 8:21 AM
Thanks for the info, but I don't think that exactly what I'm after. Guess I will have to PM Albert as he was in on the design of the Redemption I believe!
#5 Prodos8 OFFLINE
Prodos8
  • 2,260 posts
  • Where is John Galt?
Posted Sun Feb 12, 2012 7:26 PM
You need to adjust the little centering pot inside your 5200 console. I made a masterplay clone for myself and it basically didn't work at all until I properly adjusted the little pot inside the console.
I used Super Break Out to make the adjustment but Missle Command will work as well, just turn the thing a few times back and forth and then, with your redemption plugged in the controller port, adjust it so that the paddle/cursor is centered on your screen. After you do this your Redemption should work just fine. I know on some games, Galaxian comes to mind, you have to kinda thrash the stick around a few times before they work even after you make the centering pot adjustment.
Edited by Prodos8, Sun Feb 12, 2012 7:29 PM.
#6 Gaztee OFFLINE
Gaztee
  • 1,673 posts
Posted Mon Feb 13, 2012 5:57 PM
Thanks, I'll give it a shot later in the week :)
