C-380 Video Pinball button replacement
16 replies to this topic
#1 Charlie_ ONLINE
Charlie_
  • 2,866 posts
Posted Mon Feb 20, 2012 10:17 AM
I have an Ivory C-380 Video pinball. The buttons were not responding well and it turned out I had to re-flow the solder on the under side of the board. For the right bumper button I even had to run wire from the button to the next solder point along that trace to get it to work.
After all that the RESET button was not working well. I cleaned it but maybe it was just worn out....
Anyway I had a broken set of VCS paddles (I had stolen the pots to make 5200 paddles) and I remembered the buttons look similar.
Turns out the PCB of the Video Pinball has holes in it to take these buttons. So the paddle buttons can be used as replacements in the
Video Pinball. I removed the old button and soldered in the paddle button. Works great!.
I really dig this old C-380. Its been a pain to get going. 1st I had to replace the speaker with a speaker from a PC.
Also the internal female jack for the RF cable was corroded or just broken. I had to cut the cable end off and solder it directly to the back
of the board where the cable was supposed to plug in. Now all this soldering and button replacement....
Now I can enjoy it. I really like the Pinball and Breakout games in this unit.
#2 Charlie_ ONLINE
Charlie_
  • 2,866 posts
Posted Fri Feb 24, 2012 11:14 AM
After fixing this unit it worked for a few days and I was enjoying it. Played it a lot. Then,suddenly, it broke. It thinks the button for the right flipper is being held. I checked continuity and there is no short. The trace runs to a small chip under the metal shield. I can only assume that chip must have gone bad.
I really wanted a wood grain one anyway.
#3 BassGuitari OFFLINE
BassGuitari
  • 4,441 posts
  • Remember how bright the future used to look?
Posted Sat Feb 25, 2012 1:05 PM
I've got a Sears one and I love it. I like the Basketball/Rebound game (or whatever it's called) too. It's tricky at first, but once you get the hang of it it's a good game. I think I scored close to 200 at that once (I'm sure others have done much better!).
Fortunately for me, mine is in really good shape, so I can't really speak to anything in the way of repairing it. You might just need a new unit.
#4 Charlie_ ONLINE
Charlie_
  • 2,866 posts
Posted Sat Feb 25, 2012 8:48 PM
Yeah, I'm keeping an eye on ebay. I'll try to get one as cheap as possible.
Is there a model number on the sears unit or is it also c380?
#5 BassGuitari OFFLINE
BassGuitari
  • 4,441 posts
Posted Sun Feb 26, 2012 1:58 PM
The model number is 99713.
#6 thegamezmaster OFFLINE
thegamezmaster
  • 2,284 posts
Posted Sat Mar 10, 2012 10:48 AM
Just got mine slowly back to life. Great little machine. Still have a problem with static sound through TV. Any thoughts on how to repair? Also in breakout the paddle has lines coming off it, fix? Thanks.
#7 BassGuitari OFFLINE
BassGuitari
  • 4,441 posts
Posted Sat Mar 10, 2012 10:44 PM
You shouldn't have any sound through the TV at all; the game sounds come from an internal speaker. There's no audio signal in the RF connection, hence the static. Just mute/turn down the volume on your television. :)
I don't know about the paddle thing though.
#8 thegamezmaster OFFLINE
thegamezmaster
  • 2,284 posts
Posted Sun Mar 11, 2012 6:21 AM
New to this machine. Thanks for the info about the sound, I didn't know that, thanks again for the help!
#9 Brian D. Deuel OFFLINE
Brian D. Deuel
    Star Raider
  • 71 posts
Posted Mon Apr 9, 2012 10:28 PM
I'm working on repairing one now. Non-working left flipper and no sound. I've isolated the left flipper problem to a bad resistor. I can trigger the flipper by grounding the correct pin on the selector gate IC, and jumpering the leads of the resistor does the same.
I'll try a new speaker before trying to trace that issue, and see if that works.
If the game chip is socketed (as mine is), CAREFULLY remove the game chip and spray some electronic cleaner into the socket. Take an eraser and CAREFULLY clean the pins on the chip, then replace it in the socket and see if that fixes your Breakout paddle lines problem. Regardless of if it does or not, I'd go ahead and replace the socket anyway (this is on my to-do list as well), but the procedure I outlined is one way to attempt to isolate the problem.
The chip is a Quad And-Or Select Gate, and is most likely quite easy to find (or, at least, a equivalent can be cross-referenced). Check the resistor(s) along that circuit as well. You're probably right and one of the lines on the chip is stuck, but it's possible that a resistor could be causing this stuck signal.
The data sheet for the chip is here: http://doc.chipfind..../scl4019be.html
Gotta love old electronics. Easy to work on, as long as the chips aren't custom.
Edited by Brian D. Deuel, Mon Apr 9, 2012 10:37 PM.
#10 Charlie_ ONLINE
Charlie_
  • 2,866 posts
Posted Tue Apr 10, 2012 7:08 PM
Hi Brian. I got another from ebay for less than $25 shipped. It was really dirty but the insides were much better than my 1st unit.
Everything worked great except the power button was flakey. I transplanted the power button from my old unit to the new one and all is 100%
I took the thing apart and cleaned the body in the sink. What a difference. Looks like new.
Video Pinball is a neat old device. :thumbsup:
#11 kev23777 OFFLINE
kev23777
    Combat Commando
  • 3 posts
Posted Sat Nov 3, 2012 6:09 PM
I don't know if you ever figured out a fix for your static paddle problem. I recently acquired a C-380 and had the same problem. I ended up opening up the pot for the paddle controller and cleaned it with 91% isopropyl alcohol and it fixed my issue. There was a lot of black dust from mechanical wear over the years and it was preventing good contact when the knob was turned. It works great now.
#12 thegamezmaster OFFLINE
thegamezmaster
  • 2,284 posts
Posted Sun Nov 4, 2012 8:12 AM
Forgot about the sound. Thanks Brian for the tip on the paddle problem. I'll have to check it out when I have time.
#13 Charlie_ ONLINE
Charlie_
  • 2,866 posts
Posted Tue Nov 6, 2012 3:31 PM
During my week long power outage, this C-380 with 6 - C batteries and a 5" color RCA CRT with 9 D batteries kept me and my son busy for a good amount of time in the evenings. What a great unit. Love the breakout in this thing.
I did as was suggested by kev23777 and opened up the paddle pot cleaned it all out with 91% alcohol and it works jitter free.
#14 Rob Mitchell OFFLINE
Rob Mitchell
  • 2,784 posts
Posted Mon Jul 6, 2015 9:02 PM
Adding to this thread about the power button switch for the C-380. These are available at Best Electronics: "the New Atari C-380 Locking / latch On/Off Switches are in stock. Cost is only U$D 3.95 each."
#15 BassGuitari OFFLINE
BassGuitari
  • 4,441 posts
Posted Tue Jul 7, 2015 12:35 PM
Were those the same ones used on Ultra Pong consoles as well?
#16 Kosmic Stardust ONLINE
Kosmic Stardust
    Princess Rescuer
  • 9,702 posts
Posted Tue Jul 7, 2015 12:40 PM
Neato. Yeah vintage electronics can be tempermental. I'd love to own one as I collect pinball sims. Any good videos of the action?
#17 thegamezmaster OFFLINE
thegamezmaster
  • 2,284 posts
Posted Sat Aug 8, 2015 2:02 PM
Took it apart and blasted it with contact cleaner and fixed the tearing issue. Thanks for the tip!
