Question re Altirra Debugger
19 replies to this topic
#1 Heaven/TQA OFFLINE
Heaven/TQA
  • 8,428 posts
Posted Sun Feb 26, 2012 5:45 AM
I was just wondering for weeks now how can I disassemble memory location and then simply disassemble next page?
on most debuggers I am doing stuff like D 4000 and then a simple D while the next page is displayed. and in Altirra?
#2 flashjazzcat OFFLINE
flashjazzcat
  • 6,380 posts
Posted Sun Feb 26, 2012 6:03 AM
Scroll wheel works for me - just pull it down and it keeps disassembling.
#3 andym00 OFFLINE
andym00
  • 1,035 posts
Posted Sun Feb 26, 2012 6:05 AM
U
Seriously.. U 4000
Better using the windows for this stuff, then you can just page up and down through memory..
#4 Heaven/TQA OFFLINE
Heaven/TQA
  • 8,428 posts
Posted Sun Feb 26, 2012 6:11 AM
aem... no?
u 4000 gives me one page, then hitting page down, cursor down no effect?
#5 andym00 OFFLINE
andym00
  • 1,035 posts
Posted Sun Feb 26, 2012 6:12 AM
Debug->window->disassembly..
#6 flashjazzcat OFFLINE
flashjazzcat
  • 6,380 posts
Posted Sun Feb 26, 2012 6:13 AM
I'd assumed you were using the disassembly window.
#7 Heaven/TQA OFFLINE
Heaven/TQA
  • 8,428 posts
Posted Sun Feb 26, 2012 6:24 AM
aehm.... no... oldschool command line? or what are you guys using most?
#8 Heaven/TQA OFFLINE
Heaven/TQA
  • 8,428 posts
Posted Sun Feb 26, 2012 6:26 AM
ok. disassemly windows works ;) but is there a way to show only the mnemonics without the memory dump? ok not a big deal but could help in copy/pase code.
#9 andym00 OFFLINE
andym00
  • 1,035 posts
Posted Sun Feb 26, 2012 6:29 AM
Not that I know of.. But surely whatever editor you're using allows you to do a rectangular select ?
In VisualStudio it's shift+alt to select a rectangular region..
#10 Heaven/TQA OFFLINE
Heaven/TQA
  • 8,428 posts
and another question compared with Atari800 debugger... save state? how? the quickstate is not saveable for later?
#11 flashjazzcat OFFLINE
flashjazzcat
  • 6,380 posts
Personally I'd like to see the windowed memory dump scroll like the disassembly window, but preferably up and down.
Edited by flashjazzcat, Sun Feb 26, 2012 6:30 AM.
#12 Heaven/TQA OFFLINE
Heaven/TQA
  • 8,428 posts
Posted Sun Feb 26, 2012 6:30 AM
my editor is notepad ;)
#13 Rybags OFFLINE
Rybags
  • 11,197 posts
Posted Sun Feb 26, 2012 6:37 AM
You can copy from the Dissasembly window (as well as probably most others).
I often do traceblits with breakpoints, grab a couple of frames worth of trace and copy out the lot.
Select the block of text and use CTRL-C
Agreed, there's certain commands that need to continue their listing if you just enter them without parameters.
Edited by Rybags, Sun Feb 26, 2012 6:37 AM.
#14 andym00 OFFLINE
andym00
  • 1,035 posts
Memory window scrolling would be nice, but I keep four memory windows open, each doing 256 bytes in size, so mostly that's enough for me..
As for Heaven and his editor.. Get a new editor ;)
#15 Heaven/TQA OFFLINE
Heaven/TQA
  • 8,428 posts
Posted Sun Feb 26, 2012 10:44 AM
any ideas regarding save state?
#16 andym00 OFFLINE
andym00
  • 1,035 posts
Posted Sun Feb 26, 2012 11:02 AM
I've never used it in Altirra, and not quite sure what you're asking about actually :)
#17 andym00 OFFLINE
andym00
  • 1,035 posts
Posted Sun Feb 26, 2012 11:03 AM
Oh, I see, I think.. In the debugger you can't do a quick savestate because "it's in the middle of an instruction"..
#18 Heaven/TQA OFFLINE
Heaven/TQA
  • 8,428 posts
Posted Sun Feb 26, 2012 11:15 AM
Well... Save States help when you have a special condition to test... Or in a game to avoid the play through of levels. Atari800win can load save states.
#19 Creature XL OFFLINE
Creature XL
    Dragonstomper
  • 526 posts
Posted Sun Feb 26, 2012 12:47 PM
Savestates never worked for me. Neither from debugger nor when just running the debugee. But I did not try for long. Would be interested if you succeed. :)
#20 phaeron OFFLINE
phaeron
    Dragonstomper
  • 889 posts
Posted Sun Feb 26, 2012 3:21 PM
I never bothered to implement continuations for the disassembly command out of laziness. The .dumpdsm command will dump a disassembly to disk, and in 2.10 test-13 it has been expanded to support options that allow you to turn off code bytes, EA decoding, etc.
Current versions don't allow you to save states to a file because the file format isn't stable enough yet. The emulator stopping in the middle of an instruction is one of the factors that complicates this.
