ColecoVision Neo
61 replies to this topic
#1 opcode OFFLINE
opcode
  • 4,586 posts
  • Bringing new life to your ColecoVision!
Posted Sun Feb 26, 2012 2:06 PM
I had this idea last night, while I was sleeping.
Most CV are malfunctioning these days. On the other hand, having a brand new CV would require a super expensive plastic case, in addition to a long development time. So in the meantime, why not to offer a simpler solution.
So it occurred me that we could have a brand new PCB to replace the original CV PCB. The idea is to keep the original CV case, but replace the PCB and front plate.
The new PCB would offer a series of improvements:
- All glue logic (74LS chips) replaced with single CPLD, leading to much improved reliability.
- Replace DIP components with SMD equivalents when possible (Z80, memories, resistors, capacitors, diodes)
- Replace TMS9928 with TMS9128, for reduced number of VRAM chips (2 instead of 8 )
- Remove RF and replace with modern audio/video outputs
I believe that can be done for under $100.
How about that? Something to think about next year and discuss with Coleco later this year. We have a deal for the CV2, so I suppose they wouldn't oppose to something like this either.
Eduardo
Edited by opcode, Sun Feb 26, 2012 2:07 PM.
#2 killersquirel OFFLINE
killersquirel
    Dragonstomper
  • 819 posts
Posted Sun Feb 26, 2012 2:15 PM
This sounds like a good idea. I have another CV that is dead that I would gladly put a new board in it.
-mike
#3 AtariLeaf OFFLINE
AtariLeaf
    Epic Godlike Canadian
  • 11,315 posts
Posted Sun Feb 26, 2012 2:22 PM
Sounds like a great cost effective idea.
#4 opcode OFFLINE
opcode
  • 4,586 posts
Posted Sun Feb 26, 2012 2:33 PM
Not only cost, but I think it would be a far more reliable solution, with the reduced number of components. And of course improved A/V output.
#5 swlovinist OFFLINE
swlovinist
  • 2,261 posts
Posted Sun Feb 26, 2012 2:40 PM
I think that this is a great idea.
#6 cmart604 OFFLINE
cmart604
    Intellivision Hoarder
  • 12,515 posts
  • Running out of things to buy.
Posted Sun Feb 26, 2012 2:55 PM
Sounds like a great idea to me! :)
#7 the.golden.ax OFFLINE
the.golden.ax
  • 12,547 posts
Posted Sun Feb 26, 2012 3:10 PM
This is a very good idea.
#8 AtariLeaf OFFLINE
AtariLeaf
  • 11,315 posts
Posted Sun Feb 26, 2012 3:24 PM
So what are the chances of this actually going from "great idea" to actual product? :)
#9 evg2000 ONLINE
evg2000
  • 1,388 posts
Posted Sun Feb 26, 2012 3:26 PM
sounds good
#10 AtariBrian OFFLINE
AtariBrian
  • 3,659 posts
Posted Sun Feb 26, 2012 3:27 PM
good idea, but what about the dying out of all the power supplies?
#11 Pixelboy OFFLINE
Pixelboy
  • 8,246 posts
Posted Sun Feb 26, 2012 3:47 PM
That's one of the beauties of such a project, the new PCB would not use the old brick power supply, but rather any generic power supply that you can buy at any Radio Shack store.
This isn't the first time this idea of recycling CV console casings with a new equivalent PCB has been suggested. There was talk about it in the early days of the CV2 project. :)
#12 opcode OFFLINE
opcode
  • 4,586 posts
Posted Sun Feb 26, 2012 4:05 PM
Yeah, I know. It is just I was being more, let's say, ambitious when I first proposed the CV2. These days I prefer to think of things with a shorter development time so that I don't get tired of the whole thing halfway through the project. And I think such a board would be developed in a one year timeframe.
But again, that is for next year...
Oh, and yes, we would replace the power supply as well. In fact I don't think that the power supply connector in the back of the CV is available anymore, so...
Edited by opcode, Sun Feb 26, 2012 4:07 PM.
#13 Pixelboy OFFLINE
Pixelboy
  • 8,246 posts
Posted Sun Feb 26, 2012 4:32 PM
Would you expect any problem in acquiring ample supplies of the TMS9128 and the CV's sound chip? I'm sure the other chips and parts can be replaced easely enough, but there are a few that are surely no longer available today.
If I remember the discussions from long ago, there was a part on the CV PCB that was mainly used by the Atari expansion module (the part's name had an "H" in it, IIRC). So removing that part from the design would mean dropping support for the Atari module via the expansion port.
Perhaps dropping the front expansion port altogether and replacing it with the SGM built into the PCB would be a nice idea. Otherwise, you'd need to include that "H" part into the new PCB, assuming it can still be found today.
#14 opcode OFFLINE
opcode
  • 4,586 posts
Posted Sun Feb 26, 2012 5:15 PM
I think the TMS9128 shouldn't be a problem. Not sure about the TI PSG. And I think the H part you are refering to is the A/V selector inside the CV. It was used to select between CV and Atari module A/V outputs. Not sure about availability of that either, but perhaps there is a modern replacement. However the problem is that if we want 100% compatibility, we need the 12V/-5V supply no matter what, because that is available to the expansion port, and I believe at least the Atari module uses some of it. And if you ask me I would perfer to keep the expansion port, otherwise it wouldn't be a 100% replacement. So if we don't use 12V / -5V internally, we still need to produce it, which I don't believe would be a big problem.
#15 retroillucid ONLINE
retroillucid
  • 8,163 posts
Posted Sun Feb 26, 2012 8:42 PM
Great idea!! :)
I'm thinking to have a system mold someday, I want clear and colored cases
I know some may think I'm dreaming..... but this is the story of my life anyway ;)
#16 ten-four OFFLINE
ten-four
    Dragonstomper
  • 916 posts
  • Here i am... again!
Posted Mon Feb 27, 2012 8:07 AM
I think there are power supplies on the market that may well fit into CVs front left side. :-D
And the SGM facility be found on the main card, right. ?
#17 cOLeCoHiTMan OFFLINE
cOLeCoHiTMan
    Moonsweeper
  • 457 posts
  • Let's Go Red Wings!
Posted Mon Feb 27, 2012 8:58 PM
X-cellent idea...
"discuss with Coleco" .. who's around to talk to now?
#18 opcode OFFLINE
opcode
  • 4,586 posts
Posted Mon Feb 27, 2012 9:13 PM
X-cellent idea...
They are now Coleco Holdings. I believe an association of 3 companies.
#19 cOLeCoHiTMan OFFLINE
cOLeCoHiTMan
    Moonsweeper
  • 457 posts
Posted Tue Feb 28, 2012 7:08 PM
Would you consider this something that a n00b could drop in or would we need to ship off an empty case for modding?
If you're doing a new board.. how hard would it be to include an SD slot for ROMs? Right now you need a cart.. (which is great btw)
#20 opcode OFFLINE
opcode
  • 4,586 posts
Posted Tue Feb 28, 2012 8:00 PM
Both options, DIY or ship your CV to have it modded.
#21 Troy_Whelan OFFLINE
Troy_Whelan
    Dragonstomper
  • 847 posts
Posted Tue Feb 28, 2012 9:05 PM
The option to send in a CV to have it modded (or even buy a modded CV) is very appealing :)
#22 Ikrananka OFFLINE
Ikrananka
  • 3,109 posts
Posted Fri Mar 2, 2012 1:12 PM
Great idea. I'd certainly be up for buying these.
#23 Ikrananka OFFLINE
Ikrananka
  • 3,109 posts
Posted Fri Mar 2, 2012 1:15 PM
There are internal power supplies that will fit in that area, but it is a tight fit and a plastic post has to be cut off for it to fit. Plus the supplies are expensive (~$40+). I have modded one of mine and am delighted with the result but it is an expensive and tricky mod to do.
#24 ten-four OFFLINE
ten-four
    Dragonstomper
  • 916 posts
Posted Fri Mar 2, 2012 1:40 PM
After 4 unsuccessful CV power supplies, I have over the last few years used a converted PC power supply.
No problems, seems very stable. :)
I believe in a ColecoVision version with "a brand new PCB to replace the original CV PCB." :-D
#25 evg2000 ONLINE
evg2000
  • 1,388 posts
Posted Fri Mar 2, 2012 8:23 PM
would a PC power supply from an external scsi cd/HD enclose work? I picked up a couple today for $.99 each and they have PC power connectors, so I wonder if they supply the correct voltage and amperage? The actual ps in internal on a pcb.
Edited by evg2000, Fri Mar 2, 2012 8:24 PM.
