TurboBasicXL problem
Fails to load under MyDOS
134 replies to this topic
#51 Larry OFFLINE
Larry
  • 3,173 posts
Posted Mon Feb 20, 2012 6:07 AM
Sure, can't hurt to try!
-Larry
I have a patched DOS 2.5 somewhere that replaced the RUN CARTRIDGE with TURBOBASIC.
Anyone interested in that? It might give you anymore ideas about what is happening ....
Let me know!
#52 flashjazzcat OFFLINE
flashjazzcat
  • 10,689 posts
Posted Mon Feb 20, 2012 7:36 AM
Of course MEM.SAV must be active to do a re-run from DOS at $2080...
#53 JAC! OFFLINE
JAC!
  • 1,353 posts
  • Always looking for GFX and MSX for my demos
Posted Mon Feb 20, 2012 10:01 AM
Here is the extended version "test.xex" which outputs all CIO calls/P/A/X/Y of the $6000 loader. Press a key after each call to continue. It normally ends with BMI/Y=$88=136=EOF.
Edited by JAC!, Mon Feb 20, 2012 10:02 AM.
#54 bob1200xl OFFLINE
bob1200xl
  • 2,388 posts
Posted Mon Feb 20, 2012 10:09 AM
This looks useful! What are the number fields?
Bob
#55 JAC! OFFLINE
JAC!
  • 1,353 posts
Posted Mon Feb 20, 2012 10:59 AM
call no. / iccom / icba / icbl / P-register / A-register / X-Register / Y-Register
count / 7 = BGET / buffer address / buffer length / $31 or $81 if Y>=$80 / $10 (channel 1) / CIO Status ($01 = OK, $88 = EOF)
#56 bob1200xl OFFLINE
bob1200xl
  • 2,388 posts
Posted Mon Feb 20, 2012 11:33 AM
The problem seems to be that reading the last sector ($ED) does NOT give you an EOF. MyDOS reads sector 1, instead - then loads DUP. On a load from DOS 2.0, it looks like it does get the 136, does a Directory and branches to Prompt.
What program gives you that display?
Bob
#57 JAC! OFFLINE
JAC!
  • 1,353 posts
Posted Mon Feb 20, 2012 12:39 PM
Hi bob, please copy test.xex from the ATR above to your (hard)drive and start it, then post the output here.
Edited by JAC!, Mon Feb 20, 2012 12:40 PM.
#58 ProWizard OFFLINE
ProWizard
  • 4,019 posts
  • Into Stampede
Posted Mon Feb 20, 2012 12:47 PM
This topic probably does not add any extra info, but look here:
http://www.atariage....ost__p__2213745
There you also find that patch for DOS 2.5 to replace the "RUN CARTRIDGE" ... it might be handy.
#59 bob1200xl OFFLINE
bob1200xl
  • 2,388 posts
Posted Mon Feb 20, 2012 1:55 PM
The TURBO file is just DOS and an AUTORUN.SYS file of TBXL - no TEST.XEX...
Bob
#60 JAC! OFFLINE
JAC!
  • 1,353 posts
Posted Mon Feb 20, 2012 2:01 PM
Aargh, wrong file uploaded, sorry. Too many foders on C:\ error. Here's the correct one.
#61 bob1200xl OFFLINE
bob1200xl
  • 2,388 posts
Posted Mon Feb 20, 2012 2:21 PM
You can name it "TBXL_WITH_TRACE_ROUTINE.ATR".
When it moves over to my HDD, you can still reference it by that name. (kept in sector 0)
Thanks.
Bob
#62 bob1200xl OFFLINE
bob1200xl
  • 2,388 posts
Posted Mon Feb 20, 2012 2:43 PM
OK -- I ran TEST.XEX on my HDD system under OmniMon and it loads all the sectors and falls back to DUP, just like before. It does not list any CIO activity at all. I tried it with the 800XL OS and it did the same.
I tried it on a stock 1200XL and it ran with a list, like yours did.
So, whatever you use to break into the loading chain does not work on my new hardware. How is it supposed to list the disk activity?
Bob
#63 JAC! OFFLINE
JAC!
  • 1,353 posts
Posted Mon Feb 20, 2012 3:49 PM
The "test.xex" is a TurboBasic 1.5 Executable where I have exchanged the loader part at $6000 by a modified loader. See attached source. If you don't get any output at all, it means (like you mentioned before) that INIADR=$6000 is not called at all by the DOS. Do you get the "Happy Computer..." loading screen at all (that's the first INIADR segment)?
Which is the device the HDD ist mapped to? "D1:"?
; TurboBasic XL 1.5 - CIO Lister
; Replaces the OS-RAM loader segment at $6000
; JAC! - 2012-02-20
opt l+
flag = 1 ;0=original, 1=with CIO lister
iccom = $0002
icbal = $0004
icbah = $0005
icbll = $0008
icblh = $0009
; OS variables for XL/XE
; page 0 and 2
boot = $0009
dosvec = $000a
dosini = $000c
appmhi = $000e
ramtop = $006a
coldst = $0244
iocb0 = $0340
basicf = $03f8
; PIA
portb = $d301
; ANIC
nmien = $d40e
; ROM vectors
.if flag = 0
ciov = $e456
.else
ciov = loader.print_ciov
.endif
; Code equates
l0097 = $0097
l00a0 = $00a0
l00a1 = $00a1
l00ca = $00ca
l00d4 = $00d4 ;word
l00d6 = $00d6 ;word
l00d8 = $00d8
l00da = $00da ;word
l00dc = $00dc
l208e = $208e
l208f = $208f
l24f8 = $24f8
lb000 = $b000
le000 = $e000
le400 = $e400
le401 = $e401
le424 = $e424
le425 = $e425
lf53a = $f53a
lfffa = $fffa
lfffe = $fffe
l2100 = $2100
l2586 = $2586
lc95f = $c95f
lc9c5 = $c9c5
lcc00 = $cc00
le604 = $e604
; Start of code
.macro m_push
php
pha
txa
pha
tya
pha
.endm
.macro m_pop
pla
tay
pla
tax
pla
plp
.endm
opt h-
org $2000
ins "turbo15.bin",+0,$1542
opt h+
org $6000
.proc loader
ldx le424
ldy le425
inx
sne
iny
stx l24f8
sty l24f8+1
lda #$00
sta nmien
sei
lda #$fe
sta portb
lda #$ab
sta lfffa
lda #$24
sta LFFFa+1
lda #$d0
sta lfffe
lda #$24
sta lfffe+1
lda #>lcc00
jsr copy_charset_to_ram
lda #>LE000
lda #$40
sta nmien
cli
lda #$ff
sta portb
jsr load_segments
lda #$00
sta boot
lda dosini
ldy dosini+1
sta l208e
sty l208f
lda #$80
ldy #$20
sta dosini
sty dosini+1
lda #$fe
sta portb
sta l00ca
ldx #$01
stx basicf
stx boot
dex
stx coldst
jsr le604
lda #$00
sta l00a0
sta l00a1
jsr lc95f
ldy #$1f
ldx #$8a
jsr l2586
.proc copy_autorun_bas
ldy #$1e
loop lda autorun_bas,y
sta (l0097),y
dey
bpl loop
.endp
jsr lc9c5
lda #$ff
pha
lda #$ae
pha
jsr open_editor
dec portb
.proc clear_b000
lda #$00
tay
loop sta lb000,y
dey
bpl loop
.endp
jmp lf53a
.local autorun_bas
.byte $00,$00,$19,$07,$0d,$67,$14,$19,$25,$0f,$0d
.byte 'D:AUTORUN.BAS'
.byte $16,$01,$00,$06,$06,$16,$16
.endl
.proc open_editor
lda #$ff
sta portb
lda #$c0
sta ramtop
lsr
sta appmhi+1
lda le401
pha
lda le400
pha
rts
.endp
.proc copy_charset_to_ram
sta l00d4+1
ldy #$00
sty l00d4
ldx #$04
loop
.proc rom_to_buffer
lda #$ff
sta portb
loop lda (l00d4),y
sta l2100,y
iny
bne loop
.endp
.proc buffer_to_ram
dec portb
loop lda l2100,y
sta (l00d4),y
iny
bne loop
.endp
inc l00d4+1
dex
bne loop
rts
.endp
.proc load_segments
ldx #$10
lda #$d6
sta iocb0+icbal,x
lda #$00
sta iocb0+icbah,x
sta iocb0+icblh,x
lda #$04
sta iocb0+icbll,x
lda #$07
sta iocb0+iccom,x
jsr ciov
bmi last_segment
lda #<buffer_l617c
sta l00da
sta iocb0+icbal,x
lda #>buffer_l617c
sta l00da+1
sta iocb0+icbah,x
lda l00d8
sbc l00d6
sta l00dc
lda l00d8+1
sbc l00d6+1
sta l00dc+1
inc l00dc
sne
inc l00dc+1
lda l00dc
sta iocb0+icbll,x
lda l00dc+1
sta iocb0+icblh,x
jsr ciov
bmi cio_error
.proc copy_to_ram
dec portb
ldy #$00
ldx l00dc+1
beq no_hi
hi_loop lda (l00da),y
sta (l00d6),y
iny
bne hi_loop
inc l00d6+1
inc l00da+1
dex
bne hi_loop
no_hi ldx l00dc
beq no_lo
lo_loop lda (l00da),y
sta (l00d6),y
iny
dex
bne lo_loop
no_lo lda #$ff
sta portb
.endp
bmi load_segments
last_segment
; lda #0
; .byte 2
rts
cio_error
.if flag = 1
lda $d20a
sta $d01a
jmp cio_error
.endif
jmp (dosvec)
.endp
.if flag = 1
.proc print_ciov
m_push
inc cio_count
lda cio_count
jsr print_hex
lda #' '
jsr print_char
lda iocb0+iccom,x
jsr print_hex
lda #' '
jsr print_char
lda iocb0+icbah,x
jsr print_hex
lda iocb0+icbal,x
jsr print_hex
lda #' '
jsr print_char
lda iocb0+icblh,x
jsr print_hex
lda iocb0+icbll,x
jsr print_hex
lda #' '
jsr print_char
m_pop
jsr $e456
php
sta tmpa
pla
sta tmpp
pha
stx tmpx
sty tmpy
lda #' '
jsr print_char
lda tmpp
jsr print_hex
lda #' '
jsr print_char
lda tmpa
jsr print_hex
lda #' '
jsr print_char
lda tmpx
jsr print_hex
lda #' '
jsr print_char
lda tmpy
jsr print_hex
lda #' '
jsr print_char
lda #$9b
jsr print_char
key1 lda $d20f
and #12
cmp #12
beq key1
key2 lda $d20f
and #12
cmp #12
bne key2
ldy tmpy
ldx tmpx
lda tmpa
plp
rts
tmpp .byte 0
tmpa .byte 0
tmpx .byte 0
tmpy .byte 0
.proc print_hex
sta tmpa
m_push
lda tmpa
lsr
lsr
lsr
lsr
tay
lda hextab,y
jsr print_char
lda tmpa
and #15
tay
lda hextab,y
jsr print_char
m_pop
rts
tmpa .byte 0
hextab .byte '0123456789ABCDEF'
.endp
.proc print_char
sta tmpa
stx tmpx
sty tmpy
jsr putchar
ldy tmpy
ldx tmpx
lda tmpa
rts
putchar lda $e407
pha
lda $e406
pha
lda tmpa
rts
tmpa .byte 0
tmpx .byte 0
tmpy .byte 0
.endp
cio_count .byte 0
.endp
.endif
.endp
buffer_l617c
ini loader
opt h-
org $2000
ins "turbo15.bin",+$16c8
Edited by JAC!, Mon Feb 20, 2012 4:02 PM.
#64 bob1200xl OFFLINE
bob1200xl
  • 2,388 posts
Posted Mon Feb 20, 2012 4:17 PM
The HDD isn't mapped anywhere - this is all SIO from a floppy or APE. Even in 1200XL mode, which had NO PBI code at all, TBXL fails.
Anyway, no HDD is in play here. Just hardware.
If $6000 isn't loading TBXL - what is? How could that happen? Whoever is loading TBXL loads up through the last sector of the file, then reads sector $01, then does a Status commnd to the drive and then loads DUP.
Yes, I get the Happy Computer screen and colors.
Wow... that's a lot of code.
Bob
; JAC! - 2012-02-20
opt l+
iccom = $0002
icbal = $0004
icbah = $0005
icbll = $0008
icblh = $0009
; page 0 and 2
boot = $0009
dosvec = $000a
dosini = $000c
appmhi = $000e
ramtop = $006a
coldst = $0244
iocb0 = $0340
basicf = $03f8
; PIA
portb = $d301
; ANIC
nmien = $d40e
; ROM vectors
.if flag = 0
ciov = $e456
.else
.endif
; Code equates
l0097 = $0097
l00a0 = $00a0
l00a1 = $00a1
l00ca = $00ca
l00d4 = $00d4 ;word
l00d6 = $00d6 ;word
l00d8 = $00d8
l00da = $00da ;word
l00dc = $00dc
l208e = $208e
l208f = $208f
l24f8 = $24f8
lb000 = $b000
le000 = $e000
le400 = $e400
le401 = $e401
le424 = $e424
le425 = $e425
lf53a = $f53a
lfffa = $fffa
lfffe = $fffe
l2100 = $2100
l2586 = $2586
lc95f = $c95f
lc9c5 = $c9c5
lcc00 = $cc00
le604 = $e604
; Start of code
.macro m_push
php
pha
txa
pha
tya
pha
.endm
.macro m_pop
pla
tay
pla
tax
pla
plp
.endm
opt h-
org $2000
opt h+
org $6000
.proc loader
ldx le424
ldy le425
inx
sne
iny
stx l24f8
sty l24f8+1
lda #$00
sta nmien
sei
lda #$fe
sta portb
lda #$ab
sta lfffa
lda #$24
sta LFFFa+1
lda #$d0
sta lfffe
lda #$24
sta lfffe+1
lda #>lcc00
lda #>LE000
lda #$40
sta nmien
cli
lda #$ff
sta portb
jsr load_segments
lda #$00
sta boot
lda dosini
ldy dosini+1
sta l208e
sty l208f
lda #$80
ldy #$20
sta dosini
sty dosini+1
lda #$fe
sta portb
sta l00ca
ldx #$01
stx basicf
stx boot
dex
stx coldst
jsr le604
lda #$00
sta l00a0
sta l00a1
jsr lc95f
ldy #$1f
ldx #$8a
jsr l2586
ldy #$1e
sta (l0097),y
dey
bpl loop
.endp
jsr lc9c5
lda #$ff
pha
lda #$ae
pha
jsr open_editor
dec portb
.proc clear_b000
lda #$00
tay
loop sta lb000,y
dey
bpl loop
.endp
jmp lf53a
.local autorun_bas
.endl
.proc open_editor
lda #$ff
sta portb
lda #$c0
sta ramtop
lsr
sta appmhi+1
lda le401
pha
lda le400
pha
rts
.endp
sta l00d4+1
ldy #$00
sty l00d4
ldx #$04
loop
.proc rom_to_buffer
lda #$ff
sta portb
loop lda (l00d4),y
sta l2100,y
iny
bne loop
.endp
.proc buffer_to_ram
dec portb
loop lda l2100,y
sta (l00d4),y
iny
bne loop
.endp
inc l00d4+1
dex
bne loop
rts
.endp
.proc load_segments
ldx #$10
lda #$d6
sta iocb0+icbal,x
lda #$00
sta iocb0+icbah,x
sta iocb0+icblh,x
lda #$04
sta iocb0+icbll,x
lda #$07
sta iocb0+iccom,x
jsr ciov
bmi last_segment
lda #<buffer_l617c
sta l00da
sta iocb0+icbal,x
lda #>buffer_l617c
sta l00da+1
sta iocb0+icbah,x
lda l00d8
sbc l00d6
sta l00dc
lda l00d8+1
sbc l00d6+1
sta l00dc+1
inc l00dc
sne
inc l00dc+1
lda l00dc
sta iocb0+icbll,x
lda l00dc+1
sta iocb0+icblh,x
jsr ciov
bmi cio_error
.proc copy_to_ram
dec portb
ldy #$00
ldx l00dc+1
beq no_hi
sta (l00d6),y
iny
bne hi_loop
inc l00d6+1
inc l00da+1
dex
bne hi_loop
no_hi ldx l00dc
beq no_lo
sta (l00d6),y
iny
dex
bne lo_loop
no_lo lda #$ff
sta portb
.endp
bmi load_segments
last_segment
; lda #0
; .byte 2
rts
cio_error
.if flag = 1
lda $d20a
sta $d01a
jmp cio_error
.endif
jmp (dosvec)
.endp
.if flag = 1
.proc print_ciov
m_push
inc cio_count
lda cio_count
jsr print_hex
lda #' '
jsr print_char
lda iocb0+iccom,x
jsr print_hex
lda #' '
jsr print_char
lda iocb0+icbah,x
jsr print_hex
lda iocb0+icbal,x
jsr print_hex
lda #' '
jsr print_char
lda iocb0+icblh,x
jsr print_hex
lda iocb0+icbll,x
jsr print_hex
lda #' '
jsr print_char
m_pop
jsr $e456
php
sta tmpa
pla
sta tmpp
pha
stx tmpx
sty tmpy
lda #' '
jsr print_char
lda tmpp
jsr print_hex
lda #' '
jsr print_char
lda tmpa
jsr print_hex
lda #' '
jsr print_char
lda tmpx
jsr print_hex
lda #' '
jsr print_char
lda tmpy
jsr print_hex
lda #' '
jsr print_char
lda #$9b
jsr print_char
key1 lda $d20f
and #12
cmp #12
beq key1
key2 lda $d20f
and #12
cmp #12
bne key2
ldy tmpy
ldx tmpx
lda tmpa
plp
rts
tmpp .byte 0
tmpa .byte 0
tmpx .byte 0
tmpy .byte 0
.proc print_hex
sta tmpa
m_push
lda tmpa
lsr
lsr
lsr
lsr
tay
lda hextab,y
jsr print_char
lda tmpa
and #15
tay
lda hextab,y
jsr print_char
m_pop
rts
tmpa .byte 0
.endp
.proc print_char
sta tmpa
stx tmpx
sty tmpy
jsr putchar
ldy tmpy
ldx tmpx
lda tmpa
rts
putchar lda $e407
pha
lda $e406
pha
lda tmpa
rts
tmpa .byte 0
tmpx .byte 0
tmpy .byte 0
.endp
cio_count .byte 0
.endp
.endif
.endp
buffer_l617c
ini loader
opt h-
org $2000
#65 russg OFFLINE
russg
  • 1,485 posts
Posted Mon Feb 20, 2012 8:07 PM
I get:
count/iccmd/icba/icbl/31 or B1/
What is this? CB,C5,DF,CF,FF,E6,07/
Chan/Y=status I get 1s except 3 next to last and 88, last.
Edited by russg, Mon Feb 20, 2012 8:36 PM.
#66 JAC! OFFLINE
JAC!
  • 1,353 posts
Posted Tue Feb 21, 2012 12:29 AM
Well, that's what happens when the INIADR=$6000 is not executed: DOS simply loads all following sements (which are in the ROM area,so they have no effect), does not find a RUNADR and hence returns to DUP. I'll create a version with multiple INIADRs to check.
Values of the accumulators when returning from CIO
Seems CIO returns 3 instead of 1 to indicate the last byte has been read.
#67 JAC! OFFLINE
JAC!
  • 1,353 posts
Posted Tue Feb 21, 2012 11:12 AM
Here's a test executable which goes though INIADR 3 times during loading. Every time it outputs a number (1/2/3) and waits for a key. Let's see if the INIADR calls are performed. This is what it looks like in the EMU under MyDOS before it returns to DUP.
#68 bob1200xl OFFLINE
bob1200xl
  • 2,388 posts
Posted Tue Feb 21, 2012 11:38 AM
INIADR works properly - rainbow and all.
Bob
#69 JAC! OFFLINE
JAC!
  • 1,353 posts
Posted Tue Feb 21, 2012 11:51 AM
I won't give up so easily :-) Here's a test.xex which outputs "?" when the $6000 loader is called, and "!" when the loading of the first segment starts.
  • Attached File  test.xex   17.98KB   52 downloads
Edited by JAC!, Tue Feb 21, 2012 11:53 AM.
#70 bob1200xl OFFLINE
bob1200xl
  • 2,388 posts
Posted Tue Feb 21, 2012 12:52 PM
No characters were output - loaded TBXL and reverted to DUP, as always. I would say that it does not execute $6000...
Bob
#71 peteym5 OFFLINE
peteym5
  • 1,269 posts
Posted Tue Feb 21, 2012 7:33 PM
That is weird Turbobasic and MyDos 4.5x does not work together on an 1200XL. With all the hardware mods, could this be an issue with the way PortB works with bank switching, turning Basic and OS on and off? I remember there were issues with different MyDOS 4.5x variants causing some software conflicts. I would have to go between pages in this thread, but did you try 4.53, 4.55, etc? Another thought with the 65816 CPU. could DOS or TB executing any undocumented (illegal) 6502 instructions or be doing JMP/JSR to the OS outside of the jump table?
This is offtopic, but what are the differences between Turbobasic variants 1.5, 2.0, 2.11 etc? Any extra commands or changes in speed? I don't do much with Turbobasic XL anymore, maybe some quick tests here and there. Everygame I write now is all done in Assembly.
Edited by peteym5, Tue Feb 21, 2012 7:43 PM.
#72 bob1200xl OFFLINE
bob1200xl
  • 2,388 posts
Posted Tue Feb 21, 2012 7:43 PM
Not any 1200XL - just my modified system(s).
BASIC and OS work the same as an 800XL.
I don't know much about TBXL, I'm afraid.
Bob
#73 peteym5 OFFLINE
peteym5
  • 1,269 posts
Posted Tue Feb 21, 2012 7:49 PM
Another thought with the 65816 CPU. could DOS or TB executing any undocumented (illegal) 6502 opcode. Some of those opcodes become different instructions with a different CPU. This is also a long shot, but cold TB or Mydos be doing JMP/JSR to the OS outside of the jump table?
#74 JAC! OFFLINE
JAC!
  • 1,353 posts
Posted Wed Feb 22, 2012 5:44 AM
I'm getting closer. I have created a CIO tracer which yielded that MyDos uses a special CIO command $27 to load the COm file. This causes the CIOV to return back to MyDOS $1275. This routine does not perform further CIO calls and seems to skip $6000. Now I'll check what's there.
#75 bob1200xl OFFLINE
bob1200xl
  • 2,388 posts
Posted Thu Feb 23, 2012 8:14 PM
I found that my versions of MyDOS source code do not match the .OBJ code that I run (4.50). Larry found the correct code and I generated a listing and cross-reference for it. It takes a little work, so I am uploading it here.
On your PC (or, whatever...), load this into WordPad, set the margins so the pages line up, and print.
Bob
